Like Tree4Likes
Old 02-08-2017, 09:55 AM   #1351
windstar's Avatar
Originally Posted by LloydLoar View Post
It looked a lot like the same old TOP car that has been around since 2011, just with an alu chassis made by McFactory/Wallace/whatever name they use now.
The winner is Ray Darroch. It is the latest Version with Alu Chassis and a few little different parts.
Pictures at petitrc.
windstar is offline   Reply With Quote
Old 02-08-2017, 03:08 PM   #1352
odpurple's Avatar
Default Ray Darroch Snowbirds 2017 1/12th 17.5
Congratulations to Ray Darroch for his first place finish in 1/12th 17.5 at the 2017 Snowbirds. Here are a couple pics and the set up.
We are continuing development on the original design but as of today there is no new kit in the works. The version Ray ran at Snowbirds uses the latest McFactory aluminum chassis. The chassis set is supplied with a new cross brace and can be built as stock with the original cross brace stand offs and side springs mounted above the links or with the cross brace mounted lower on shorter stand offs and side springs mounted inboard. The short stand offs as well as spacers and hardware for the alternate cross brace installation are supplied with the chassis set.
Front Springs .020
Camber -1
Caster 0
Reactive Caster 10
Reactive Adjuster Spacer 1mm
Axle Spacer 1mm
Front Suspension Arm Mounts-Narrow
AE Steering Blocks, Lunsford Axles
Kingpin Lube 15K
Ride Height 3.5mm
Shock Spring-Copper
Side Springs-TOP Black
Shock Oil 550CST
Center Shock Mount-Top Hole
Ride Height Center and Rear 3.5mm
Standard Side Spring Position on Links w New Cross Brace
Damper Tubes 15K
Alloy Chassis
Spec Tires 40mm Fr and Rear
SXT Sauce
Body Strakka 12
Motor Fantom V2R 17.5
Gearing 56/72
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 02-08-2017, 03:48 PM   #1353
haywood's Avatar
Trader Rating: 48 (100%+)
Default Top
One of my favorite cars I've owned over the years! OD is tough to beat as well!
Calandra Racing Concepts/ Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 02-12-2017, 08:47 AM   #1354
http://site.petitrc.com/reglages/top...dNational2017/
Arn0 is offline   Reply With Quote
Old 02-16-2017, 04:20 PM   #1355
nitrobeast's Avatar
Trader Rating: 41 (100%+)
looking to sell my rebel if anyone is interested.
TOP Rebel 1/12th McFactory Chassis
nitrobeast is offline   Reply With Quote
Old 02-23-2017, 03:38 AM   #1356
chef88's Avatar
Have to cars for parts or build them
Rebel 12 (2)
X -Ray X1.TRF 101
Rebel 12, T4 2017.
Maryland Funster/ Beneteau 373.
180 Raceway/ Johns Mobile Raceway.
chef88 is offline   Reply With Quote
Old 02-28-2017, 07:34 AM   #1357
performula's Avatar
Will a Futaba S9650 fit, stock, or do the servo mounts to be re-drilled for the servo to fit?
performula is offline   Reply With Quote
Old 03-01-2017, 01:55 AM   #1358
I have a S9650 in mine,no drilling needed.But I did use CRC servo mounts.I guess it also works with the kit mounts...
M.Boos is offline   Reply With Quote
Old 03-13-2017, 09:09 AM   #1359
Am I right,3rd and 4th place at the roar nats in the modified class for the Rebel12?great job guys!any info and pictures of the cars would be great!😁
Old 03-13-2017, 09:15 AM   #1360
Trader Rating: 15 (100%+)
Ray got 3rd with the Rebel, yes. I am driving for Destiny now, actually - so no Rebel.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 03-26-2017, 06:26 PM   #1361
BardSmith's Avatar
Trader Rating: 61 (98%+)
Hey guys, I'm going to be listing my nigha Rebel 12 on the national thread shortly, hit me up if you're interested but here's a preview photo. Electronics will be removed.
T.O.P Racing's Rebel 1/12th scale-img_20170326_100108_crop_436x607.jpg
Taz_S likes this.
"Bard"
On-Road Only!
BardSmith is offline   Reply With Quote
Old 04-19-2017, 05:44 PM   #1362
odpurple's Avatar
Default Rebel 12
Rebel 12 kits in stock at TOP Racing USA!
Aluminum chassis sets also in stock!
[email protected]
650-583-8898
Taz_S likes this.
Old 06-26-2017, 09:00 AM   #1363
darnold's Avatar
Originally Posted by Racermac73 View Post
no real need for a new car.. this has been one of the best cars for a long time now. congrats to Ray on the big win
For the racer, a "New" kit from a manufacturer represents a solid investment of their money. They know that support of parts and setup advice will be available, but sometimes team size can be misconstrued as a platform problem when it's not.
Racers should remember that most of the "new" car launches are actually "ongoing" development accumulations that manufacturer's do every few years until something truly revolutionary comes about. So the 'new' kits are usually refinements of some aspect of their design theme. For instance, they may want to introduce better pivot balls for less play along with a better differential setup. Or they may want to introduce a slightly revised front steering geometry to work better in higher bite; or a stiffer chassis that allows adjustable wheelbase. Although these revisions can be misinterpreted as "new cars" instead of evolution's, it does appear that this update or "freshening" up cycle can serve as an indicator to the buying public that the car is still viable. TOP has chosen not to take that path so it can seem as if no development is going on and it's a dead platform; but nothing could be further from the truth.
The TOP car has done lots of development testing since its introduction. For instance, an in-line configuration was extensively tested to see if they needed to bring out a new chassis configuration, but the tests were very inconclusive so nothing was done. Sure TOP could have released a 2014 "In-line" car anyway but all it would have been was a standard TOP Rebel with a different chassis plate. So why do that, just to have a "new car"? TOP also tested a different front end configuration and changes to the roll centers, and some other geometries, but they didn't offer overall increased performance. So again, why bring them out as a 'new' kit was TOP's thinking?
The AL chassis represented a tangible improvement for the increased traction of the Black carpet so an addendum kit was created. There are other things being tested right now that may offer increased adjustability for a wider performance envelope. At some point TOP USA may put it all together and offer a "new" kit. They just wanted it to be something of substance for their platform like other manufacturers do for theirs. Because their base platform has been really quite good it has taken longer to get to that point.
What can be said for now and the future is that everyone that runs a TOP Rebel 12th scale will continue to have parts availability and setup support; just as they have since it's introduction in 2011-2012. The car is still being run at the highest levels from 17.5 to 13.5, through 12th Mod, and it is doing well. The team has shrunk some as drivers find other opportunities, but that is the economy of today's market, and the cycle that most teams go through. Neither constitutes any real change in the car's capability, and the TOP Rebel is still very much a capable and consistent platform to compete and win with.
Taz_S likes this.
Team Top Racing USA,Team MaClan ESC, Pro One Tires, Hot Race Tires
darnold is offline   Reply With Quote
Old 06-27-2017, 07:38 AM   #1364
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
Thumbs up
TOP 12 fo' life!!
Taz_S likes this.
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Trains and Lanes Onroad Racing Summer 08 edition t_laible Racing Forum 2280 06-09-2010 01:41 PM
FS: 1/12 Scale, GTB, 9650 Servo, receivers, Setup Station, DPD, Lathe, +more revolution31 R/C Items: For Sale/Trade 27 12-18-2009 11:09 AM
3-10-2007 Trenton Carpet Racing ShaunMac Georgia Racing 10 03-09-2007 01:49 PM
Hampton MN Rc Racing Mark O'Brien Minnesota and North/South Dakota Racing 411 01-04-2007 11:47 PM
