Like Tree4Likes
Old 02-24-2015, 06:18 AM   #1276
Originally Posted by M.Boos View Post
Same problem here. I have a Savöx 1257 and the spline is about 1mm left from the middle. I use the CRC Servo mounts.
I think I will get a new Servo. and I had the Futaba S9650 on my mind. Is it any good? Is it possible to get this one centered correctly?
Thanks!
the 9650 is not the smallest, lightest, or fastest servo around. but they are smooth, accurate, affordable, and ultra reliable. I generally use 9650's in all of my pancars and have not been tempted to use anything else. In a Rebel, they bolt right down to the holes provided and it is handy that no servo mounts are needed because you can just use the flat-mounting tabs that are a handy feature of the futaba servos.
vafactor is offline   Reply With Quote
Old 02-24-2015, 06:37 AM   #1277
Thank you, just ordered one.
TOP Rebel 12 - Hobbywing XR10 Pro Stock Spec - GM Racing 10.5 - nVision - Futaba
TLR 22 4.0 - GM Racing - Graupner - Futaba
M.Boos is offline   Reply With Quote
Old 02-24-2015, 10:34 PM   #1278
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
Originally Posted by racenut123 View Post
I need suggestions for some Tires for higher bite/big race conditions.
Currently running Black/yellow combo but I know there are better combos. I have been looking at the BSR Blue/double Blue and green combos and Ulti options. Will be running 17.5.
Any help is greatly appreciated because my head hurts reading for the last 3 hours on all these newer tire compounds.
You already know what tires are working. Just stick with what you know.
Josh-n-ya is offline   Reply With Quote
Old 02-24-2015, 11:07 PM   #1279
Trader Rating: 28 (100%+)
LoL yeah, yeah Josh. I got all the combos coming. I will be trying both the Ulti and the BSR jft tires.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 03-18-2015, 08:11 AM   #1280
dr_hfuhuhurr's Avatar
I'm in the process of rebuilding my car post season. Is there anyone using a Futaba BLS651 that's mounted to the chassis without gluing it? What are you using?
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 03-18-2015, 08:51 AM   #1281
oeoeo327's Avatar
Trader Rating: 70 (100%+)
My back-up car has a Futaba 9650 in it, attached to the chassis using the mounting brackets on the case. I wouldn't be surprised if I performed the same installation in my primary car as well.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 03-18-2015, 08:56 AM   #1282
You mean those things I cut off to fit in my other 12th scale car...DOH!
Old 03-18-2015, 09:12 AM   #1283
hanulec's Avatar
Trader Rating: 27 (100%+)
futaba 9650 here.
shoegoo.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 03-22-2015, 09:19 PM   #1284
Default Spurs
I've been reading over this thread for awhile now. First just wanted to say it contains a large amount of information. So thanks for that.
Backlog, I got a Rebel and drove it and 1/12 scale for the first time. It rocked. Loved it. I'll be adding 17.5 1/12 to the classes I'm running.
The only question that I can't quite find in this thread is about spurs, specifically how they relate to diff balls.
My used kit came with a 73T spur. Works fine, however I'm sure I'll need to replace it. As such I ordered a few things from Arrowmax and one was a 74T spur that I thought I might give it a try. Wrong, the relief for the diff rings is 24.7mm in diameter. Thickness around 5mm outside of that near the teeth.
Diff balls won't touch the plate and the diameter of the diff holes will not allow such a big diff ball to increase the thickness. I assume if I would like to give this spur a try I"ll need smaller diff rings?
Looks like if I ordered a larger spur the Rebel rings would of fit. Who knows what tooth I would of needed though.
Is there some sort of guide of which spurs fit the Rebel or other cars? Guy that sold the car threw in another spur. Little known to me it was a CRC. From the look I got when I showed a fellow racer that wasn't going to work. I guess I'm lucky that it was thrown in with the kit..
I also noticed some talk about moving the motor forward by using the a large spur. Is that what the cool kids are doing now days?
Thanks in advance.
homerthefourth is offline   Reply With Quote
Old 03-23-2015, 04:56 AM   #1285
oeoeo327's Avatar
Thanks in advance.
Several ways to go about resolving this issue... No "special" spurs are required, just compatible diff balls, diff rings, and spurs. Easiest way to address fitting spurs to the car would be to use PRS, RW, or Core R/C spur gears (they are flat, and roughly 3mm in thichkness), and using 1/8 inch diff balls. TOP diff rings should work without any problem.
Old 03-23-2015, 09:36 AM   #1286
windstar's Avatar
I bought me the option motormount-kit to use smaller spurs and coming on a rollout of around 63 mm. I also can use pinion like from 33 to over 40.
I suggest to check out what rollout you need with your motor.
Actually I use 78 spur, 36 pinion with around 43 mm diameter of wheel in the back (front 41.5). Driving 10.5 motor 1S lipo.
By the way, I put the balldiff together only with GearLube, no grease!
Works fine over 100 minutes without taking appart again. Very smooth and no adjusting's needed (checking it after every 8 minute run).
windstar
No TC at the moment, Team Associated RC5.2 x 2, Tam Associated RC10 B6, T.O.P Racing Rebel 12 (2013), VBC Lightning 12M, Sanwa M12
windstar is offline   Reply With Quote
Old 03-23-2015, 09:38 AM   #1287
D4 17.5. 42mm diameter F/R. 73T spur. Rollout 100mm. Which puts the pinion at 55T.
Old 03-30-2015, 06:28 AM   #1288
Can someone post a link to the washers used on the upper hinge pin?
Old 03-30-2015, 07:12 PM   #1289
odpurple's Avatar
Many racers use these:
T.O.P. Racing Products #PA-100204 Shim Set 2 x 4mm .1, .2, .3mm (10 ea)
I've recently started using these from McMaster-Carr:
#95610A510 Nylon Flat Washer, M2 Screw Size, 2.2mm ID, 5.0mm OD
You have to cut a flat spot on one side as the OD is too large, but they are easier to use than stacking up all those stainless shims.
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 03-31-2015, 07:50 AM   #1290
CRC makes nice little nylon caster spacer shims too
1253 - Front Hinge Pin Caster Washers
Front Hinge Pin Caster Washers - (8)
Price: $1.99
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Trains and Lanes Onroad Racing Summer 08 edition t_laible Racing Forum 2280 06-09-2010 01:41 PM
FS: 1/12 Scale, GTB, 9650 Servo, receivers, Setup Station, DPD, Lathe, +more revolution31 R/C Items: For Sale/Trade 27 12-18-2009 11:09 AM
3-10-2007 Trenton Carpet Racing ShaunMac Georgia Racing 10 03-09-2007 01:49 PM
Hampton MN Rc Racing Mark O'Brien Minnesota and North/South Dakota Racing 411 01-04-2007 11:47 PM
