Like Tree4Likes
Old 09-04-2014, 01:20 PM   #1186
odpurple's Avatar
Originally Posted by avink007 View Post
I was wondering if someone who has one of these could give me the bottom screw hole measurements of the rear pod. Center to center of the screw holes for the motor aluminum side plates front to back and center to center from left to right between the pod plates. Thanks in advance.
These measurements are from my workbench and not the factory:
Motor Plate screw holes: 35.5mm
Mount Plate screw holes: 35.5mm
Bottom Plate attachment holes, side to side: 62mm
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 09-04-2014, 04:51 PM   #1187
haywood's Avatar
Trader Rating: 48 (100%+)
Hey Bubby! I'm trying to see if I can get this pod to work on a different car, I just really like the design of it with the height adjustment. Could you get those dimensions for me? Hope all is well up north.
Aaron had that rear pod on a 12r5. Not sure if you remember that?
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 09-04-2014, 05:43 PM   #1188
Mr. Bubby's Avatar
yeah I do remember that, it worked pretty damn good too!
Schumacher MI6 (SMC Powered) Touring Car
Schumacher KC (SMC Powered) Stock Buggy
No 1/12 scale till they run with rubber tires!!!
Mr. Bubby is offline   Reply With Quote
Old 09-04-2014, 06:09 PM   #1189
Thank you!
avink007 is offline   Reply With Quote
Old 09-04-2014, 06:10 PM   #1190
I remember, that is what has given me ideas to put it on another car.
Old 10-22-2014, 08:35 AM   #1191
pumpkinfish's Avatar
I just picked up a Rebel 12 and getting it ready to race. In the Hanulec setup, I have a few questions. First, is it starting with zero pretension on the side springs? I put the black ones on and it seems like I need about 1.5-2.0mm of pretension to get the springs touching the link. Is this correct? What is the purpose of flipping the sidelinks?
Secondly, I picked up the revised upper arm hinge pin. Does the e-clip go on the front or rear side of the assembly? The TOP site shows it on the front, but when I took my one test drive, the pins seems to slide forward and I would want the clips on the rear to prevent this. So I really don't know what is correct.
pumpkinfish is offline   Reply With Quote
Old 10-22-2014, 09:33 AM   #1192
ByteStream's Avatar
You want the side springs just touching the side links which would mean zero pre-load.
Flipping the side links eliminates the possibility of the spring getting caught up in the "bowl" of the side link.
If I were using the new hinge pins, I would put it on the top to prevent them from sliding down.
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 10-26-2014, 12:09 PM   #1193
hanulec's Avatar
Trader Rating: 27 (100%+)
i can hardly believe there hasn't been any chatter on this thread since Donny's excellent 3rd place qualification at Worlds or Ray D's 2nd place qualification at IIC in 13.5.
i finally got my 1/12th back onto the track yesterday w/ those new style tires. wow -- crazy steering. a few front end changes -- adding 2.0mm to the inner upper camber/caster mount totally made the car turn around.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 10-26-2014, 02:14 PM   #1194
PutAwayWet's Avatar
Okay, I'll bite. I've been fascinated by a couple of things on Donny's car. First, what is up with the ESC? It seems he's drilled locator holes on the chassis and then run them up through the case and to the custom heat sink plate? Is this what I'm seeing?
Second, where's the booster or RX battery? Is it simply removed for the pictures? Would it normally go on the deck next to the receiver? Please explain.
Finally, I've heard in the past that the fast TOP drivers will swap out a couple of front end parts. I believe they it's AE knuckles? I can't tell from these pics whether that's the case. What sort of hand fits are in play here? (If any.)
Oh, and double final. BSR blues front/rear?
Todd Mason
Seattle RC Racers
The world ends when you're dead. Until then, you got more punishment in store.
Stand it like a man, and give some back. --Al Swearengen
PutAwayWet is offline   Reply With Quote
Old 10-26-2014, 03:14 PM   #1195
hanulec's Avatar
Donny's cars have some really nice millwork.
For the ESC -- carbon chassis is milled with the chassis acting as the bottom plate.
Another milling feature is putting a 1/2mm cut into the front arm mount area -- cut for the shorter track width -- to prevent the front end from tweaking after a big hit.
I didn't pay attention to his steering blocks. I run ase 10l/12l. Don't see that changing anytime soon...
Old 10-26-2014, 09:42 PM   #1196
Donny Lia's Avatar
Hey yea guys the chassis was cut to replace the plastic bottom of the case. The pocket that the internals of the speedo sit in is about 2mm in depth. Flex analysis was almost identical to stock once the speedo was tightened down. It works well and the speedo ends up only being 11mm tall. I don't run a booster or Rx pack. Also, I use associated r5 steering blocks. Hope this helps. Any other questions just ask. Thanks
RocheAwesomatixTrinityKoBsrProtoformTQAvidKimbrough
Donny Lia is offline   Reply With Quote
Old 10-26-2014, 11:01 PM   #1197
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
Donny, which esc do you use so you do not have to use a booster?
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 10-26-2014, 11:36 PM   #1198
EDWARD2003's Avatar
LRP FLOW is the speedo!
Donny why did you opt to dun the D3.5 instead of the D4?
EDWARD2003 is offline   Reply With Quote
Old 10-27-2014, 12:37 AM   #1199
avs
avs's Avatar
Interesting integration! how exactly did you 'tighten down' the speedo? if the case bottom is removed there is only a thin edge of the speedo in contact with a mating edge on the main chassis plate. is the speedo attached with shoe goo or ?
(it just occurred to me the case is screwed together, so you could just use the same screws doh!)
Tony Shimko
avs is offline   Reply With Quote
Old 10-27-2014, 05:52 AM   #1200
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Im not Donnie by any means but its because IFMAR requires motors to be out 6 months prior to a worlds to be legal. The D4 wasnt out in time for this or they would have been running the new motor (This is what Ernie had said in an email).
Kinda a silly rule. They allow any type of car, tires, and ESC's but not motors or batteries.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Trains and Lanes Onroad Racing Summer 08 edition t_laible Racing Forum 2280 06-09-2010 01:41 PM
FS: 1/12 Scale, GTB, 9650 Servo, receivers, Setup Station, DPD, Lathe, +more revolution31 R/C Items: For Sale/Trade 27 12-18-2009 11:09 AM
3-10-2007 Trenton Carpet Racing ShaunMac Georgia Racing 10 03-09-2007 01:49 PM
Hampton MN Rc Racing Mark O'Brien Minnesota and North/South Dakota Racing 411 01-04-2007 11:47 PM
