Like Tree4Likes
Old 04-18-2011, 03:53 PM   #436
Originally Posted by Grenade10 View Post
Any fix for it?
A CRC axle
Also gets rid of the shitty 2.5mm screws for the reear wheels.
You just need to add extra shimming to the left hub (4mm from memory) I just used a Bearing, but you could use the TOP shims for a cleaner look.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 04-18-2011, 07:51 PM   #437
Grenade10's Avatar
Trader Rating: 37 (100%+)
I alreeady changed most of the screws.
Was thinking about machining the face of the hub, and see if that works.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 04-19-2011, 08:50 PM   #438
Grenade10's Avatar
Default Left Rear Hub
If you set up the equipment correctly, machining the hub works. Dial Indicator agree's.
Old 04-19-2011, 09:19 PM   #439
Victor Vector's Avatar
I already changed most of the screws.
It's weak enough already !! You're just asking for an even quicker failure by turning the gink out. My third left hub is CRC (sadly)
Jacko
Jack Balchin.
Timezone Hooligan
IBEW Local 48-retired (Definitely, great pension.)
Victor Vector is offline   Reply With Quote
Old 04-19-2011, 10:18 PM   #440
OVA
OVA's Avatar
Trader Rating: 77 (100%+)
Jacko
I'm still running my rebel left hub....I have the irs left hub for back up...
OVA is offline   Reply With Quote
Old 04-19-2011, 11:28 PM   #441
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
is it possible to re-tap the hub to accept 3mm screws for the wheels?
Thanks!
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 04-20-2011, 07:15 AM   #442
Grenade10's Avatar
Thanks!
Yes, but you should check your wheels to see that the screw head will fit. Most wheels were made for an american socket cap 4/40 screw and I believe the socket cap on the 3mm is slightly larger.
I really don't have an issue with the 2.5mm once you get good screws. Corally has used them since they re-designed from the clips.
Old 04-20-2011, 03:42 PM   #443
How many of you Rebel owners are interested in lowered steering blocks? I know they are supposed to be reworking the molds for the lower arms. The few that I have made so far will accept the stock axles as well as the threaded axles.
team_tamale is offline   Reply With Quote
Old 04-20-2011, 03:48 PM   #444
Grenade10's Avatar
I'd take a set.
Old 04-20-2011, 05:26 PM   #445
Mr. Bubby's Avatar
Sign me up, are they on your website yet
Schumacher MI6 (Motiv Powered) Touring Car
Schumacher KC (SMC Powered) Stock Buggy
No 1/12 scale till they run with rubber tires!!!
Assoc. F6 (Cuz we run them with RUBBER TIRES!)
Mr. Bubby is offline   Reply With Quote
Old 04-20-2011, 05:52 PM   #446
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I would love to get a couple sets of these.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 04-20-2011, 06:04 PM   #447
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
I'd be in for a set or 2
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 04-20-2011, 11:45 PM   #448
CypressMidWest's Avatar
You need 4 sets.....
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 04-21-2011, 03:57 AM   #449
What exactly are you trying to say?
Old 04-21-2011, 05:11 AM   #450
That you like to have spares on hand... jeez.
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Trains and Lanes Onroad Racing Summer 08 edition t_laible Racing Forum 2280 06-09-2010 01:41 PM
FS: 1/12 Scale, GTB, 9650 Servo, receivers, Setup Station, DPD, Lathe, +more revolution31 R/C Items: For Sale/Trade 27 12-18-2009 11:09 AM
3-10-2007 Trenton Carpet Racing ShaunMac Georgia Racing 10 03-09-2007 01:49 PM
Hampton MN Rc Racing Mark O'Brien Minnesota and North/South Dakota Racing 411 01-04-2007 11:47 PM
