Like Tree1Likes
Old 11-16-2011, 12:50 PM   #751
i am new to 12th scale this season. purchased the rebel with no local intel put it on the track and loved it with the standard set up. cant wait to play with set up in search of the ultimate Rebel! my local track has brand new ozite carpet any set up and tire tips will be much appreciated. thank you
automagic302 is offline   Reply With Quote
Old 11-16-2011, 12:53 PM   #752
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
There are setups posted in this thread, if you look back a page or two.
Also http://racerlog.com/wiki/T.O.P._Rebel#Setups
For more info on overall 12th scale info look HERE
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 11-17-2011, 11:48 AM   #753
Hi Larry. You have a PM
Jeremy Otis is offline   Reply With Quote
Old 11-17-2011, 12:52 PM   #754
godzukihop's Avatar
Trader Rating: 31 (100%+)
You want a tip? After the straight, don't make the right hand turn go straight and give others a chance FAST GUY!!!!
JOHN's MOBILE RACEWAY | 180 RACEWAY | Jackson RC Track
Murnan Modified because HP is intoxicating!!! | VP RACE FUEL |
G-FORCE HOBBIES | Fordham Hobbies | ASHFORD HOBBY | TEAM CAMDEN
RC AMERICA / XRAY / HUDY / TEAM POWERS
godzukihop is offline   Reply With Quote
Old 11-17-2011, 06:21 PM   #755
Josh-n-ya's Avatar
Trader Rating: 72 (100%+)
I used this link before! It has some good stuff in it. I used the associated stearing blocks mentioned in the front end section. It makes the front end less wobbly. I did not have to sand down the stearing blocks because I had got the newer lower A arms. I actually had to add shims under the A arms to get my (ride height right). Say that three times fast.
Josh-n-ya is offline   Reply With Quote
Old 11-18-2011, 06:43 AM   #756
great thanks for the help. looking forward to trying some changes. the axles titanium threaded axles are they the BSR axles listed previously in the thread? not a fan of chasing e clips across the pits!!!
Old 11-18-2011, 09:11 AM   #757
ByteStream's Avatar
Figured I'd share a tip
Dubro #2107 - 2mm flat washers fit really nicely as castor shims instead of the small black plastic clips. 4 on each side and they come in a package of 8 for about $1. They are about .75mm thick.
I run them on the WGT car as well:
For a pic, post #64
T.O.P. Racing Rebel 10 World GT
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 11-19-2011, 09:48 AM   #758
How can I tell if my diff is set correctly? I just had a diff problem with another car and I don't want it to happen again with my Rebel. Thanks.
Delawareguy is offline   Reply With Quote
Old 11-19-2011, 12:19 PM   #759
Infinite 12th's Avatar
As free as possible without slipping
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 11-19-2011, 11:37 PM   #760
Default Front springs
Hi
What are you using of brand and hardness as front spring. I have until now been using the Top gold ones , but they seems to collapse , they are 6,2mm long as new , but last night my car was behaving very strange , and the were only 5,5mm long.
Thanks in advance
Michael
Denmark
johnsen-dk is offline   Reply With Quote
Old 11-19-2011, 11:39 PM   #761
Originally Posted by johnsen-dk View Post
Hi
Thanks in advance
Michael
Denmark
Honestly most use associated .020 for many years
Old 11-20-2011, 06:21 AM   #762
hanulec's Avatar
Trader Rating: 24 (100%+)
Hi
Thanks in advance
Michael
Denmark
it doesn't matter who makes the springs -- they will collapse as you run them. you just need to keep on shimming them so that your kingpins have equal quantity of droop left to right.
based upon the testing done by Fairtrace, the entire line of TOP 1/12th front springs appear to be lighter than the Associated 1/12th 0.020 spring.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 11-20-2011, 06:56 PM   #763
MikeXray's Avatar
Trader Rating: 73 (100%+)
Ran the car again today, still with 17.5 blinky, which is slow at this track, will work on 13.5 boosted now, just need to get the right tires. Car was a lot smoother than the last time I ran at the same track, switched to bsr and replaced my kingpins, pivotballs. The car drives really well an carries great corner speed.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 11-20-2011, 07:39 PM   #764
Yes and I think the silver are just slightly stiffer than .018?
So I think all the TOP springs are are between .018 and 0.020 which is kinda neat if one we're to really want fine tune front stiffness?
Old 11-24-2011, 04:10 AM   #765
I drove my Rebel for the first time last night in practice. So far I really like it. I still need to work on set up but it seems to handle well as it is. Plus is seems really durable and since I drive like a gorilla that's a good thing. My only concern is that the motor appears to move out of position pretty easily. Is there something I can do to make sure it stays in place... other than not crash?
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9055 02-23-2017 03:26 PM
Trains and Lanes Onroad Racing Summer 08 edition t_laible Racing Forum 2280 06-09-2010 01:41 PM
FS: 1/12 Scale, GTB, 9650 Servo, receivers, Setup Station, DPD, Lathe, +more revolution31 R/C Items: For Sale/Trade 27 12-18-2009 11:09 AM
3-10-2007 Trenton Carpet Racing ShaunMac Georgia Racing 10 03-09-2007 01:49 PM
Hampton MN Rc Racing Mark O'Brien Minnesota and North/South Dakota Racing 411 01-04-2007 11:47 PM
