Like Tree4Likes
Old 10-10-2011, 09:55 PM   #661
artwork's Avatar
Trader Rating: 59 (100%+)
Originally Posted by johnsen-dk View Post
Hi
Can anyone explain why you place the servo laying down and the front narrow. I race the front wide and the servo angled. I know it's depend on the track, but please explain the difference
Michael
It is all about tire offset. Narrow for BSR and CRC tires and wide for Jaco and Parma.
Flat servo helps lower the CG in the car and I think make the steering feel more consistent. If you run it flat remember to get the bump steer correct. Links pretty flat I am running 4mm of bumpsteer with the lowest holes on the servo saver.
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 10-16-2011, 01:19 PM   #662
hanulec's Avatar
Trader Rating: 27 (100%+)
I just through together a setup sheet with my 1/12th 17.5 blinky setup from IIC. The car was far superior to my driving that week -- unfortunately. Check it out at -
http://racerlog.com/wiki/T.O.P._Rebel#Setups
Yesterday I ran the same car setup in 13.5 boosted, but with some larger tires, swapping to BSR Magenta Fronts and BSR Pink Rears and a 80t spur.
I've updated some of the other data about tire sizes/etc on the Rebel wiki too - http://racerlog.com/wiki/T.O.P._Rebel
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 10-17-2011, 05:53 PM   #663
odpurple's Avatar
Nice job Mike, thanks for posting
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 10-17-2011, 06:37 PM   #664
hanulec's Avatar
No problem OD. I wonder how many more 4th place finished I can pull off this year . All joking aside, the car performed much better than me. I think the guy running 13.5 w/in the 17.5 class really threw us all off as we struggled all week to come to grips with his straightaway speed.
Thankfully there is always next race... (which might be the Halloween Classic... some of us are 50/50 if we are going to go right now. should know by tomorrow or wednesday...)
Old 10-17-2011, 08:17 PM   #665
odpurple's Avatar
I's amazing how something like that can get in your head (the 13.5 guy). Don't worry, I'm sure you have many more 4th place finishes in you!
Next big race for us will be the Timezone Grand Prix in November. Way too soon IMO as I am still sleeping off the IIC
Old 10-17-2011, 09:49 PM   #666
Infinite 12th's Avatar
Just got my 12th and what a great kit
I was looking at my steering blocks and it is possible I have two left one's or right one's?
They look identical
I say this cause the bevel looks different in the top and bottom of steering block
So just curious if anyone noticed what I am noticing
Also please would someone list the hard to soft with springs
Side springs - hard to soft - colors, etc
ft springs - hard to soft - colors, etc
Shock spring - hard to soft - colors, etc
Thank you team Top
Take care
p.s. Only need Speedo and some tools and I'll be racin at Norcal
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 10-18-2011, 06:42 AM   #667
Come on FJ. You can do better than 4th.
Hope you can make it to the Halloween Classic. I might need some help. I'm running 13.5 boosted with my Rebel. Arvin and I are riding out together.
Are you making the trip down to Middle river this weekend since Horsham is closed?
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 10-18-2011, 07:05 AM   #668
They look identical
They are (or at least were when I got my kits last year), you have to dremel them down to make them fit properly.
Not sure if there are updated arms available now though ?
CPD Racing
chris_dono is offline   Reply With Quote
Old 10-18-2011, 09:22 AM   #669
Luppi Stefano's Avatar
someone have a good setup for Mod Class?
thanks
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 10-18-2011, 10:01 AM   #670
Ok
thanks
Probably best to state what surface your on
Old 10-18-2011, 02:34 PM   #671
odpurple's Avatar
They look identical
Thank you team Top
Take care
The steering blocks are the same side to side, don't worry about the bevel. I've built several R12s and not had to dremel any thing on the blocks to make them fit, not sure what that is about.
V2 arms have been out for some months now.
The springs all show the wire diameter and number of turns on the header card and you can tell the relative stiffness from that. They go like this, from soft to stiff:
front: copper, silver (kit), gold
side: black, copper(kit), silver, gold
shock: black, copper(kit), silver, gold
Old 10-18-2011, 03:55 PM   #672
Old 10-18-2011, 06:23 PM   #673
hanulec's Avatar
Hey Steve - we made some last minute moves right around noon today -- I convinced Larry and Jerry to come out to the race too. I don't think you'll find any of use at Middle River this weekend. I'm going to rest up for the epic adventure to Cleveland Friday after work. See you before 7am Saturday morning. If you wanna talk about your 1/12th prior to the race give me a ring...
-FJ
Old 10-19-2011, 09:37 AM   #674
Ok
Carpet, of course!
Lab F1-01
Old 10-25-2011, 11:32 AM   #675
jmellipse's Avatar
Just building this kit. It's looks very nice and the fit is perfect. One thing I noticed is that the steering block don't lay flat on the king pin balls without some modification, strange.
2 things I have to ask:
Do I need to make the hole in the steering block larger to fit the optional wheel axle with nut ? It is larger and doesn't really fit, I'm afraid that if I force it they will break.
Also, why are there 2 rubber O-rings with the optional pod plates/axle carrier ? There are four screws, so what to do with the rings ?
jmellipse is offline   Reply With Quote
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Trains and Lanes Onroad Racing Summer 08 edition t_laible Racing Forum 2280 06-09-2010 01:41 PM
FS: 1/12 Scale, GTB, 9650 Servo, receivers, Setup Station, DPD, Lathe, +more revolution31 R/C Items: For Sale/Trade 27 12-18-2009 11:09 AM
3-10-2007 Trenton Carpet Racing ShaunMac Georgia Racing 10 03-09-2007 01:49 PM
Hampton MN Rc Racing Mark O'Brien Minnesota and North/South Dakota Racing 411 01-04-2007 11:47 PM
