Like Tree4Likes
Old 12-03-2015, 01:27 PM   #1306
landau's Avatar
Please try new GXX compound soled by kimihiko. This is dominate in AOC race. GX is already discontinued.
landau is offline   Reply With Quote
Old 01-09-2016, 03:56 AM   #1307
Dray01's Avatar
Thanks again for the input on the JFT foam. I finally got my hands on some. Delivery was not great over the holidays.
Cannot agree more regarding pace and zero fade. Generally I run ulti's which are a great choice but I will be switching to JFT.
Dray01 is offline   Reply With Quote
Old 01-19-2016, 11:59 AM   #1308
Trader Rating: 15 (100%+)
Here is my setup sheet from the 2016 1/12 Reedy Race of Champions:
http://chrishillier.com/wp/wp-conten...6_hillierc.pdf
My car was really good with this setup. The driver? Debatable.
Let me know if you have any questions.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 01-21-2016, 07:34 AM   #1309
I received some questions about the front end configuration of my car, so I have updated the setup sheet to try and make things clearer.
I use AE R5 steering blocks with two 0.1 mm shims, one of top of the steering block, one below the steering block. I then use a single 1 mm shim on the axle.
I use shims on top of the kingpin to set droop to be even from side to side - those shims are not mentioned in the setup sheet since they are variable depending on the springs. My car has around 0.2 mm of front droop.
Old 02-09-2016, 04:32 PM   #1310
Default lower pivot balls
I've never been a fan of using metal pivot balls in the lower front arms of any 1/12th scale car. Metal balls are great for the upper ball since they typically minimize the play that can occur within the upper eyelet. But I've always found that my kingpins just don't seem to slide as smoothly thru a metal lower pivot ball as they do thru a delrin or nylon ball. And yes, I do polish the kingpins. So my question is this.....can someone please advise on which brand of nylon or delrin pivot balls fit best in the Rebel 12's front lower suspension arms?
New Bern, N.C.
CRC, McFactory, Motiv
vafactor is offline   Reply With Quote
Old 02-09-2016, 11:14 PM   #1311
bshookup's Avatar
Trader Rating: 18 (100%+)
I too had a similar issue with metal in the lower arms. I can't claim that they are the best, but I've been happy with standard Associated 12R5 balls.
TEAM ASSOCIATED
REEDY
TEAM POWERS: www.teampowersusa.net/
bshookup is offline   Reply With Quote
Old 02-11-2016, 09:56 PM   #1312
Trader Rating: 13 (93%+)
Is it normal for the side black springs to be mega tight when pushing them on?
mine took a lot of force and in the end i noticed the springs are a bit bent
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 02-12-2016, 09:08 AM   #1313
mine took a lot of force and in the end i noticed the spring looks retarded
Not too pumped about your word choice there, but yes, it is normal for the springs to be fairly tight on the retainers. You just need to slowly work them on and then you should be able to get them to settle on the retainer so they aren't at an angle.
Old 03-01-2016, 10:46 AM   #1314
odpurple's Avatar
Default Kits!
Hey Guys,
We just received a new batch of Rebel 12 kits at TOP Racing USA.
It is a small number so these will not last long.
[email protected]
650-583-8898
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 03-01-2016, 12:18 PM   #1315
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by odpurple View Post
Hey Guys,
[email protected]
650-583-8898
O.D. Purple Aluminum Edition ?
Old 03-01-2016, 12:22 PM   #1316
odpurple's Avatar
Special order just for you, Buddy!
Old 03-06-2016, 04:48 PM   #1317
odpurple's Avatar
Default Carpet Nats
So stoked to see three Rebel 12s in the Modified A Main at the ROAR Carpet Nats at Pro Level RC!
Ray Darroch finished 3rd
Chris Hillier in 5th
David Arnold in 10th
Old 03-08-2016, 01:37 PM   #1318
Thanks OD! My car was good, my driving just let down the side.
Here is my setup from carpet nats:
http://chrishillier.com/wp/wp-conten...d_hillierc.pdf
I know Ray's car was quite a bit different, so more evidence that there are multiple ways to make this car quite good on the new carpet.
Old 03-12-2016, 12:42 PM   #1319
odpurple's Avatar
Default Aluminum Chassis!
We are now taking orders for the new Wallace Motorsports Aluminum Chassis Set for the TOP Rebel 12
[email protected]
650-583-8898
T.O.P Racing's Rebel 1/12th scale-img_20160310_173935054.jpg
Old 03-13-2016, 03:31 AM   #1320
TOP Rebel12 is TQ at the German Championships in the 10.5 Blinky Class!
Nice!
TOP Rebel 12 - Hobbywing XR10 Pro Stock Spec - GM Racing 10.5 - nVision - Futaba
TLR 22 4.0 - GM Racing - Graupner - Futaba
M.Boos is offline   Reply With Quote
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 01:46 PM
Trains and Lanes Onroad Racing Summer 08 edition t_laible Racing Forum 2280 06-09-2010 02:41 PM
FS: 1/12 Scale, GTB, 9650 Servo, receivers, Setup Station, DPD, Lathe, +more revolution31 R/C Items: For Sale/Trade 27 12-18-2009 12:09 PM
3-10-2007 Trenton Carpet Racing ShaunMac Georgia Racing 10 03-09-2007 02:49 PM
Hampton MN Rc Racing Mark O'Brien Minnesota and North/South Dakota Racing 411 01-05-2007 12:47 AM
