Like Tree4Likes
Old 07-17-2011, 06:37 PM   #541
clinehobbies's Avatar
How do you set tweak with BMI side t-bars?
clinehobbies is offline   Reply With Quote
Old 07-17-2011, 11:51 PM   #542
Josh Cyrul's Avatar
"I understand your point, but like i said i spent hours trying both at the track and the plates yield a faster and more consistant lap times than the spring. I know the car was design with the springs but im pretty sure the graphite plates were never tested by the designer. Like I said Im just trying to get The Rebel faster and more consistant at the track and hope to keep getting it in the Amain and maybe a few wins !! Isnt that what we all want? Instead of knocking down ideas how about trying and testing your self and see what results you get."
Nope...lol... I never tested the plates like this (at least on a 1/12 car). If Jason is going longer with the graphite plates then I am sure the spring rate will be closer and it should work well. In the past, the short plates (I believe) get too stiff, too quick. The only thing to watch now is the degrading of the graphite over so many runs as the fibers will break down and get softer over time (like a t-bar did).
Jason - Don't sweat it!! Larry has kicked me around a bit too the past few years since I was fired from TOP with the new products I've made - While he still drives everything I've drawn (and even graphite I've cut..lmao).
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 07-18-2011, 01:52 AM   #543
Most 1/12th setups these days will balance the chassis so that all you do is tighten the springs down until they touch and not actually set tweak. So long as the chassis is properly balanced it won't be tweaked...However that is one of the nice things about a spring setup is you can make a tweak adjustment for a quick fix.
Old 07-18-2011, 03:15 AM   #544
protc3's Avatar
Hey Josh,
I am trying the longer plates for 2 reasons to be honest and both are for the reasons you are saying. I wanted a more linear spring rate and less movement of the plate to increase the life of the plate. They do last much longer than T bars as they dont even come close to experiencing the twisting loads of the T bar but like you say, they will break down over time. I have been running the same set since the birds so they are really lasting long and still not showing signs of fatigue. The longer ones seem to be working out very well so far.
Too funny, people are so quick to talk smack aren't they. I get such a kick out of it. Oh well, maybe we will be driving the cars they design soon and we can pull some flip mode on them. Talk to you soon brutha.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 07-18-2011, 03:17 AM   #545
protc3's Avatar
We are changing things up a bit but i really dont want to clog the Top thread with BMI stuff so if anyone wants any info, please PM me or we can discuss on the CH12 thread. Thanks guys.
BTW, thanks for the support guys.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 07-18-2011, 10:29 AM   #546
Is the Rebel coming with the new motor pod plate and rear brace or is that going to remain an option part?
Old 07-18-2011, 10:47 AM   #547
Super Moderator
Marcos.J's Avatar
Trader Rating: 180 (100%+)
they have one for mod
Old 07-18-2011, 01:07 PM   #548
odpurple's Avatar
The new motor plate set will not come in the kits and will remain an option. It was designed to allow the use of smaller spur gears when running mod motors. The original design by Josh is very open, has a low center of gravity and has proven to work very well on the Rebel, not to mention the CEFX car, so there are no plans to discontinue it
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 07-18-2011, 02:14 PM   #549
Ah ok cool...Eventually I'd like to pick one up just because I'm a 1/12th scale nut and have some design ideas of my own I'd like to try out but don't have machining equipment so I'll have to use pod plates from other cars for testing.
Old 07-18-2011, 03:05 PM   #550
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Cool
Hey O.D.
What's up.
Normally we run LARGER Spur gears for mod.
Perhaps you meant to say smaller pinions ?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-18-2011, 03:44 PM   #551
odpurple's Avatar
Originally Posted by RedBullFiXX View Post
Hey O.D.
What's up.
Hi Dave
Ya, I know that of course but wasn't very clear. It sounded right at the time
What I meant was that the slot at the bottom of the motor plate for the motor screws does not go back far enough to make mesh between the pinion and spur when using the small pinions you would use for mod. So for some roll outs you have to run a larger spur gear than you might want to. The option motor plate solves that issue.
I really like the stock motor plates and since we run gigantic pinions in every class but mod now getting mesh is not a problem
Now I'd better go check all the emails I sent this morning and see if they were also clear as mud
Old 07-18-2011, 03:52 PM   #552
Has anyone noticed any back to back handling differences with the std low, and optional motor mount?
There has been some discussion that the std low allows the motor to flex independantly of the pod, generating more rear grip, and a more consistent car.
The scratches on the sensor end of the motor only would seem to support the idea that the motor can flex a fair way.
I have not had a chance to try it myself, however a mate tried it, and felt like he had a lot less rear bite.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 07-18-2011, 07:06 PM   #553
Hi Dave
Just bustin your balls O.D.
You racing IIC ?
Old 07-18-2011, 09:21 PM   #554
odpurple's Avatar
You racing IIC ?
OW!
This will be my 7th IIC, wouldn't miss it
Old 07-18-2011, 11:03 PM   #555
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Od,
Just picked up a Rebel 1/12th. I have a Question about the front springs. Which ones are equal to Associated .018 and .020 1/12th springs? I noticed that these spring have more coils are these springs Linear?
Im going to place and Order soon so i can get the right parts
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Trains and Lanes Onroad Racing Summer 08 edition t_laible Racing Forum 2280 06-09-2010 01:41 PM
FS: 1/12 Scale, GTB, 9650 Servo, receivers, Setup Station, DPD, Lathe, +more revolution31 R/C Items: For Sale/Trade 27 12-18-2009 11:09 AM
3-10-2007 Trenton Carpet Racing ShaunMac Georgia Racing 10 03-09-2007 01:49 PM
Hampton MN Rc Racing Mark O'Brien Minnesota and North/South Dakota Racing 411 01-04-2007 11:47 PM
