Old 06-01-2011, 02:06 PM   #1501
Scott B's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Juan Aveytia View Post
They're cars were box stock with exception of hpi silvers all the way around and double gear diffs. Victor told me 500,000 front and never asked for the rear diff oil.
I also recall seeing split suspension blocks frt and rear!!
Mugen Racing USA, Gizmo Racing USA, Sweep Racing Tires, R1 Wurks, Protoform...
"When I want the truth I go to the internet because that's the magical place where no one lies"...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 06-01-2011, 04:12 PM   #1502
Does anyone have stock on the new 417 Tamiya Gear Diff II??
Turillo is offline   Reply With Quote
Old 06-02-2011, 01:59 AM   #1503
kentech's Avatar
It's not released yet. Believe production is early June.
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 06-02-2011, 05:31 AM   #1504
Thanks for the reply.
Old 06-02-2011, 10:37 AM   #1505
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
Anyone looking for a used like new kit
Tamiya TRF417 Like new
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 06-02-2011, 02:55 PM   #1506
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey entitymugenmtx ygpm
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 06-03-2011, 04:34 AM   #1507
5tylez's Avatar
MuchHobby has it listed already, along with the 417 w/ Gear diff II.
http://www.muchhobby.com/shopping/pr...oducts_id=6081
http://www.muchhobby.com/shopping/pr...oducts_id=6078
So Im sure Tom just got them in at Tamiya Borgfelt.
5tylez is offline   Reply With Quote
Old 06-03-2011, 10:16 AM   #1508
ldivinag's Avatar
anyone experiencing a loud shudder when 1/2 to full throttle and turning the wheels in either direction? say about 1/3 turn and higher?
i'm thinking it's the one way front "diff"?????
this is when the car is up on a rack and i'm listening and looking at it closely.
leo d.
ldivinag is offline   Reply With Quote
Old 06-03-2011, 11:43 AM   #1509
TryHard's Avatar
And has been said before... ignore it!
It's do to with the fact that the CVD's are not true constant volecity joints, and there is always a little binding in their action. Doing it without any load and a spool will only make it more apparent. It will happen with every car on the market that uses the CVD-style driveshafts.
It really isn't something to worry about, and given the only set of dual-CVD's that seemed to be reliable were on my old Losi, I've never bothered looking at other solutions.... to put it another way (maybe a little tenuous), but the 416 won two IFMAR worlds with those CVD's up front...
HiH
Ed
Old 06-03-2011, 11:56 AM   #1510
YmeBP's Avatar
Trader Rating: 32 (100%+)
I had the same issue last weekend when i was assembling mine. Make sure you are using the right bushings, there are 2 types that are VERY close in size, the other thing double check for burrs (there weren't any on mine) on the teeny tiny ones. Once i had the correct bushings in place things were super smooth even when tightened down.
The other thing i found was that I couldn't fit the correct number of shims (1x3mm) infront of the rear arms ... i tried just about every permutation and i couldn't do it. can somoen take a pic of their spacers in front of the rear arms for me?
so... got my 417 tonite (*super duper price).
took about 10 hours. and still not complete but got about 80% done.
now, about the steering. looking at the manual, step 8 page 7.
1. shims are silver and spacers are blue anodized, right?
2. right now, without a servo and just moving the steering by hand, the 2 screws BA1 that goes into steering bridge BB20 will loosen up after a few cranks. if i tighten them down, it binds. it seems that there needs to be a shim on the top, not just a the bottom of BB20... right?
thanks... now for sleep... lol...
one more thing... no other way to mount the battery besides using tape (either double sided or actual batt tape)???
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 06-03-2011, 01:25 PM   #1511
rc_square24's Avatar
Does anyone know if the 417 diff rings will fit on the tamiya aluminum diff joints for the ff03?
The 417 has 2 flat spots on the rings, but I cant tell if the ff03 alum diff has 2 notches or not (from pics) and if the diameter fits. I have neither of the parts to compare.
rc_square24 is offline   Reply With Quote
Old 06-03-2011, 07:52 PM   #1512
Default Tweaked car?
Just finished assembling the 417 and noticed that, when the shock preloads are the same, there is unequal ride height left to right by approx 0.5mm, which is giving me a tweaked car.
The only way to rectify is by preloading the battery side shocks much more than the ones on the other side. Now the ride height is equal and there's no more tweak.
What could be causing this? Also what would be the drawbacks of running the car the way it is right now as explained above?
Anyone experience this?
thx
mhavlena is offline   Reply With Quote
Old 06-03-2011, 09:16 PM   #1513
geeunit1014's Avatar
Tory, best thing to do is get however many shims you want on the setup sheet side, and then fill the other side up with small shims until the play is right.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 06-03-2011, 10:34 PM   #1514
ldivinag's Avatar
what i eventually did on mine was i noticed that i needed to add enough shims to the cross bar is flushed with the steering arms.
now, it's solid tight and it turns easily...
leo d.
Old 06-03-2011, 10:45 PM   #1515
TryHard's Avatar
thx
Simple answer, no drawbacks, IMO.
Double check your shock lengths, and make sure all the holes are right on the arms (trust me, done that one..). Also check the suspension blocks/hinge pins to make sure there are no bends.
If it's still out, it's most likely either a little bit of weight balance out, or a little bit of tweak in the chassis plate. You might be able to solve it with a bit of a re-jig on the electrics, or utilise the "push down on shock towers when tightening top deck" technique. However, personally, anything up to a full turn difference on the spring collars is fine, as this means that each tyre is getting equal loading... I put that above equal ride-height in the scheme of setup.
My 417 tends to run between 1/4 and 1/2 turns different on the rear (front is norma equal), and never have a problem with tweak. Bear in mind this is done with an MIP tweak board, so it's pretty close to being spot on.
HiH
Ed
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
