Like Tree4Likes
Old 01-19-2012, 05:28 PM   #841
Infinite 12th's Avatar
Originally Posted by Josh-n-ya View Post
P.S. can I get his SS# and credit card# as well. Is his house pink or (purple)!!!!!
OD has a stalker again ...lol
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 01-22-2012, 04:51 AM   #842
A couple of quick questions... I picked up the alloy servo mounts the other day. I got them because the info I found on them says that it allows for the servo to be mounted flat. Has anyone done this? It doesn't look like there is enough clearance between the servo mount and the arm for the tabs on the servo.
Second question... I keep breaking parts... a lot. Mostly side links and steering blocks. Are there any option parts available that might be stronger then the stock parts? I'm mostly interested in the steering blocks. Otherwise, I may have to admit that 12th scale just isn't my class.
Delawareguy is offline   Reply With Quote
Old 01-22-2012, 06:39 AM   #843
hanulec's Avatar
Trader Rating: 27 (100%+)
A flat servo can be done easily with top servo tape and shoe goo.
associated steering blocks are pretty sturdy. The best $2 upgrade . Check my wiki for part numbers
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 01-22-2012, 07:35 AM   #844
duggyload's Avatar
Hi Delawareguy
I had the same problem with my rebel . Just boil the parts in water for 5 min and Problem gone (worked for me)
Also to save yourself headaches you should get yourself the associated front camberlink turnbuckles as the rebel ones bend to easy
duggyload is offline   Reply With Quote
Old 01-22-2012, 07:40 AM   #845
ByteStream's Avatar
If you don't want to shoe goo the servo, then CRC vertical servo mounts (3355) with about 3.5mm of shims might work depending on your servo. I use a JR3650, see pic.
I have not broken steering blocks very often but the side links IMO are a weak point in the car. I've got a collection of broken ones from the few of us that run a rebel 12/10. Make sure your battery is straped in tight, it may have the tendency to move into the side links during a hard impact.
To help the situation, I boil the steering blocks and side links in water for 3 minutes, this seems to help quite a bit. Since doing this, theses parts have lasted alot longer.
Hang in there .. it is a good car, and no car is perfect. Just try to avoid the impacts as much as you can.
T.O.P Racing's Rebel 1/12th scale-img_0246%5B1%5D.jpg
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 01-22-2012, 08:16 AM   #846
Thanks for the tips. I've never heard about boiling the parts. I assume that will make them a bit softer? I'll give that a try. I've already put Lunsford axles, turnbuckles and camber links on after bending the stock parts. I'll try the AE blocks as well.
I don't want to shoe goo the servo because I'd be worried that I won't get it in the right spot. I was thinking that the optional servo mount would be an easy fix. Maybe I can shim it to get the clearance that I need.
Old 01-22-2012, 08:22 AM   #847
Are these the AE steering blocks that I want?
http://www.amainhobbies.com/product_...Steering-Block
Old 01-22-2012, 07:51 PM   #848
hanulec's Avatar
http://racerlog.com/wiki/T.O.P._Rebel#Hop-ups
Old 01-22-2012, 08:04 PM   #849
syndr0me's Avatar
Trader Rating: 32 (100%+)
T.O.P Racing's Rebel 1/12th scale-photo.jpg
syndr0me is offline   Reply With Quote
Old 01-22-2012, 08:10 PM   #850
ralph m's Avatar
R/C Tech Charter Subscriber
Trader Rating: 31 (100%+)
If you get those you will also need these.
If you get the steering blocks that Mike recommends, you will also need these or these.
tqwire.com
ralph m is offline   Reply With Quote
Old 01-23-2012, 12:52 AM   #851
I'm using the upgrade servo mounts and a button head I trimmed a little off the lower arm mount for some added space. I didn't like the CRC mounts with added spacers when I saw them.
Independent Racer, J-Spec sand and sealer, Dog hair free since 2011
Dragarcher is offline   Reply With Quote
Old 01-23-2012, 01:55 AM   #852
Anyone know who stocks the Rebel body posts? Mine are getting bent up so it's finally time to swap em out.
Old 01-23-2012, 07:16 AM   #853
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Check out Speedtech RC in So-Cal, he's got them in stock.
http://www.speedtechrc.com/store/ebp...=1017&id=11098
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 01-23-2012, 09:24 AM   #854
MAD916's Avatar
we have them in stock also...
http://www.timezonehobbies.com/store...&cPath=2_26_58
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 01-23-2012, 09:30 AM   #855
Sweet thanks guys!
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Trains and Lanes Onroad Racing Summer 08 edition t_laible Racing Forum 2280 06-09-2010 01:41 PM
FS: 1/12 Scale, GTB, 9650 Servo, receivers, Setup Station, DPD, Lathe, +more revolution31 R/C Items: For Sale/Trade 27 12-18-2009 11:09 AM
3-10-2007 Trenton Carpet Racing ShaunMac Georgia Racing 10 03-09-2007 01:49 PM
Hampton MN Rc Racing Mark O'Brien Minnesota and North/South Dakota Racing 411 01-04-2007 11:47 PM
