Like Tree1Likes
Old 06-02-2011, 08:35 PM   #481
Originally Posted by RC MARKET View Post
TOP Released Option Motor Mount la !
That would be right, after 4 days of issues with my address, the new parts arrive the day after my order is shipped
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 06-06-2011, 03:51 PM   #482
Ok I have acquired a rebel but have no instruction manual and new to 1/12 scale. I need a rear axle the one I have has a slight woble driver side rear and the screws for mounting the rear wheels. Could someone gives me some part numbers . If a CRC axle will fit a part number for it would be good to. Thanks
JETT is offline   Reply With Quote
Old 06-06-2011, 04:00 PM   #483
theisgroup's Avatar
I guess driver side would depend on what side of the pond you reside. The crc axle would fit, but your prob is that the screws to mount the wheels would now be standard and not metric. If you are talking the clamping side that wobbles, it could be the clamping hub. For me, I would stick with the top parts
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 06-06-2011, 09:03 PM   #484
tpczx6's Avatar
RcAmerica--Xray---Hudy----KO PROPO USA---ORCA---GRAVITY RC
Motiv------Apexrc----- AVID
SWEEP Racing USA
Mike's Hobbyshop in Dallas (RIP)
Nor-Cal Hobbies [The Race Place]
tpczx6 is offline   Reply With Quote
Old 06-06-2011, 09:12 PM   #485
TOP
REBEL 10 & 12 New Product Coming Soon !
Why are the motor screw slots machined for the screw head on the motor side of the mount?
Old 06-06-2011, 09:59 PM   #486
mike ivy's Avatar
Trader Rating: 50 (100%+)
My Guess the pod plate is thick, or to better hold the washer for the motor screw? I could be wrong it was just a guess.
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 06-06-2011, 10:55 PM   #487
No...my point is the indentation is on the wrong side of the motor mount...it faces in toward the motor. Not having the indentation would give more surface contact between the plate and the motor for better heat dissipation and less chance of the motor shifting in an impact.
Old 06-06-2011, 11:08 PM   #488
I cant recall the indent, however i would think it is eaither to allow the load to be spread more evenly, or on some cars there has been a provision to out a small oring on the motor side of the motor screws to stop them from falling out when removing the motor.
Old 06-06-2011, 11:09 PM   #489
Just het a CRC axle set, the kit hubs are shite, alloy is soft, and the 2.5mm screws just plain SUCK.
Just use an extra bearing to space out the LHS hub to the correct spacing.
Old 06-06-2011, 11:59 PM   #490
RC MARKET's Avatar
You had order in our co. ?
Please pm your order no.
& Your address problems so was delay arrive !
but you was received !
Thanks !
RC MARKET is offline   Reply With Quote
Old 06-07-2011, 03:45 AM   #491
Thanks !
Yeah, all is good now, order received yesterday, just frustrating to see something available the day after the order was shipped. Just bad timing on my behalf.
Old 06-07-2011, 06:28 AM   #492
avs
avs's Avatar
the clamping hub gets out of true without too much trouble. a not very spectacular crash and the wheel has about 1.5 to 2mm runout.
i like the arrangement, the screw is easy to access but the hub could use a larger fillet (my $0.02)
Tony Shimko
avs is offline   Reply With Quote
Old 06-07-2011, 07:36 AM   #493
RC MARKET's Avatar
OK No problem !
Old 06-07-2011, 10:31 AM   #494
The load would be better spread with more surface area...as for an o-ring to keep the motor screws in...that's a gimick I could do without.
Old 06-07-2011, 10:54 AM   #495
Grenade10's Avatar
Trader Rating: 37 (100%+)
If it is on the left, non gear side it is probably the clamping hub. I had to machine mine, as it gets off square when you clamp it to the axle. Did not take much to clean it up on the lathe, just need a to have a shaft the same dia as your carbon axle (yes there are some tolerance in these) clamp it to the axle and then cut the mounting face until you just kiss all the surfaces. Red anodize is a good "Guide Coat".
T.O.P Racing's Rebel 1/12th scale-rebel-12-machined-hub.jpg
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9055 02-23-2017 03:26 PM
Trains and Lanes Onroad Racing Summer 08 edition t_laible Racing Forum 2280 06-09-2010 01:41 PM
FS: 1/12 Scale, GTB, 9650 Servo, receivers, Setup Station, DPD, Lathe, +more revolution31 R/C Items: For Sale/Trade 27 12-18-2009 11:09 AM
3-10-2007 Trenton Carpet Racing ShaunMac Georgia Racing 10 03-09-2007 01:49 PM
Hampton MN Rc Racing Mark O'Brien Minnesota and North/South Dakota Racing 411 01-04-2007 11:47 PM
