Old 02-10-2011, 03:02 PM   #331
ralph m's Avatar
R/C Tech Charter Subscriber
Trader Rating: 31 (100%+)
Until we get something from Larry - here is a temporary solution to the ride height issue http://www.racerlog.com/wiki/T.O.P._Rebel
tqwire.com
ralph m is offline   Reply With Quote
Old 02-10-2011, 03:56 PM   #332
Why are youguys swapping out to different steering blocks?
I got some threaded axles (i believe they were for the AE R5. and the slotted straight in no issues.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 02-10-2011, 04:59 PM   #333
There are a couple of these showing up at our local track. I'm sure there will a couple of things to work on.
team_tamale is offline   Reply With Quote
Old 02-10-2011, 06:01 PM   #334
Has anyone noticed any strange handling immediately after putting the car sideways or hitting a dot?
On the bench when moving the pod, the side springs click in and out of the side link recesses, sometimes getting caught on the lip, effectively preloading 1 side spring an additional 2mm for a moment. Your thoughts?
Old 02-10-2011, 06:34 PM   #335
hanulec's Avatar
Trader Rating: 23 (100%+)
due to ride height concerns. you cannot make ride height with small front tires. it looks like Ralph has been busy -- good work man..
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 02-10-2011, 07:18 PM   #336
L.Fairtrace's Avatar
Send a message via AIM to L.Fairtrace
Flip the sides of the links and run the recess down. I have been running them like that since day 1 and have had no problems. I accidentally did it because I had no instructions when I built my car 4 months ago.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 02-10-2011, 08:06 PM   #337
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
only reason why I swapping the steering block is because the alum block king pin hole don't wearout like the plastic and no slop...my camber stay the same...
OVA is offline   Reply With Quote
Old 02-11-2011, 02:06 AM   #338
TeamWTF's Avatar
I know it will most likely be undriveable... but what rollout would you recommend for a 3.5t on 1s?
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 02-11-2011, 02:59 AM   #339
Depends on the track size..... but 30-35 in rollout, and a 4-4,5t is much more recomanded.
Blink281 is offline   Reply With Quote
Old 02-11-2011, 06:58 AM   #340
Trader Rating: 64 (100%+)
Getting out of the hobby shortly after receiving my Rebel's, so get them cheaper than new while basically new
TOP Rebel 12
http://rockymountainrccarshobby.com
Caravanshaka is offline   Reply With Quote
Old 02-11-2011, 10:52 AM   #341
TeamWTF's Avatar
Thanks for that.
I have a 10.5 (With boost) in for now (First outing with 1/12 tonight) and a 5.5 for when i gain some confidence. The 3.5 will be to see if i can get it round and improve throttle control.... The same way i run Mod TC to improve my stock racing.
Cheers
Phill
Old 02-12-2011, 08:07 PM   #342
Thanks, looks like your Fopar is better than the deisgners
I flipped the links on my firends and my car, both were much better on the track, much more consistent. Sometimes the norm definately does not need redesigning.
The car was transformed going from 25k oil to 50k side tube oil. sssoooo much more consistent.
I also played with raising the outside front top link 2mm, the steering was so much more consistent, was ultra easy to drive.
Old 02-12-2011, 09:50 PM   #343
TeamWTF's Avatar
What tires are you using at Windsor?
Old 02-12-2011, 11:11 PM   #344
The safe bet is speedmind 32f with 30 or 32 rear.
Other brands also work, you can get for example CRC Purple with CRC pink or Magenta to work, but it requires a lot more finesse.
The different type of foam that Speedmind use for the fronts just makes life easier.
Old 02-13-2011, 01:25 AM   #345
TeamWTF's Avatar
So I guess that speedmind combo would work at SMA and Fairy Meadow too?
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9055 02-23-2017 03:26 PM
Trains and Lanes Onroad Racing Summer 08 edition t_laible Racing Forum 2280 06-09-2010 01:41 PM
FS: 1/12 Scale, GTB, 9650 Servo, receivers, Setup Station, DPD, Lathe, +more revolution31 R/C Items: For Sale/Trade 27 12-18-2009 11:09 AM
3-10-2007 Trenton Carpet Racing ShaunMac Georgia Racing 10 03-09-2007 01:49 PM
Hampton MN Rc Racing Mark O'Brien Minnesota and North/South Dakota Racing 411 01-04-2007 11:47 PM
