Like Tree1Likes
Old 02-08-2011, 09:08 PM   #316
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Originally Posted by Victor Vector View Post
Hey Franko, have you blown anything up on yer rebel yet ?
Putting mine down at TimeZone tamara night...all excited I are !!
Jacko
Hey Jacko
Not yet ....you might want to pick up caster shims..I lost mine during the races....just box stock is dialed
OVA is offline   Reply With Quote
Old 02-08-2011, 09:16 PM   #317
hanulec's Avatar
Trader Rating: 24 (100%+)
Originally Posted by OVA View Post
I took the measurement again and I'm bearly under 40mm..more like 39.9mm
and tight 3mm ride height.... I will take pic soon as I can...
I could shave the material off the alum steering knuckle to increase the ride height.
those look like Larry's steering blocks for the Speed Merchant Rev5 or 6.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 02-08-2011, 10:18 PM   #318
OVA
OVA's Avatar
yep
Old 02-08-2011, 10:53 PM   #319
Have you shaved something off the lower arms ?? They look more thinner than mine.
Michael
johnsen-dk is offline   Reply With Quote
Old 02-09-2011, 05:14 AM   #320
ralph m's Avatar
R/C Tech Charter Subscriber
Trader Rating: 31 (100%+)
Those blocks appear to be longer (king pin to ball) than the stock part. This could change the ackerman...not neccessarily bad. Maybe the Xray steering block by Tamale is a closer fit - anyone have experience with these?
tqwire.com
ralph m is offline   Reply With Quote
Old 02-09-2011, 06:25 AM   #321
OVA
OVA's Avatar
Michael
No ..I could shave it more ,if I want to use smaller tires like 39mm or lower...
the steering knuckle is for the rev6..that are thinner than rev 5
Old 02-09-2011, 06:28 AM   #322
OVA
OVA's Avatar
fyi..the tamale and stock are very close the same...I can check tonite....
You can add the plastic spacer to set the servo farther back to change the ackerman..
Old 02-09-2011, 06:52 AM   #323
If possible , that you could take a more clear picture , we don't know the Rev6 in denmark
Thanks in advance
Michael
Old 02-09-2011, 07:42 AM   #324
theisgroup's Avatar
Hum... What did Larry make? Is it a new part? Or a re-use of an existing steering block?
Can u take a picture?
i need to talk to Mr. tamale about making some parts for this car. he maybe able to offset the axle on the steering block so that we can get more ride height from small tires. nothing is perfect until you can run some tamale part.
here is a link to team tamale steering block http://home.earthlink.net/~cbradshaw25/id37.html
here are the xray steering block
http://home.earthlink.net/~cbradshaw25/id41.html
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 02-09-2011, 09:47 AM   #325
Yang, could we get them anodized red? They are tomale so it just seems right.
Independent Racer, J-Spec sand and sealer, Dog hair free since 2011
Dragarcher is offline   Reply With Quote
Old 02-09-2011, 09:52 AM   #326
theisgroup's Avatar
i'll get with larry. most of his stuff is just polished alum because he always cuts small runs of parts. basically what us local guys aks him about.
it almost has to stay that way, just so people know that they have tamale upgrades. lol
yang lai
Old 02-09-2011, 02:22 PM   #327
Yep, those are Rev5 or 6 steering blocks. This distance from the axle to the ball is a little longer than all of the other makes of cars. This will change the ackerman position if the servo position is not moved. This longer position will also effect the steering response making it slightly slower. I can get things anodized just about any color, if there is enough demand to cover the cost.
team_tamale is offline   Reply With Quote
Old 02-09-2011, 03:50 PM   #328
OVA
OVA's Avatar
but the Rebel is closer to center line of the king pin to the axles than the Rev6 steering block...
I used the king pin to line up together and compare
Old 02-09-2011, 04:43 PM   #329
The speedmerchant blocks do have a little more trailing position for the axle.
Old 02-09-2011, 10:25 PM   #330
OVA
OVA's Avatar
yes...
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9055 02-23-2017 03:26 PM
Trains and Lanes Onroad Racing Summer 08 edition t_laible Racing Forum 2280 06-09-2010 01:41 PM
FS: 1/12 Scale, GTB, 9650 Servo, receivers, Setup Station, DPD, Lathe, +more revolution31 R/C Items: For Sale/Trade 27 12-18-2009 11:09 AM
3-10-2007 Trenton Carpet Racing ShaunMac Georgia Racing 10 03-09-2007 01:49 PM
Hampton MN Rc Racing Mark O'Brien Minnesota and North/South Dakota Racing 411 01-04-2007 11:47 PM
