Old 12-31-2014, 03:31 AM   #1231
Trader Rating: 32 (100%+)
I still have a few 2.5 mm chassis left you can email me at red_mosquito7@rocketmail.com for more information.
If guys are interested in the the 2mm version let me know as well, if I can get enough pre orders I will get another run cut.
The attached pic is the 2.5mm chassis.
Monti
T.O.P Racing's Rebel 1/12th scale-image.jpg
Monti is offline   Reply With Quote
Old 12-31-2014, 09:59 PM   #1232
slowpoke68's Avatar
Trader Rating: 28 (100%+)
Default top rebel 1/12
question?how much difference is there between a 17.5 setup and a 13.5
what i have now is
front spring associated 20.
top black sides just touching
copper center w/50 wt oil
battery all the way back
ulti's xh front/xm rear
1.5 camber/6 caster/10 deg reactive
level front and rear at least 3.2-3.4 ride height
on my 13.5 i don't have enough steering i would have to let off to make sharp turns but the 17.5 is ok and not that much slower.what am i doing wrong
thanks
coyote hobbies raceway,tq raceway,kenon hobby.apex speed shop
futaba 4px,hobbywing,schuur speed,associated b6 b5m t5m sc5m,mini z,ta05 v2,some rock crawlers,and still counting....
slowpoke68 is offline   Reply With Quote
Old 12-31-2014, 10:10 PM   #1233
racer x 1's Avatar
Trader Rating: 27 (100%+)
what i have now is
thanks
I would go thicker on the side tubes. it will free the car up all around.
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 12-31-2014, 10:35 PM   #1234
slowpoke68's Avatar
using kyosho 15000 in the side tubes on both cars
Old 01-01-2015, 02:47 AM   #1235
racer x 1's Avatar
try 20k in the 13.5 car.
Matt Bell
Old 01-01-2015, 07:49 AM   #1236
hanulec's Avatar
Trader Rating: 23 (100%+)
Slowpoke - u need more side spring tension.
And less front camber..
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 01-01-2015, 07:56 AM   #1237
Trader Rating: 15 (100%+)
what i have now is
thanks
Where in the corner is it lacking steering?
How much of the front tire are you doping? I know folks have had success with the xh fronts in 13.5 in the past, myself included, but they do lack a bit of steering compared to using a blue or magenta front. Good thing about xh front is that it is wicked easy to drive, even when the bite is high.
I don't know that I agree with the damper tube change. I would think about where in the corner it is lacking steering and then look at caster and/or front tire. Just my thoughts.
LloydLoar is offline   Reply With Quote
Old 01-01-2015, 10:56 PM   #1238
slowpoke68's Avatar
lack of steering seems at the beginning i would have to let off sooner to make the turn tighter or it would push out through the turn.
i thought of getting the rear inserts from ulti for the rear tires suppose to give more steering also i have a new chassis red mosquito on the way.well see what happens this weekend..
Old 01-04-2015, 07:23 AM   #1239
windstar's Avatar
Hey there!
I bought me a Rebel 12 (not the new one) and I am also reading here from first page about everything.
I would like to know what the different is between flat Servo and the original way to Mount it? Is there a different driving the Car?
More or less I have it in the original way, just a different Setup.
First Race was ok, but it is to aggressiv in the front.
In march is the german Championship and I want to race it in 10.5 blinky.
windstar
Team Durango DETC410, Team Associated RC5.2 x 2, Tam Associated RC10 B6, T.O.P Racing Rebel 12 (2013), Sanwa M12
windstar is offline   Reply With Quote
Old 01-04-2015, 01:34 PM   #1240
Racermac73's Avatar
Lay the servo flat and put the front upper in the middle hole (5).. Those changes will calm the car way down
TEAM SCREAM, McFACTORY, TQ WIRE, HO-B-MAX, MBR SPEED SHOP, DSI INC, SPEEDMERCHANT , 360 RACEWAY, XENON-USA.COM, TEAM SAXO, ROCHE USA, SANWA, DESOTO RACING, HOT RACE TYRES
Racermac73 is offline   Reply With Quote
Old 01-05-2015, 01:33 PM   #1241
windstar's Avatar
Thanks a lot! Now with the servo flat, I put the Speedo and RX a different way. The next days I will shortening the wires. It looks pretty good after that. I love that car.
windstar
Old 01-05-2015, 03:08 PM   #1242
Rear inserts might help, but I find those to be more of an 'icing on the cake' type of change. If you think the car is lacking quite a bit at a specific part of the corner, you could always try changing caster to match. In this case, reduce caster to gain more initial steering. I personally think 6 degrees is quite a lot of caster, especially so if you run in high grip.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
Old 01-05-2015, 10:07 PM   #1243
slowpoke68's Avatar
ran the car this last weekend and what a difference.i had a tweak chassis so i got a red mosquito 2.5 mm.
my set up was
4 caster
1.5 deg camber
middle hole for reactive caster
.5 toe out
1.4mm pod droop
top black side spring
associated .20 front
top cooper center spring
ride height 3.4 front and rear
ran great handle perfect just need to drive more
Old 01-07-2015, 10:04 AM   #1244
windstar's Avatar
Step one is finished.
Servo lay down, wire in the back is short.
T.O.P Racing's Rebel 1/12th scale-wp_20150107_17_53_56_pro.jpg
windstar
Old 01-08-2015, 08:28 PM   #1245
bigcracing's Avatar
Does anybody have a good setup for 17.5 and medium grip track.
ThNks Chris
bigcracing is offline   Reply With Quote
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Trains and Lanes Onroad Racing Summer 08 edition t_laible Racing Forum 2280 06-09-2010 02:41 PM
FS: 1/12 Scale, GTB, 9650 Servo, receivers, Setup Station, DPD, Lathe, +more revolution31 R/C Items: For Sale/Trade 27 12-18-2009 12:09 PM
3-10-2007 Trenton Carpet Racing ShaunMac Georgia Racing 10 03-09-2007 02:49 PM
Hampton MN Rc Racing Mark O'Brien Minnesota and North/South Dakota Racing 411 01-05-2007 12:47 AM
SEO by vBSEO 3.5.0
