Old 12-04-2013, 03:11 AM   #1381
Hasi's Avatar
Also congrats from me
Now I know who you are in the M-Chassis United-group on facebook
Onroad: Tamiya TT-02, Tamiya TA-02SW, Xray T2'008
Offroad: Asso B5, Asso SC5M, Asso B64D (preordered), Tamiya Avante 2011 Re-Release
Trucks: Tamiya Mercedes Benz Arocs 8x4, Tamiya Mercedes Benz SK 2638 6x6
Hasi is offline   Reply With Quote
Old 12-04-2013, 10:52 PM   #1382
ruebiracer's Avatar
Aitutaki,
thatīs great, that you can run also kit tires. From Tamiya Tires, I always found that the radials are working more easy to drive on the M06 rear for me.
Thanks for the shock/spring setup, but Iīm still curious, if you run Brushless to compete with the FWD-Minis?
And what batteries do you use in the M-class?
Thanks in advance,
Matthias
www.TTSC-Racing.de
www.mst-estenfeld.de/der-loeffler-cup
ruebiracer is offline   Reply With Quote
Old 12-05-2013, 06:36 AM   #1383
Aitutaki's Avatar
Hi Matthias,
we have to use the Carson Cup Machine brushed motor. I think you know this Black Can equivalent very well
Batteries are not limited.
i always use shortys - Vampire Batteries works so well ... - also to have the possibility to change the battery position from rear to front within the short wheelbase...
and i fully agree. i love the S-Grip tires on the rear wheels. they work very fine...
cheers
Flo
Aitutaki is offline   Reply With Quote
Old 12-08-2013, 12:46 PM   #1384
ruebiracer's Avatar
Originally Posted by Aitutaki View Post
Hi Matthias,
cheers
Flo
Thanks Flo,
yes, I know this engine really well, and still like it! In Germany 2 years ago I was the only one running it in the Euro Cup run I participated. The others were already using the 16t Carson brushless, which is in my eyes a slight advantage for the FWD Minis. They were just spinning the front wheels so much, that the acceleration of the Top FWD Minis was really well. But as I learned, being stuck to the Type A-slicks Tire sauce is very important, and everyone is using secret receipes to get the best out of the tire...
Much to complicated for me.
Br,
Matthias
www.TTSC-Racing.de
Old 12-10-2013, 06:18 PM   #1385
Shane Parker's Avatar
Where can I find a blank setup sheet for the M06
Shane Parker is offline   Reply With Quote
Old 12-11-2013, 12:12 AM   #1386
Aitutaki's Avatar
here you go
http://www.tamiya.com/english/rc/setting_sheets.htm
Old 12-11-2013, 05:35 AM   #1387
Boons's Avatar
Hi all,
I have an M03 and M05 and would like an M06 for the collection too
I must admit I dont know too much about these but have seen them in various specs on ebay.
Which one do I want?
Oh, if it matters I'll be using it on carpet.
Cheers
Tamiya Mini M05 V2, Tamiya Mini M03, Carisma M40S brushless
Boons is offline   Reply With Quote
Old 12-11-2013, 06:37 AM   #1388
bizkit1's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Boons View Post
Hi all,
Cheers
For the price, the M06R is your best as far as price and hop-ups included. It already has aluminum dampers, aluminum steering, the rear weights, and various other items that I can't think of right now. Also the bling factor of having a silver and read chassis
Fuzz
bizkit1 is offline   Reply With Quote
Old 12-15-2013, 10:38 PM   #1389
Aitutaki's Avatar
Can't await to run my new Honda Body
TAMIYA M-06 Thread-img_3178.jpg   TAMIYA M-06 Thread-img_3180.jpg   TAMIYA M-06 Thread-img_3182.jpg   TAMIYA M-06 Thread-img_3190.jpg
Old 12-17-2013, 07:14 AM   #1390
Hasi's Avatar
I don't like that S800 body much but yours looks really nice
Old 12-29-2013, 05:24 PM   #1391
mayhem3x's Avatar
I have a question about suspension setup.
using the 54000 dampers, how do you achieve a 5mm ride height?
do I need the carbon fiber towers?
I have two o rings in the front damper piston using the stock towers and it's far from 5mm. this is with the springs all the way up(not threaded).
If I put another o ring in there won't be much travel left.
mayhem3x is offline   Reply With Quote
Old 12-29-2013, 08:32 PM   #1392
Mikeybike's Avatar
I am hoping someone out there has discovered a very short rear body post for the M-05 or M-06? I am trying to set up a Midnight Pumpkin body for fun and need the rear body posts to be basically 0 lift.
Mike Abrey
Why does work always get in the way of my fun?
shhhh, don't tell my wife, she still doesn't know.
Mikeybike is offline   Reply With Quote
Old 12-30-2013, 05:41 PM   #1393
LiamC's Avatar
Could anyone tell me where, or if, you can get the rear hub weight from the M06R? Building myself up another M06 and wouldn't mind it as a tuning option.
LiamC is offline   Reply With Quote
Old 12-30-2013, 07:06 PM   #1394
Raman's Avatar
Trader Rating: 48 (100%+)
Standard and Pro Kit:
You need to use the pistons that comes with the kit, they are slightly longer than standard m chassis 54000 pistons. Part number is: 9805548
http://www.tamiyausa.com/items/radio...-58193-9805548
Carbon Dampers: There are two types. 54300 and 54299 are designed to be used with the 54000 m chassis dampers
54362 and 54361 are designed to be used with the standard touring trf dampers.
M06R: The M06R becomes a little bit more tricky because it has a new lower suspension mount. That kit require that you use 9805504 on the rear with the M chassis dampers.
http://www.tamiyausa.com/items/radio...-58200-9805504
I however ended up using the standard tc damper in the rear to get more ride height.
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 12-31-2013, 09:55 AM   #1395
marcos graveyar's Avatar
Send a message via AIM to marcos graveyar
Only come in the M06R kit unfortunately
marcos graveyar is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 20907 02-18-2017 09:12 AM
EAMotorsports discussion thread BigDogRacing Team and Company Discussions 7633 01-07-2017 08:19 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 02:13 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 08:17 AM
