Like Tree24Likes
Old 10-01-2013, 04:00 PM   #1336
OVA
OVA's Avatar
Trader Rating: 77 (100%+)
Originally Posted by cementsurfer86 View Post
You better bring that thing out on Wednesdays!
Okay I do my best...once I get the mini hopefully I have it ready and dialed...
does is have to be TCS legal?
OVA is offline   Reply With Quote
Old 10-01-2013, 04:23 PM   #1337
cementsurfer86's Avatar
No sir.
Jesse Anderson / JROY386 / R_
ThreeEightSix / Sticky Kicks RC / Schumacher
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is offline   Reply With Quote
Old 10-06-2013, 08:03 PM   #1338
What Tamiya tyres are a good starting point for high grip carpet?
Was going to take the S-Grips off my M05 and try it on the M06R, but I have a few Tamiya Mini sicks and some M-grips.. just running short on new wheels so I don't have much to experiment with.
Thanks.
jjjheimer is offline   Reply With Quote
Old 10-07-2013, 01:58 PM   #1339
Hasi's Avatar
I use the Tamiya 53215 with the 53204 inserts on carpet with my M-06 Pro. Works fine so far
Onroad: Tamiya TT-02, Tamiya TA-02SW, Xray T2'008
Offroad: Asso B5, Asso SC5M, Asso B64D, Tamiya Avante 2011 Re-Release
Trucks: Tamiya Mercedes SK 2638 6x6, Tamiya Mercedes 3553 8x4 heavy haulage
Hasi is offline   Reply With Quote
Old 10-07-2013, 03:47 PM   #1340
Thanks.
A couple of years ago I had my M06 (non-R version) dialled using S-Grips on the back and Type A Slicks on the front, both mounted using the Tamiya dark grey/black inserts (I think they're the hard?). Now that I have an M06R that's where I'll be starting with tires. HTH!
Cheers,
Mike
Mike
Hyper_Mike is offline   Reply With Quote
Old 10-17-2013, 03:29 AM   #1341
Aitutaki's Avatar
Carpet setup:
i'll start first carpet training on saturday. will let you know, what tires i will have used
but i do have an "beginners" question, which makes me a little bit ashamed
during my last race i made following experience:
gear diff installed : when i accelerate from 0 to full throttle the car begins to turn left, no full throttle is accepted. this was not was i was used to before. i cleaned the bearings, set up new dampers etc... but nothing helped out.
except changing back to my M-05 ball diff., then everything was fine again.
so the question is: (and please apologize in advance )
what do i have to change in the gear diff , to be a smoother diff.
shall i fill it with oil ? if so , which ?
or shall i leave it , blank, or build once again how mentioned in the instructions, or use diff grease , or ... ?
thanks for your input.
cheers
Flo
Aitutaki is offline   Reply With Quote
Old 10-17-2013, 06:03 AM   #1342
subaru73's Avatar
Trader Rating: 41 (100%+)
Default M06
Originally Posted by Aitutaki View Post
Carpet setup:
cheers
Flo
I am also building an m06r for carpet in my diff it has tamiya anti wear grease in it.Fill it all the way it will need a little bit of break in just build it like the instructions and you should be good.
Tamiya Ta07 Tamiya evo5 ms,Tamiya Ta05r Tamiya FF04 rm01 Tamiya Ff03R
Futaba 4Px radio lrp speed control
Cfx paint works Fantom Racing apex Rc tq hobbies acer racing Hebki design works
subaru73 is offline   Reply With Quote
Old 10-18-2013, 03:13 AM   #1343
Aitutaki's Avatar
hm thanks, i will give it a try.
but it's strange becuse it worked well for 1,5 years
might it be , that even a gear diff has to be reworked after some times?
nevertheless i will rework it as mentioned in the manual..
thanks again
Old 10-23-2013, 04:53 PM   #1344
Raman's Avatar
Trader Rating: 56 (100%+)
I'm foreseeing (wishfully) an M06 release with the Alfa Romeo 4C. It would be a perfect fit, rear wheel drive, super light weigh small sports car. Perfect for an M chassis
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 10-23-2013, 05:40 PM   #1345
kwkride's Avatar
That would be sweet!
Jim
"If God had meant for us to drive through the front wheels, he never would have allowed us to invent the ring & pinion"
kwkride is offline   Reply With Quote
Old 11-01-2013, 05:16 AM   #1346
Hello,
It's been a while, did some testing last Sunday in preparation for the 2014 season. Some interesting findings (for my track and electronics).
* Springs made no difference in lap times, but the feel was different. Softest springs felt sluggish. Hardest (around 22 pounds, tamiya gas car springs) made the car feel very good and fast in the chicanes. But lap times... same.
* Heavy battery made the car feel more planted and easier to keep on the line. Lap times same as light batteries.
* Tire combo the biggest gain. I started with a set that ran 23 seconds and found a set in the 20+ seconds.
Time to play with the diff, shock angle, width, camber etc.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 11-01-2013, 07:31 AM   #1347
Raman's Avatar
Originally Posted by rccartips View Post
Hello,
I like your scientific methods. Keep us posted..
Old 11-07-2013, 06:04 AM   #1348
bizkit1's Avatar
Trader Rating: 27 (100%+)
Ok, never messed with a M06, but I just bought the "R" model and need to know about shock length. It's going to be used on high traction carpet and I know about the oring trick for the other minis, but this R has be baffeled. I know it has the two different length shocks for front and back, but the rear hop up mounts makes be wonder if I change any length. So can I get some thought on it? Thank you.
Fuzz
bizkit1 is offline   Reply With Quote
Old 11-10-2013, 02:09 PM   #1349
Tested the gear diff yesterday. Nice to give the F1 cars a hard time
+ YouTube Video
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
Old 11-12-2013, 09:30 AM   #1350
bizkit1's Avatar
Fuzz
Anyone??
Tamiya Championship Series Neil Rabara Racing Forum 21185 09-05-2017 07:20 PM
EAMotorsports discussion thread BigDogRacing Team and Company Discussions 7670 08-30-2017 06:14 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
