Old 06-08-2011, 12:35 AM   #1546
KELVIN KHNG's Avatar
Trader Rating: 15 (100%+)
Try hard... does the diff fit the ta05 version II as well?
KELVIN KHNG is offline   Reply With Quote
Old 06-08-2011, 09:23 AM   #1547
TryHard's Avatar
That one I don't know on... but I suspect not, as the TA05v2 has the spur off to one side, not in the middle like the 417, so the pulley offset will be different.
HiH
Ed
Old 06-10-2011, 08:41 AM   #1548
where you can buy the tamiya 417?. because there is not in stock at any location
oscargonzalez is offline   Reply With Quote
Old 06-10-2011, 10:21 PM   #1549
2-Bad's Avatar
Trader Rating: 24 (100%+)
Email
Champ: champ_international@​yahoo.co.jp
Or
Pro-Futaba: shop@pro-s-futaba.co​.jp
They are both in Japan, both very reliable & efficient and will be your best chance....
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 06-11-2011, 01:35 AM   #1550
kedal's Avatar
I bought mine at RCMart
TRF201 - Tekin RS Pro - PRT HS 10.5T
F103 - Hobbywing 1S - Hobbywing 13.5T
rctouch.over-blog.com
kedal is offline   Reply With Quote
Old 06-11-2011, 02:48 AM   #1551
CHICO1977's Avatar
HI does any one know what is the biggest spur Gear we can install in the 417?
CHICO1977 is offline   Reply With Quote
Old 06-11-2011, 08:15 PM   #1552
GeorgePravata's Avatar
Trader Rating: 104 (100%+)
Default Where do you find HPI silver Springs
Ok so what is the fix for not finding any HPI Silver springs for my TRF417 I've been reading about these springs and i can't find them any where. can I use the TRF spring kit or is it just HPI is a better spring.
TEAM ASSOCIATED,REEDY POWER, AKA, TQ WIRES, SILLYBOYZ PRODUCTS.
GeorgePravata is offline   Reply With Quote
Old 06-11-2011, 08:47 PM   #1553
TryHard's Avatar
If you absoutely cant find any of the HPI's, give the tamiya blues a try all around. They do feel different to drive however, as the knock the edge off the initial reaction. Worth a try
Old 06-11-2011, 10:02 PM   #1554
geeunit1014's Avatar
Use these , they are linear like the HPI springs, and they dont need a different spring retainer. The other AE springs are good as well. For Jackson on my 416, I liked the AE golds up front, and the greens in the back, although I feel the Reflex 13.5s could be better.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 06-12-2011, 03:55 AM   #1555
kedal's Avatar
There is some here
Does anybody try what I tried yesterday : I use the split arm mount front and rear, and for the rear, I use it as 1A, insteed of 1XA. Then, I have 2° rear toe insteed of the 3° stock, the car feels a lot better on my local track, wich is small, technical, medium grip alsphalt. I also put off the washer under the rear arm mount, the became easier to drive.
Old 06-12-2011, 08:39 AM   #1556
Thanks for all the Info. on the springs
Old 06-12-2011, 10:49 AM   #1557
Tekinpro's Avatar
hi ... I'm still new to use TRF 417 .. my problem now is the spring, and oil absober ... any suggestions ...?
Tekinpro is offline   Reply With Quote
Old 06-12-2011, 11:07 AM   #1558
RL.2002's Avatar
Default final result of ETS rd 5
Xenon Modified Overall Result
1. Marc Rheinard (DE) – Tamiya/Speed Passion – 3 pts
2. Yannic Prümper (DE) – Yokomo/Speed Passion – 4
3. Jilles Groskamp (NL) – Tamiya/Orion – 5
4. Cyril N’diaye (FR) – Yokomo/LRP – 8
5. Steen Graversen (DK) – Awesomatix/Speed Passion – 10
6. Ronald Völker (DE) – Yokomo/LRP – 11
7. Christopher Krapp (DE) – Kyosho/Orion – 11
8. Viktor Wilck (SE) – Tamiya/Thunder Power – 12
9. Frederik Südhoff (DE) – Hot Bodies/LRP – 12
10.Juho Levanen (FI) – Associated/Reedy – 13
the passion of the slide when taking the corner....
http://www.penabai-rcdrifter.blogspot.com/
Kyosho TF-5 drift spec powered by Ezrun 35A + 9t
Tamiya TRF-416X, Tamiya TRF-417
Hobbywing Xerun 120A, Xerun 3.5t, Team Orion 11.5t, Xerun 5.5t
RL.2002 is offline   Reply With Quote
Old 06-12-2011, 11:30 AM   #1559
kedal's Avatar
What kind of track ? what motor ?
Old 06-12-2011, 11:48 AM   #1560
Tekinpro's Avatar
high speed technical track ... I use 10.5t motor ..... may track the heat in 30celcius .. sorry .. I'm not good english
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 09:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 06:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 07:28 AM
SEO by vBSEO 3.5.0
