Like Tree2Likes
Old 08-26-2013, 08:04 AM   #1306
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Originally Posted by Hasi View Post
My setup on my M-06 Pro, high grip carpet track:
Toe-in Front: kit standard
Toe-in Rear: kit standard
Camber Front: kit standard
Camber Rear: kit standard
Damper position Rear: inner position, kit damper stay
Dampers: TRF M-Chassis Works Edition
Front: Yellow springs
Rear: Red springs
Oil: 300 wt(? I always get confused about wt/cst)
Pistons: 2 hole
Rear dampers got the long ball cups.
Tires: Tamiya 54d slicks all around
Body: HPI BMW 2002 Turbo
Works fine for me so far.
I'm thinking about getting the M06R...
How does this car work on Asphalt?
OVA is offline   Reply With Quote
Old 08-26-2013, 12:04 PM   #1307
Aitutaki's Avatar
works pretty fine.
last weekend i won my local TCS against all M-05s fastest lap was nearly 1 second faster then the second.
my setup for aspahlt tracks (posted earlier in this thread)
2 degree rear
600 tamiya damper oil front
500 rear
red spring front & rear
tamiya red m-06r dampers
carbon damper stay rear
hard stabilizer in the front (none in the rear)
tamiya type a tires all around.
SWB and Silvia S15 body
M-05 ball diff or gear diff (depends on the grip of the track)
Aitutaki is offline   Reply With Quote
Old 09-07-2013, 09:01 PM   #1308
I thought the Silvia S15 would be a comical body, but seems pretty good looking after all...
Wanted some speed... Hobbywing turbo esc with 13.5T brushless and lipo...
My setup... for testing next weekend.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 09-07-2013, 10:10 PM   #1309
Aitutaki's Avatar
yes i can confirm, it does not look bad at all
finally i love the S15 body too...
nice position for the esc...
was this planned, or just because of missing space?.
cheers
flo
Old 09-07-2013, 11:58 PM   #1310
I would like to put esc opposite the servo, but wires were too short
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
Old 09-08-2013, 04:33 AM   #1311
ruebiracer's Avatar
Ha ha,
simple explanation Joel!
As everyone is knowing here your genius and love for details,
no one would expect too short wires as explanation!
You seem to want to push the M06 to the limit with this engine?
Guess itīs just for fun racing?
I wonder what will happen when you push the throttle!
Keep us updated please!
BR,
Matthias
www.TTSC-Racing.de
www.mst-estenfeld.de/der-loeffler-cup
ruebiracer is offline   Reply With Quote
Old 09-11-2013, 11:08 PM   #1312
what's the general consensus on diff builds? go with dry gears and the stock M06 gear diff? It's for high traction indoor carpet.
jjjheimer is offline   Reply With Quote
Old 09-12-2013, 01:26 AM   #1313
Hasi's Avatar
I just use the Tamiya stock gear diff with the kits stock grease, also greased the gears like advised in the manual.
I drive on a high traction indoor carpet also.
Onroad: Tamiya TT-02, Tamiya TA-02SW, Xray T2'008
Offroad: Asso B5, Asso SC5M, Asso B64D, Tamiya Avante 2011 Re-Release
Trucks: Tamiya Mercedes SK 2638 6x6, Tamiya Mercedes 3553 8x4 heavy haulage, Tamiya Mercedes Arocs 8x4
Hasi is offline   Reply With Quote
Old 09-12-2013, 08:01 AM   #1314
Aitutaki's Avatar
Default batteries for stock class racing
Hi guys,
what batteries would you prefer for stock class racing.
So all of us have the same slow motor etc...
it is important to have a lot of punch , served by the batteries
i know Noel had some comparisons a time ago...
what batteries would you prefer nowadays, to be the fastest with your M-06
At the moment i tested some
Vampire, MuchMore , GM Lipos...
But not sure which one is state of the art....
For me, even 2500maH would be more than enough, because only about 1000 are used during a Main...
But also 7000 Batteries will be ok, the Punch is the important thing
Thanks for your thoughts
Flo
Old 09-12-2013, 02:46 PM   #1315
I tried:
5100/40c (338gm) - 7.78v avg discharge voltage
3300/35c (210gm) - 7.61 avg discharge voltage
Similar lap times on tamiya slow motor racing (28T). I guess the 0.2v was not enough to compensate for the extra 128gm.
But there are strong batteries that are very light that should make the difference. e.g.
Fantom 5300/65c (270gm) - 7.85v
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
Old 09-13-2013, 03:09 AM   #1316
Aitutaki's Avatar
I tried:
thanks,
sounds interesting.
unfortunately i did not found an european reseller for fantom so far.
let's see where i can find one.
one additional question about your measurement.
did you just drive e.g. 6 minutues and then measure the voltage of your battery ?
thanks
Old 09-13-2013, 07:14 AM   #1317
From fully charge, I discharge using lightbulbs (around 14 amps), take voltage measurements every 15 seconds for around 5 minutes. Then take the avg voltage.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
Old 09-15-2013, 10:45 AM   #1318
Finally got to test the M06 short wheelbase. I love it, much better than my medium wheelbase Miata. Fun to powerslide the corners, with back end drifting a little, rotating the car very quickly.
+ YouTube Video
Video had a lot of background noise, so I put music instead.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
Old 09-15-2013, 01:40 PM   #1319
Aitutaki's Avatar
absoluteley agree.
love the SWB right now.
i will try the renault alpine body next time. let's see how this ones performs...
Old 09-18-2013, 03:13 PM   #1320
foampervert's Avatar
Send a message via MSN to foampervert
Default Bodies with wings or flaps
Originally Posted by Aitutaki View Post
absoluteley agree.
I used to run my m06 with a tamiya renault alpine body, I found that it was very fast, not much steering and definitely very little rear grip or stability.
I tried some other shells, such as team titan's Volvo c30, abc hobbies lancia stratos and some others.
I noticed that the shells with wings work best for m06, shells with gurney flaps also worked pretty decently. Shells with no aero downforce made the car very unstable for road racing. They were great for rally though.
-Alexander
During heats, i use durex for both front and rear, with Hard inserts.
Sorex, i meant Sorex.
foampervert is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 20957 Today 01:22 PM
EAMotorsports discussion thread BigDogRacing Team and Company Discussions 7633 01-07-2017 07:19 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
