Old 12-05-2011, 12:09 PM   #781
ByteStream's Avatar
Originally Posted by odpurple View Post
Anymore news on this?
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 12-05-2011, 01:06 PM   #782
Originally Posted by Infinite 12th View Post
I saw OD having one a couple months back I think he custom made for himself
I would rather have updated V2 steering blocks with titanium axles first though
There are V2 steering blocks? Are they available yet? I want them. Also, what does the upgraded motor mount do for performance? My LHS has them in stock and they look cool.
Delawareguy is offline   Reply With Quote
Old 12-05-2011, 01:11 PM   #783
Infinite 12th's Avatar
There are not yet! That is just what I would like to have updated. I think the motor mount was for small spurs and large pinions like for stock
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 12-05-2011, 01:17 PM   #784
hanulec's Avatar
Trader Rating: 23 (100%+)
Take your existing car, and spin the pack around - that is what this is
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-07-2011, 07:23 AM   #785
racer x 1's Avatar
Trader Rating: 27 (100%+)
can you a few of you guys post some pics of how you wired your cars? i just picked one up and im looking for ideas on wiring it with a tekin and thunder power motor.... thanks
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 12-07-2011, 07:34 AM   #786
racer x 1's Avatar
oh and is anyone balancing the motor pod by itself for the rebel? if so how much shimming does it require?
Matt Bell
Old 12-07-2011, 10:28 AM   #787
hanulec's Avatar
Look for a pic of Larry iic/Halloween classic dominating car..
Balance the pod - no.
Making sure the axle is centered - yes.
Old 12-07-2011, 03:58 PM   #788
Larry Fairtrace
Mine's kinda the opposite
Old 12-07-2011, 11:01 PM   #789
bkspeedo's Avatar
What are people doing when assembling the steering blocks on the king pin? Are you reaming the hole so the steering block slides freely or drilling a hole in the side and set screwing the block to the pin so it does not slide like the WGT car?
Replacing with an Associated steering block is not preferred.
I don't personally own a Rebel I'm asking for a friend.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
bkspeedo is offline   Reply With Quote
Old 12-11-2011, 09:44 PM   #790
Default Learning about the Top Car
My rear pivot seems to flop to one side or another like there is a grove or something not letting it settle to the middle. This might explain how it doesn't seem to shoot too straight or why it's so twitchy. How do I fix it? Replace?
Actually I disconnected the links and it isn't the pivot. What about the links is making it do this. They are very free. Is there a link worn out part. Should I replace the links. What is going on? Anyone?
When I only connect one link it works fine only when both links are connected
Ok I fiddled around a bit and seems when you loosen the two screws to the left and right of the pivot that mounts the pivot to the chassis and pull it towards the pod as it is tightened it does not act weird but when I push it towards the chassis and tighten the two screws it totally will not sit free but to one side or another
I am new to link cars
Old 12-11-2011, 11:31 PM   #791
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
That is how you adjust the center football, with both links connected it should be silky smooth.
You need to adjust the football with the 2 screws that mount it to the chassis.
This is link car 101 stuff, where is O.D. he should have walked you thru this already.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-12-2011, 12:11 AM   #792
O.D. has been sick and on the down low
Thanks Link Professor
Old 12-12-2011, 07:35 AM   #793
Josh-n-ya's Avatar
Trader Rating: 72 (100%+)
You could of asked anyone at our track about that!
Josh-n-ya is offline   Reply With Quote
Old 12-12-2011, 09:32 AM   #794
lol...But I didn't notice till I got home and re-built my Rebel
Old 12-12-2011, 09:47 AM   #795
L.Fairtrace's Avatar
Send a message via AIM to L.Fairtrace
This happens very often with link cars. if you hit something really hard you should take everything off the pod plate. And then check it. With nothing on the pod plate (just graphite) it should transitiion from left to right smoothly and fall under its own weight.
Always check this with everything off the pod because it will be much easier to tell this way.
If your car is ill handling or your side springs look all messed up this is the first thing you should check. Then move onto other places.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9055 02-23-2017 03:26 PM
Trains and Lanes Onroad Racing Summer 08 edition t_laible Racing Forum 2280 06-09-2010 01:41 PM
FS: 1/12 Scale, GTB, 9650 Servo, receivers, Setup Station, DPD, Lathe, +more revolution31 R/C Items: For Sale/Trade 27 12-18-2009 11:09 AM
3-10-2007 Trenton Carpet Racing ShaunMac Georgia Racing 10 03-09-2007 01:49 PM
Hampton MN Rc Racing Mark O'Brien Minnesota and North/South Dakota Racing 411 01-04-2007 11:47 PM
