Like Tree1Likes
Old 06-03-2011, 11:53 PM   #1516
noline's Avatar
Hello TryHard,
I have a setup question for you. I just picked a up a Tamyia 417. Im running the box stock setup the only change i made to the car is that i added a gear diff in the rear ( with 1000w in it) and a spool up front.
Im running 13.5 on Med bite outdoor asphalt with Protoform LTC -Body and solara hard compound tires.
The problem im having is it has a push going into the turns how can i get it to steer into the turn/corner quicker/rotate. And i need more on power steering I have to llft alot to get into the turn. I hope this makes sence. Lol...
I've been watching alot of videos of Mark Rinehard,Victor Wilck,Jilles Groskamp and Elliot Harper and i like how there cars corner better thats what im looking for.
noline is offline   Reply With Quote
Old 06-04-2011, 12:44 AM   #1517
TryHard's Avatar
Originally Posted by noline View Post
Hello TryHard,
If your using the kit springs, then change the front's to match the rears. I would suggest Tamiya blue's all round, as these are closest to the HPI Silvers that most use on tarmac.
The kit springs have a weight split (blue/yellow), so will naturally make the car understeer.
Other things to try would be to remove the 0.5mm shims from underneath the front most suspension blocks. Remember to re-set the droop when you try this. It lowers the front roll center, giving more grip.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 06-04-2011, 12:48 AM   #1518
noline's Avatar
Hello TryHard,
Ok I'll try that. I do have a set of the HPI silver springs I'll put them on thanks.
Old 06-05-2011, 10:44 AM   #1519
I've been looking some modified setup sheets from jilles and marc.
Most of the setups have 2 mm front suspension arm spacer. Instead of the 1.5 mm thats default from the kit. Is this something standard that is changed? Just to get the car more stable?
Gr.
Gerwin
GerwinGood is offline   Reply With Quote
Old 06-05-2011, 03:03 PM   #1520
ldivinag's Avatar
Ok... gonna.enter a.local TCS race next Sunday.
What pinion for the113 spur.gear would I use running a non ramped 17.5?
Thanks... currently running a 30 pinion.
Also without taking off the top deck what is the easiest way to swap out.the pinion?
leo d.
ldivinag is offline   Reply With Quote
Old 06-05-2011, 03:25 PM   #1521
GMartinez's Avatar
Trader Rating: 85 (100%+)
there is a cutout slot directly on the bottom of the chasis which allows u to change your pinion
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 06-05-2011, 03:30 PM   #1522
GMartinez's Avatar
Race 1 of the superior hobbies/kraceaway Summer Sizzler
Tq 1st,2nd & 3rd were 417 A Main 17.5 boosted final order after 6 min's
1st 417 22 laps 6:11
2nd 417 22 laps 6:15
3rd T3 21 laps 6:13
Old 06-05-2011, 03:41 PM   #1523
I would try using a smaller spur. I ran 17.5 non ramped with a 3.5 fdr.
M3dreamin2008 is offline   Reply With Quote
Old 06-05-2011, 03:43 PM   #1524
Does anyone prefer the Tamiya springs over the HPI silver when running in the parking lot?
Old 06-05-2011, 05:30 PM   #1525
ldivinag's Avatar
wow... 3.5? even with the 111 spur, that's like a 62 tooth pinion.
i mean i'm calculating this right, right? from the manual:
spur divided pinion times 1.947 = fdr...
so with the 113 i have in right now, a 63 gets me around 3.49...
i guess i'm still thinking with my off road SCTs, where i run 12-15 tooth pinions...
leo d.
Old 06-05-2011, 05:33 PM   #1526
ldivinag's Avatar
dang... nice trick that isnt mentioned in the manual...
doh...
leo d.
Old 06-05-2011, 05:49 PM   #1527
trf415msx's Avatar
Trader Rating: 15 (100%+)
I suggest to run 100 on spur and try to get ratio around 3.8-4.1 it depend on the track lay out
trf415msx is offline   Reply With Quote
Old 06-05-2011, 05:58 PM   #1528
ldivinag's Avatar
why a smaller spur? saves rotational weight?
after all, isnt fdr from 113/62 is that same as 100/56 fdr (going for a 3.5)?
track will be a parking lot in a crappy mall. so it will be dirty. dont know if they will pre-sweep it.
leo d.
Old 06-05-2011, 07:47 PM   #1529
Yes, both ratios are indeed the same, however, the 113/62 combo WILL NOT FIT with the available spacing of the motor mount, thus, you have to go smaller on the spur/pinion combo. I would also beware of the 100/56 combo. I know 100/52 will work, better to try....if not, go even smaller on the spur...good luck!!
mhavlena is offline   Reply With Quote
Old 06-05-2011, 07:52 PM   #1530
mattwoodcraft's Avatar
hi
what else should i be buying for this kit, i will be running stock so i wondering what parts i will need to stock up on
i
thanks
mattwoodcraft is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
