Like Tree1Likes
Old 04-21-2011, 06:47 AM   #451
theisgroup's Avatar
Originally Posted by L.Fairtrace View Post
I would love to get a couple sets of these.
oh yeah. Mr. Tamale, I need 2 set for a buddy of mine. lol
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 04-21-2011, 02:08 PM   #452
Originally Posted by team_tamale View Post
How many of you Rebel owners are interested in lowered steering blocks? I know they are supposed to be reworking the molds for the lower arms. The few that I have made so far will accept the stock axles as well as the threaded axles.
Hey, Larry!
I'm good for at least 3 pair.
Thanks for doing these for us!!
Crashby is offline   Reply With Quote
Old 04-21-2011, 02:15 PM   #453
theisgroup's Avatar
Originally Posted by Crashby View Post
Hey, Larry!
Crashby, these are aluminum and don't break. So you do not need spares. Lol
yang lai
Old 04-21-2011, 02:34 PM   #454
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
Originally Posted by CypressMidWest View Post
That you like to have spares on hand... jeez.
Filo needs spares. Heard he Zero turned another 8th scale at worlds.
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 04-21-2011, 09:00 PM   #455
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
What is the smallest front tire size @ 3mm ride height with this new steering block?
OVA is offline   Reply With Quote
Old 04-22-2011, 02:07 PM   #456
Why do you think they call me crashby?!?! I have two built Rebels and I am sure that another racer at the track will want a pair. Gotta keep 1/12th racers alive!
Old 04-22-2011, 06:08 PM   #457
For all of you that would like to have the lowered steering blocks, shoot me an email at teamtamale@tx.rr.com. I didn't make a large run this time as I know they will eventually get the lower arms changed. I will be starting up some more in the next couple of days. Also, the amount these have been lowered is .625mm. This will allow a 1.2 mm smaller tire to be run and maintain the same ride height.
team_tamale is offline   Reply With Quote
Old 04-26-2011, 11:49 AM   #458
Grenade10's Avatar
Trader Rating: 37 (100%+)
Things that I have done to my Rebel 12 that may help others:
: Cut the front bumper so that the transponder fits in front of the cross brace
: Trim Associated camber shims to replace the clips. Takes 5 clear ones
: If you are carefull and spend some time, you can balance the car with out any weight.
: Replace the front battery locator with lead or ???? to get the car over 730gm
: Machine the left hub so it is flat when put on the axle
I have also ordered the Team Tamale steering blocks, which will let me run a little smaller front tires.
Anyone else do something that helped or looked better?
T.O.P Racing's Rebel 1/12th scale-hpim1047.jpg   T.O.P Racing's Rebel 1/12th scale-hpim1051.jpg
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 04-26-2011, 03:04 PM   #459
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Happy Birthday Larry!
Old 04-26-2011, 04:52 PM   #460
Grenade, flip your side links so that the recess for the spring is on the bottom, this will make the suspension movement MUCH smoother, with no binding as the spring pops in and out of the recess.
Also, for more side bite, try to raise the back of the shock. I have gone up to 7mm and it feels awesome. I dont know why raising the rear feels better than lowering the front, but it does.
Use some good 2.5mm head screws for the motor, lets you get a good grip on them to keep everything tight.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 04-26-2011, 06:30 PM   #461
Grenade10's Avatar
That would make sense, but one side is really close to fully raised, but I'll give it a try.
I did not have that issue, but will add that to my notes. What tires are you running with that set up?
Yes I would agree on that one. I have replaced most of the screws, a must do on the small screws. The "Cheese" is really soft ..... LOL!!! I use some old motor screws that have a counter sunk washer that really holds, plus it spreads the load over more area.
While we are talking about the motor, any quess as why they did not use the same motor plate on the left side? I know it would do the same job, just has a different open area to it.
Old 05-02-2011, 10:23 PM   #462
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
Anybody have any idea what springs I should use for this thing on asphalt??
Fishhook
ewashburnaf is offline   Reply With Quote
Old 05-02-2011, 10:49 PM   #463
Black side and black centre. I tihnk i have 40wt oil. Side springs about half a mm off chassis at ride height, 50k in tubes.
You will need to maintain a good 4-5mm ride height as it is quite soft, it will bottom out on bumps.
For more side bite, try raising the back end of the centre shock, up to 7mm.
Old 05-02-2011, 10:54 PM   #464
Team Tamale Larry's lowered blocks went on my car on Sunday. Definitely nice pieces!!
Old 05-03-2011, 08:43 AM   #465
RC MARKET's Avatar
TOP Released Option Parts for Rebel 12
T.O.P Racing's Rebel 1/12th scale-top-po-rch005rd.jpg   T.O.P Racing's Rebel 1/12th scale-top-po-rch006.jpg
RC MARKET is offline   Reply With Quote
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9055 02-23-2017 03:26 PM
Trains and Lanes Onroad Racing Summer 08 edition t_laible Racing Forum 2280 06-09-2010 01:41 PM
FS: 1/12 Scale, GTB, 9650 Servo, receivers, Setup Station, DPD, Lathe, +more revolution31 R/C Items: For Sale/Trade 27 12-18-2009 11:09 AM
3-10-2007 Trenton Carpet Racing ShaunMac Georgia Racing 10 03-09-2007 01:49 PM
Hampton MN Rc Racing Mark O'Brien Minnesota and North/South Dakota Racing 411 01-04-2007 11:47 PM
