Like Tree4Likes
Old 10-29-2011, 06:37 PM   #706
Dread Pirate's Avatar
Trader Rating: 15 (100%+)
Interesting looking car, but where can you buy one and get parts?
Not at Tower, Stormer, Speedtech, Ampdraw, A-Main, Horizon, LHS, TOP's own site, etc. Not out of stock, but don't even carry it.
"We face each other as God intended. Sportsman-like. No tricks, skill against skill alone." -Fezzik
Dread Pirate is offline   Reply With Quote
Old 10-29-2011, 09:31 PM   #707
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Talk to OD aka Mike O'Donnel at topracingusa.com
topracingusa@yahoo.com
650-583-8898
More info on the 12th scale page
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 10-29-2011, 09:36 PM   #708
skypilot's Avatar
Trader Rating: 14 (100%+)
the info on the previous page might have some answers.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 10-31-2011, 09:35 AM   #709
hanulec's Avatar
Trader Rating: 27 (100%+)
Update from the Halloween Classic ..
Larry Fairtrace TQ and Wins 13.5 boosted 1/12
Mike Hanulec sets the fastest "real" lap in 1/12 stock Amain (before blowing out of 3rd pace in attempt to catch back up to the leaders)
First time 1/12 races do well with the Rebel 12 - Arvin Nano in the B-main and Mike Larcher in the stock C-main
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 10-31-2011, 11:55 AM   #710
Infinite 12th's Avatar
Default Hi
I didn't see these optional spacers in any setups
Do you TOP guys ever use them and how thick are all three of them for both?
Thank you
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 10-31-2011, 01:08 PM   #711
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Thank you
Thanks FJ.
I love my Rebel. Its just unbelievable .
I checked over the setup on Fj's wiki and it looks just about perfect.
We were not using the optional spacers. Putting the lowered arms on the car flattened out the upper link because it lowered the outer part of the upper arm.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 10-31-2011, 01:34 PM   #712
duggyload's Avatar
Default Steering problem
What is the best way to get less steering (slow coming out of corner on power) and more steering (high speed off power going into corner)
Car spins out coming out of the corner on power and wont turn in off power going into corner
Car has kit setup appart from blue side springs(crc)about 0.2mm above the links, blue centre spring (crc)
30000 damper lube associated 35 oil in centre shock , upper arm mount position is in the upper position , 4mm spacer under rear of shock mount
and no droop in the rear 0 deg camber on front wheels
32 shore rears and 40 shore fronts
This is a very low traction track
Any help would be greatly appreciated
duggyload is offline   Reply With Quote
Old 10-31-2011, 01:58 PM   #713
Obviously there is a general lack of mechanical grip on a low traction track.
So if you're running magenta type 32 rear tires, you might want to try Yellow instead, this is a Synthetic tire, and with some outdoor tracks it will have a lot more grip than a magenta or pink.
Black front tires may help with turn in as well.
I'm sure there is some tuning that could help, like less caster, more droop, soft side damping & springs and such.
But tires can make a huge difference, with minimal tuning.
Old 10-31-2011, 09:26 PM   #714
CypressMidWest's Avatar
Larry was unbelievable all weekend. Both car and driver were near perfect!
Great run Mr. Fairtrace.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 10-31-2011, 09:38 PM   #715
It be nice to see some pic's of his car
Old 10-31-2011, 11:00 PM   #716
Bob-Stormer's Avatar
I don't think this will come across as spammy, so here you go.
Stormer Hobbies will be carrying the parts (every last part). We started with the cars, parts should be trickling in.
I personally like the car, and that's how that all happened. I suspect you'll see me at a few onroad races this winter with a Rebel. So we'll definitely be carrying parts. ...lol...
www.stormerhobbies.com "Where the world shops for radio control."
www.facebook.com/stormerhobbies
www.twitter.com/stormerhobbies
looking for....vintage 1/10-1/12 pan, need Schumacher 1/12th cars and parts.
Bob-Stormer is offline   Reply With Quote
Old 10-31-2011, 11:03 PM   #717
Cool, that should help push out a few more kits !
Old 10-31-2011, 11:09 PM   #718
Looks like were also stocking the rebel 10 and the oval car. I think when I talked to Mike, I decided we'd wait for the newer Photon before doing more with the TOP touring stuff. Likely get the parts that crossover though, so we'd have those ahead of time.
Fairtrace,
you running the 10th car? I'm willing to give one a shot. Fun to be different, and it would seem they can haul the mail, so that helps.
Old 11-01-2011, 08:15 AM   #719
Thank you. That is always encouraging.
I will post some later tonight when I get home from work.
Fairtrace,
Thats great news Bob. Should help get the car out there more.
I have not run the WGT car, I may get one soon to give a try but I have my hands full with TC and 12th scale at bigger races. The WGT might just be fun to run at our local track to put down traction.
Ej's was pretty good at the IIC for never running it on carpet before.
Old 11-01-2011, 08:49 AM   #720
Besides Larry and FJ think WGT is for the "old guys" and I'm o.k. with that.
Larry great win!
Independent Racer, J-Spec sand and sealer, Dog hair free since 2011
Dragarcher is offline   Reply With Quote
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Trains and Lanes Onroad Racing Summer 08 edition t_laible Racing Forum 2280 06-09-2010 01:41 PM
FS: 1/12 Scale, GTB, 9650 Servo, receivers, Setup Station, DPD, Lathe, +more revolution31 R/C Items: For Sale/Trade 27 12-18-2009 11:09 AM
3-10-2007 Trenton Carpet Racing ShaunMac Georgia Racing 10 03-09-2007 01:49 PM
Hampton MN Rc Racing Mark O'Brien Minnesota and North/South Dakota Racing 411 01-04-2007 11:47 PM
