Like Tree1Likes
Old 11-01-2010, 01:32 PM   #31
Originally Posted by Dragarcher View Post
As far as motor plates holding up no one has put this on the track yet so it remains to be seen. I don't think there will be a problem because Josh did a bunch of CAD work just like actual "real car" designers. TOP has shown their commitment to being winners with Josh's other design the "PHOTON" by upgrading parts and working with their team drivers to make changes where needed. Here in the USA Mike O'Donnell, and E.J. Evans (TOP USA partners) are absolutly hounded about when this car will be available and that's just by their employee ME! One quick question when you received your Rebel did it come with instructions? I'm thinking they may be waiting on the printers?
I believe the instructions are being printed up yes
CPD Racing
chris_dono is offline   Reply With Quote
Old 11-01-2010, 01:35 PM   #32
over gear's Avatar
Trader Rating: 15 (100%+)
this is the motor mount.
over gear is offline   Reply With Quote
Old 11-01-2010, 01:55 PM   #33
RC MARKET's Avatar
Yes this is new type low cg motor mount !
RC MARKET is offline   Reply With Quote
Old 11-01-2010, 02:23 PM   #34
Team EAM
EAMotorsports's Avatar
Trader Rating: 78 (100%+)
Send a message via AIM to EAMotorsports
Im thunking someone needs a new spur gear!!
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 11-01-2010, 02:36 PM   #35
sportpak's Avatar
Trader Rating: 26 (100%+)
EA
Yeah, I'm wondering if the motor moved in a crash.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 11-01-2010, 05:05 PM   #36
And to think, I was going to buy a Gen XL this weekend! I hope this comes soon!
DJG24 is offline   Reply With Quote
Old 11-02-2010, 01:43 AM   #37
radio_car_racer's Avatar
Originally Posted by chris_dono View Post
can you do a video showing how the rear ride height adjusters are changed?
radio_car_racer is offline   Reply With Quote
Old 11-02-2010, 12:22 PM   #38
over gear's Avatar
use shims to change ride height
Old 11-02-2010, 04:09 PM   #39
Those look like they may break. I hope they have aluminum option parts for that.
Old 11-02-2010, 04:26 PM   #40
Buckaroo's Avatar
Interesting design on using the two screws to hold the motor in. I wonder just how rugged that's going to be.b The shim idea for adjusting ride height looks pretty cool, and may be easier to get set than those dang offset inserts that are always too loose or too tight.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 11-02-2010, 04:40 PM   #41
Ffejdat's Avatar
Chris dono- does it look like you can use up tires all the way if you so choose, I.E. can you set the ride height low enough to run down to the rim?Does it look like you can run the rear axle narrow enough to run 0 offset wheels such as CRC?
Does the car use standard pan car bearing sizes front and rear, 1/8th and 1/4th, or is it metric, standard spurs fit? THANKS!!
Ahhhh, I could'a got a falcon!
Ffejdat is offline   Reply With Quote
Old 11-02-2010, 05:03 PM   #42
haywood's Avatar
Trader Rating: 48 (100%+)
That's a lot of questions there Jeff!
My concern is if the rear pod can withstand a hard hit?
haywood is offline   Reply With Quote
Old 11-02-2010, 05:27 PM   #43
I'll check, but it looks like you can get low enough with the rears
There's a bunch of shims in the box to set the rear axle width, so I'd imagine you can use CRC wheels with no offset, but again I'll double check that for you
Standard bearings (flanged, non flanged, fronts are the same fitting as Jaco wheels take, rather than crc)
The spur in the box is a kimborough item, so they will all fit fine.
CPD Racing
Old 11-02-2010, 06:59 PM   #44
Ffejdat's Avatar
Thanks for the info!!
Old 11-03-2010, 02:23 PM   #45
Chris any updates on the kit? did you put it together yet? have you run it? if so post up some pic's or just call Vincent and tell him to get these out!
Independent Racer, J-Spec sand and sealer, Dog hair free since 2011
Dragarcher is offline   Reply With Quote
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9055 02-23-2017 03:26 PM
Trains and Lanes Onroad Racing Summer 08 edition t_laible Racing Forum 2280 06-09-2010 01:41 PM
FS: 1/12 Scale, GTB, 9650 Servo, receivers, Setup Station, DPD, Lathe, +more revolution31 R/C Items: For Sale/Trade 27 12-18-2009 11:09 AM
3-10-2007 Trenton Carpet Racing ShaunMac Georgia Racing 10 03-09-2007 01:49 PM
Hampton MN Rc Racing Mark O'Brien Minnesota and North/South Dakota Racing 411 01-04-2007 11:47 PM
