Old 06-05-2011, 10:33 PM   #1531
kedal's Avatar
To improve durability :
-Steel drive shaft (44mm)
-Titanium turnbuckle
Part you should break :
-3x46mm suspension shaft
-H carrier
Part needed just in case :
-Belt
-Arm
-C part
-E part
Pretty all for the start
TRF201 - Tekin RS Pro - PRT HS 10.5T
F103 - Hobbywing 1S - Hobbywing 13.5T
rctouch.over-blog.com
kedal is offline   Reply With Quote
Old 06-05-2011, 11:10 PM   #1532
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
from: http://www.tamiyausa.com/product/ite...oduct-id=42197
The use of a gear differential unit is becoming a major trend in the touring car class that use very high power brushless motor technology. The Tamiya Gear Differential Unit uses oils with different viscosity to attain adjustment, which results in optimum power transmission from the high-power brushless motors in the market today. It also improves traction and acceleration. TRF Driver Marc Rheinard uses these units in the front and rear of his TRF417 when racing on carpet to minimize diff rebuilds that are common when using a traditional ball diff unit. The unit is fully enclosed and the built-in gears are less likely to wear out compared with ball differentials.
Specs and Features
TRF417 Gear Differential Unit II x 1pc.
Aluminum Diff Cup Joint (exclusive to this item) x 2pcs.
Bevel Gear: 12T/20T (Item 42185 TRF417 Gear Differential Unit includes bevel gears with 10T/20T).
Compatible with TRF417, TA05 ver.II, and TA05-IFS R (with 37T pulley) chassis machines.
Silicone diff oils of 100000 weight are recommended as a starting point
is that a typo? or are they really recommending thicker oil for use in the new gear diff?
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 06-05-2011, 11:12 PM   #1533
ldivinag's Avatar
Originally Posted by mhavlena View Post
Yes, both ratios are indeed the same, however, the 113/62 combo WILL NOT FIT with the available spacing of the motor mount, thus, you have to go smaller on the spur/pinion combo. I would also beware of the 100/56 combo. I know 100/52 will work, better to try....if not, go even smaller on the spur...good luck!!
got it... physical size...
so then... what's everyone's fav spur gear maker? i looked at robinson's website and their 64p spur doesnt seem to have the same holes to get the center shaft and pulley holder through.
leo d.
ldivinag is offline   Reply With Quote
Old 06-06-2011, 07:52 AM   #1534
Trader Rating: 28 (100%+)
You always complain about every place you race at. You are a pretty clueless person. This should be fun watching you run onroad. Goodluck with that.
Originally Posted by ldivinag View Post
why a smaller spur? saves rotational weight?
after all, isnt fdr from 113/62 is that same as 100/56 fdr (going for a 3.5)?
track will be a parking lot in a crappy mall. so it will be dirty. dont know if they will pre-sweep it.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 06-06-2011, 08:39 AM   #1535
Trader Rating: 31 (100%+)
I was using the Xenon gears without the blue spur spacer. It looks like the RW spurs are the ticket now though. Check them out at speedtechrc.com.
ittjv is offline   Reply With Quote
Old 06-06-2011, 09:39 AM   #1536
spring71's Avatar
Smile
We have indoor rc track & hobby shop in chino CA.
Spec R Gear Diffs and Universals are in stock.
Click Here to see Spec R products.
Click Here to visit the parts store
Please visit www.tqrcracing.com for more information.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 06-06-2011, 08:23 PM   #1537
YmeBP's Avatar
Trader Rating: 32 (100%+)
Originally Posted by GMartinez View Post
there is a cutout slot directly on the bottom of the chasis which allows u to change your pinion
I did not know you were into electric! I just picked up my 417 and ran it for the first time this weekend ran great =D. Blew a spur though ... my pinions were the thin ones and it chewed up the stock spur.
I'll be bringing my 417 with me on the next trip to Kraceway!
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 06-06-2011, 09:34 PM   #1538
GMartinez's Avatar
Trader Rating: 83 (100%+)
next weekend is the electric regionals @ Kraceway
That's were it all began 11 years ago Losi XXX'S for the winter than all nitro after I moved to florida 6 years ago
The car is awesome box stock & all that I added was the spec r gear diff running 500,000 in the front with a ball diff in the rear
Full line available @ http://www.superiorhobbies.com/istar...t=19&class=SPR
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup
2014 Hosted Events Roar Paved Electric Nationals, IFMAR ISTC Worlds
2015 Roar Fuel On Road Nationals,U.S.World Nitro Cup Completed
2016 U.S. World Nitro Cup Dec 7th - Dec 11th
GMartinez is offline   Reply With Quote
Old 06-07-2011, 07:55 AM   #1539
RC MARKET's Avatar
Tamiya Gear Diff. 2 & Roll-Bar Set released !
RC MARKET is offline   Reply With Quote
Old 06-07-2011, 09:06 AM   #1540
Pro10noob's Avatar
Geardiff II is allready on it's way to me
Ordered it last week.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 06-07-2011, 10:34 AM   #1541
Trader Rating: 45 (100%+)
So it looks like for asphalt a front gear diff with 500K and rear gear diff with 1K is the ticket these days???
Apex is offline   Reply With Quote
Old 06-07-2011, 05:39 PM   #1542
Vicko's Avatar
Trader Rating: 14 (100%+)
so are those sway bars new??
different sizes
Vicko is offline   Reply With Quote
Old 06-07-2011, 08:16 PM   #1543
TryHard's Avatar
Personally, still a spool in the front for me, with either 1k or 2k (depending on the track/motor) for the rear.
I do have a 500k front diff to try, but I'm saving that for super high traction.
Regards
Ed
Old 06-07-2011, 11:10 PM   #1544
KELVIN KHNG's Avatar
Trader Rating: 15 (100%+)
GUys... do you have any idea if the gear diff version II for the 417 fit the 416 on the front?
KELVIN KHNG is offline   Reply With Quote
Old 06-07-2011, 11:31 PM   #1545
TryHard's Avatar
Yes, it should fit. The bearing spacing hasn't changed between the cars, so an axle that fits the 7 will fit the 6.
HiH
Ed
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
