Like Tree4Likes
Old 02-07-2015, 10:55 PM   #1261
Josh-n-ya's Avatar
Trader Rating: 73 (100%+)
Originally Posted by racenut123 View Post
anyone have a Rebel kit or roller for sale? pm me!
lol
Josh-n-ya is offline   Reply With Quote
Old 02-07-2015, 11:09 PM   #1262
Trader Rating: 28 (100%+)
The owner wants his car back.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 02-08-2015, 10:47 PM   #1263
bshookup's Avatar
Trader Rating: 18 (100%+)
YGPM
TEAM ASSOCIATED
REEDY
TEAM POWERS: www.teampowersusa.net/
bshookup is offline   Reply With Quote
Old 02-14-2015, 07:03 PM   #1264
Dray01's Avatar
Originally Posted by Donny Lia View Post
I was not using the prototype software at the Worlds, I have been running 4.0. I like it, but I plan on trying another version soon, probably the 12th scale specific one. I'm not sure but I think Olly Jefferies was running the new 12th scale version. As far as rx pack or booster, it is not recommended but it can be done. I have been running it this way for about 2 years now. I'll get my setup up there once I get a chance I'll summarize it below.
-1.5dg Camber
-6dg Caster
-3mm ride everywhere
-1.5mm pod droop above ride height
-asc. .020" front springs-neutral
-Top Black side springs barely touching
-15K Kyosho grease in tubes and front pins
-41mm front/42mm rear BSR blues (kinda big, low traction)
-50wt in shock/Top copper center
-165mm front width, 171mm rear
i'll get my speedo setup on here too when i get my hands on it. LMK if there anything else specific you need to know.
Thanks for Sharing Donny and congrats on your efforts at worlds!
Just wondering if you can share you ESC/motor settings.
Thanks,
Brett
Dray01 is offline   Reply With Quote
Old 02-23-2015, 01:51 PM   #1265
Dray01's Avatar
Originally Posted by LloydLoar View Post
I use ASC4626, which also includes a pair of caster blocks you won't be using. Yes, you will need to use the AE axles, ASC4627 along with the appropriate nut.
You could also use the Xenon steering blocks, which are a little 'nicer' and will also give you the option of changing scrub: http://xenon.ocnk.net/product-list/48
To mount the servo flat you can either just shoegoo the servo down or use servo mounts from any number of other chassis. I think the following are pretty good:
- VBC Servo Mounts (expensive, though) - B-02-VBC-5012
- Kyosho servo mounts KYOPZ029 (this red isn't a perfect colour match, fyi)
- CRC molded plastic servo mount - CRC 3315 (made for imperial screws, but should work with metric)
With the servo mounted flat and with r5 steering blocks, I believe I have 3 mm shims underneath the ballstuds on the steering blocks. Servo saver is a normal black kimbrough, lower holes.
Hi Chris,
What servo do you use with the Kyosho mounts?
I got the mounts but alas it did not work out.
I have been running a savox and it seems that it is non standard size or just a little to wide.
Thanks,
Brett
Old 02-23-2015, 02:51 PM   #1266
ralph m's Avatar
R/C Tech Charter Subscriber
Trader Rating: 31 (100%+)
Originally Posted by Dray01 View Post
Hi Chris,
Thanks,
Brett
If you like the Savox servo and don't mind taking it apart, this mount it awesome. It converts the Savox to the Futaba mount spacing and you just have to run the servo on the left side of the chassis.
http://www.mcpappyracing.com/store/p...Case-Core.html
http://www.mcpappyracing.com/savox.php
Ralph
tqwire.com
ralph m is offline   Reply With Quote
Old 02-23-2015, 03:19 PM   #1267
wingracer's Avatar
Trader Rating: 23 (100%+)
Yeah the problem with savox is that the spline comes out at a different point than any others so you can't get it centered using stock holes on pretty much any car. That McPappy case is the hot ticket if you want to use that servo.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 02-23-2015, 03:42 PM   #1268
Trader Rating: 15 (100%+)
Hi Chris,
Thanks,
Brett
Hey Brett!
I use the KO Propo 951 with the Kyosho servo mounts. As others have said, you are encountering 'the issue' with the Savox servos, where the spline is at a different center point than with all other servos. You will have a similar issue no matter the servo mounts you use, so I would recommend either using a different servo or buying the McPappy case, as linked by Ralph.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 02-23-2015, 03:44 PM   #1269
hanulec's Avatar
Trader Rating: 27 (100%+)
or just install your servo with a healthy portion of shoegoo. let it sit/setup for 12h+ ... and your good to go!
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 02-23-2015, 03:48 PM   #1270
not all of us are uncultured savages like you, FJ
Old 02-23-2015, 03:52 PM   #1271
Dray01's Avatar
haha Cheers guys,
I have it stuck flat but wanted to mess with ackerman so I ordered the mounts.
It's a learning process right! That McPappy case looks sweet. (Glad there is a silver option) It is a cheaper option than a new servo i guess.
Loving the top btw. Consistently placing top 2 at my local club in mod. Thanks for all the help FJ, Chris and the rest of the guys on here.
Old 02-23-2015, 03:52 PM   #1272
L.Fairtrace's Avatar
Send a message via AIM to L.Fairtrace
Or you could do what I did at the IIC when mine came loose. A healthy dose of CA and bang. 20 seconds later back on the track
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 02-23-2015, 11:23 PM   #1273
I need suggestions for some Tires for higher bite/big race conditions.
Currently running Black/yellow combo but I know there are better combos. I have been looking at the BSR Blue/double Blue and green combos and Ulti options. Will be running 17.5.
Any help is greatly appreciated because my head hurts reading for the last 3 hours on all these newer tire compounds.
Team I'm Over It
Old 02-24-2015, 04:09 AM   #1274
hanulec's Avatar
these new tires are complicated. sorry, i wish it was like it used to be.
for front - i've run bsr: double blue, magenta
for rear - i've run bsr: blue, green
Old 02-24-2015, 05:42 AM   #1275
Same problem here. I have a Sav÷x 1257 and the spline is about 1mm left from the middle. I use the CRC Servo mounts.
I think I will get a new Servo. and I had the Futaba S9650 on my mind. Is it any good? Is it possible to get this one centered correctly?
Thanks!
TOP Rebel 12 - Hobbywing XR10 Pro Stock Spec - GM Racing 10.5 - nVision - Futaba
TLR 22 4.0 - GM Racing - Graupner - Futaba
M.Boos is offline   Reply With Quote
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Trains and Lanes Onroad Racing Summer 08 edition t_laible Racing Forum 2280 06-09-2010 01:41 PM
FS: 1/12 Scale, GTB, 9650 Servo, receivers, Setup Station, DPD, Lathe, +more revolution31 R/C Items: For Sale/Trade 27 12-18-2009 11:09 AM
3-10-2007 Trenton Carpet Racing ShaunMac Georgia Racing 10 03-09-2007 01:49 PM
Hampton MN Rc Racing Mark O'Brien Minnesota and North/South Dakota Racing 411 01-04-2007 11:47 PM
