Like Tree1Likes
Old 10-25-2011, 12:21 PM   #676
ByteStream's Avatar
Originally Posted by jmellipse View Post
Just building this kit. It's looks very nice and the fit is perfect. One thing I noticed is that the steering block don't lay flat on the king pin balls without some modification, strange.
2 things I have to ask:
Do I need to make the hole in the steering block larger to fit the optional wheel axle with nut ? It is larger and doesn't really fit, I'm afraid that if I force it they will break.
Also, why are there 2 rubber O-rings with the optional pod plates/axle carrier ? There are four screws, so what to do with the rings ?
The optional front wheel axles w/nut are meant to be pressed into the plastic steering blocks. Use a vise to gently press them in.
No clue what the o-rings are for on the optional motor plate.
ByteStream is offline   Reply With Quote
Old 10-25-2011, 01:16 PM   #677
odpurple's Avatar
If you look on the motor side of the motor plate you will see that the screw slots are recessed for the o rings. You put the o rings on the screws and they keep the motor screws in place when the motor is out
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 10-25-2011, 02:05 PM   #678
jmellipse's Avatar
Funny, I was just thinking why the recessed slots where on the motor site. I thought about it holding the screws but decided that would never be the case. Learn every day ;-)
jmellipse is offline   Reply With Quote
Old 10-25-2011, 02:40 PM   #679
CypressMidWest's Avatar
That's just brilliant. I can't believe that nobody's thought of this until now.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 10-25-2011, 03:10 PM   #680
I'm thinking about getting a T.O.P Rebel. How easy is it to get parts for these? I haven't found many places that carry them. How do these compare to the cars from AE and CRC? Thanks for your help.
Delawareguy is offline   Reply With Quote
Old 10-25-2011, 03:36 PM   #681
Trader Rating: 17 (100%+)
Parts are easy to get. If your LHS doesnt carry them you can call/Email T.O.P. and they will have what you need to you in a couple days. As for comparing to the AE or CRC. There are a lot of 12th scales in my area. I really dont see any AE's. There are a lot of CRC's but the Rebel is right there with them!
T.O.P Racing USA
"This T-bird will put a spell on you"
Mr.A Morris is offline   Reply With Quote
Old 10-25-2011, 05:30 PM   #682
Infinite 12th's Avatar
@Delawareguy
Michael O'Donnell is great with seeing you get what you need if you can't find it elsewhere
topracingusa@yahoo.com
@Top Dudes
Curious Top guys what spacing (mm) do you have between steering block and top arm?
Thank you
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 10-26-2011, 05:06 PM   #683
Just picked up a TOP today. I was wondering if there any tips for the build process. Any common mistakes that I should try to avoid?
Old 10-26-2011, 05:11 PM   #684
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
I'd recommend polishing the rear pivot balls and king pins. Also take extra time to make sure the rear side links and center pivot are silky smooth and free.
You my want to use use this setup as your base setup.
http://www.racerlog.com/w/images/8/8...-175blinky.pdf
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 10-26-2011, 05:13 PM   #685
Grenade10's Avatar
Trader Rating: 37 (100%+)
Check out this site http://racerlog.com/wiki/T.O.P._Rebel#Setups
Avoid letting it sit on the shelf!!!!!
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 10-26-2011, 06:16 PM   #686
hanulec's Avatar
Trader Rating: 24 (100%+)
good question - but i don't know the answer. since the car came out and had somewhat high arms people have been running different steering blocks -- and just haven't gone back yet. i suspect after this weekend folks will have a little more time to play around w/ different steering blocks. until then i can only recommend -- Associated ASC8421 -- 10l/12l offset steering blocks.
OD - how do you have your steering blocks configured??
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 10-26-2011, 07:30 PM   #687
I'm actually having problems with this. The center pivot ball seems fine but the side links seem like they are binding. I keep loosening the screws but it doesn't seem to be making much difference. This might be a dumb questions but how do you polish the pivot balls? How "floppy" should the chassis feel at this point?
Old 10-26-2011, 07:30 PM   #688
MikeXray's Avatar
Trader Rating: 73 (100%+)
I have 1mm under and 3mm above the stock knuckle.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 10-26-2011, 07:47 PM   #689
Thanks dude
Old 10-26-2011, 09:37 PM   #690
Default Stock knuckles
Hi
Until last sunday I have been using stock knuckles with 0.5mm under and 4 mm over. But kept getting understeer and a wheel shattering. Then I broke my last knuckle , and put on IRS Asso knuckles. I have now a super steering car. The stock knuckles are to thin in my oppinion , only 6mm , and the IRS are 10-11mm , that mean that there are a lot more control on the kingpin.
johnsen-dk is offline   Reply With Quote
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9055 02-23-2017 03:26 PM
Trains and Lanes Onroad Racing Summer 08 edition t_laible Racing Forum 2280 06-09-2010 01:41 PM
FS: 1/12 Scale, GTB, 9650 Servo, receivers, Setup Station, DPD, Lathe, +more revolution31 R/C Items: For Sale/Trade 27 12-18-2009 11:09 AM
3-10-2007 Trenton Carpet Racing ShaunMac Georgia Racing 10 03-09-2007 01:49 PM
Hampton MN Rc Racing Mark O'Brien Minnesota and North/South Dakota Racing 411 01-04-2007 11:47 PM
