Like Tree4Likes
Old 02-24-2012, 11:48 PM   #916
I think I got all the info needed for the car setup. Special thanks to everyone who helped.
faifaisalfal is offline   Reply With Quote
Old 02-25-2012, 09:02 AM   #917
Originally Posted by faifaisalfal View Post
Hi Infinite 12th,
Thanks for the info. So basically the front droop is mainly by feeling and eyeballing only.
I like to measure front droop two different ways.
The first way is the easiest, and it is what I do when Im at the track and fussing around with the car. First, I will pull off the front bumper and plastic brace thingy, so that I have easy access to the chassis centerline hole.... and so that I see exactly what the ride height is. I use the Hudy pan car gauge with the .2mm increments(it ranges from 2mm to 5mm or so, so it works perfectly for 12ths).
Poke down on your rollover antenna a few times and then roll the car back and forth on the setup board. Compress the suspension again once more, for good measure. Then measure the front ride height with the Hudy gauge. It is important that you are using the gauge with the .2mm increments, otherwise the following process will not work.
As I measure the front ride height, I find exactly where the car sits at static height on the gauge. Then I slowly push the gauge farther under the car, one .2mm step at a time. Lean down to board/car level, and watch as you do this. Continue pushing the gauge under the car, until you see the front tires just start to lift from the ground. Ideally, your car will be tweaked correctly at this point, so both front tires will lift from the ground at the same time.
Take the static front chassis ride height measurement and subtract it from the measurement where the car is currently sitting on the gauge. That will tell you your front droop. Normally, I tend to run .2-.4mm of droop at our local carpet track. So, for example, I will measure the front ride height at 3.4mm with the Hudy gauge. Then I push the gauge under the car little by little, until the front tires lift. The gauge is measuring 3.8mm at this point. So, the front droop is: 3.8 - 3.4 = .4mm.....
It's a pretty simple process really.
The second way I measure droop is by measuring the actual front axle height from the ground. I only do this when I am rebuilding/tweaking the car at home, usually. As a side note, when you assemble and set up the car (and between each race weekend/meeting), you should always be checking that the front axle height matches left to right on the car. If it does not, that is a surefire way to introduce tweak to your chassis.
Just put the car on a totally flat surface, I usually also put it on droop blocks. Then measure the distance from the ground to the very inner part of the front axle... on both sides of the car. You need a set of digital calipers for this. I try to get the front axles equal to within a tenth of a millimeter. Next, jiggle the front steering block until you find the spot where the spring begins introducing resistance. This should be easy to find, but you need to make sure you aren't actually compressing the spring, otherwise your measurements will be off. Raise your calipers from the static height until you feel that initial resistance... the delta between the two measurements is your front droop value.
This way is a little more accurate, but is much more time consuming and more difficult to get correct. I like this method because you ensure that both sides of the car have the same amount of front droop. But, again, I only take these measurements when I have plenty of time to kill at home prepping the car. I generally don't get this involved at the track, unless I had a wreck where I broke some front end pieces... or I suspect I have a collapsed front spring.
Hope this helps a bit.
JamesL_71 is offline   Reply With Quote
Old 02-25-2012, 10:40 AM   #918
Hi James,
thanks for the sharing on the front droop measurement.
Just to double check with you, if let say I want .5mm rear droop, I just take the reading straight from the gauge right? There is no math involve like the front droop measurement.
Old 02-25-2012, 12:51 PM   #919
Hi James,
Yep, just like that. Just adjust the length of the center shock so that the edge of the rear pod is smack between the -1mm and 0mm steps on the droop gauge.
Old 02-25-2012, 10:49 PM   #920
HI James,
thank you very much for all the detailed explanation. I have benefited from it and I'm sure many others will too.
Old 02-25-2012, 11:29 PM   #921
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Run the setup that Hanulec posted. I ran just about that exact setup this weekend at Middle River Hobbies and the car was pretty much untouchable. Please if you have this car and run anything but mod try that setup exactly.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 02-26-2012, 08:08 AM   #922
Larry, do you generally run the middle setting for reactive caster(5*, I believe)? Or is this class and surface dependent?
My buddy and I have been working on our setup for 17.5 blinky and have been running a similar setup to Hanulec's, except we're using 10* RC, slightly stiffer on the side springs, and more pod droop.
Im curious as to what RC setting you would recommend for stock 12th in particular... Thanks.
Old 03-04-2012, 08:09 AM   #923
Hi,
after reading the racer log, I have a question regarding the body shell. I see that the recommended body shell for modified class is the Protoform AMR 12. Is there a reason why this shell is recommended for the modified race? How is it different from Speed 12?
Old 03-04-2012, 10:12 AM   #924
hanulec's Avatar
Trader Rating: 27 (100%+)
Hi,
Speed12 hasn't been popular in competition - no matter the chassis since lipo 1s. It doesn't provide the stability.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 03-04-2012, 06:32 PM   #925
Ok. I already tried the AMR 12. Will try out the other recommended shell soon
Old 03-09-2012, 07:16 AM   #926
Just finished up the Rebel 12 I am going to be running @ the Carpet Nats... wrapped up the wiring and electronic installation last night. Thought I would share a few pics. It isn't anything to write home about, but Im excited to get this car on the track for some testing and shakedown this weekend:
Old 03-09-2012, 07:32 AM   #927
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Thumbs up
Nice ride
Good luck at the Nats
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 03-09-2012, 08:13 AM   #928
hanulec's Avatar
Looks nice
if your running 17.5 blinky u will need a small spur and that one looks big..
Old 03-09-2012, 09:18 AM   #929
Infinite 12th's Avatar
@JamesL_71
Looks really nice James
Lets us know how your doing in qualifying at the nat's
Infinite 12th is offline   Reply With Quote
Old 03-09-2012, 03:09 PM   #930
Thanks fellas.
The spur is a Kimbrough 76t... what Ive always used for 17.5 non-timing.
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 01:46 PM
Trains and Lanes Onroad Racing Summer 08 edition t_laible Racing Forum 2280 06-09-2010 02:41 PM
FS: 1/12 Scale, GTB, 9650 Servo, receivers, Setup Station, DPD, Lathe, +more revolution31 R/C Items: For Sale/Trade 27 12-18-2009 12:09 PM
3-10-2007 Trenton Carpet Racing ShaunMac Georgia Racing 10 03-09-2007 02:49 PM
Hampton MN Rc Racing Mark O'Brien Minnesota and North/South Dakota Racing 411 01-05-2007 12:47 AM
