Old 07-28-2013, 07:29 AM   #1291
tim fry's Avatar
What options for SWB body are there?
I'm current using the Renault Alpine but fancy something else.
tim fry is offline   Reply With Quote
Old 07-28-2013, 08:12 AM   #1292
Raman's Avatar
Trader Rating: 47 (100%+)
You actually have a greater option on short wheelbase. You can run the HPi cup racer Porsche 911 rsr, Lancia Stratos and all the bodies from abc hobby..
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 07-29-2013, 12:19 AM   #1293
Hasi's Avatar
I think the Carson Trabant should also fit
Onroad: Tamiya TT-02, Tamiya TA-02SW, Xray T2'008
Offroad: Asso B5, Asso SC5M, Asso B64D (preordered), Tamiya Avante 2011 Re-Release
Trucks: Tamiya Mercedes Benz Arocs 8x4, Tamiya Mercedes Benz SK 2638 6x6
Hasi is offline   Reply With Quote
Old 07-29-2013, 09:31 AM   #1294
Aitutaki's Avatar
Thumbs up
For competitions the Silvia S15 might be the best choice.
If you have to use tamiya bodies in your local TCS...
Aitutaki is offline   Reply With Quote
Old 08-04-2013, 06:41 AM   #1295
Rc-bear's Avatar
I am currently building a M06, I know what speedie and motor I will be running.
What do you people recommend servo wise?
I was going to install a savox 1251, that's what I run in my m05 but the m06 isa new beast.
Sakura Zero - Sakura Zero S- F113 - Mini M05 & M06 - SC10 - T4.1 - B4.1 - 12R5.1 - Losi MRC
Rc-bear is offline   Reply With Quote
Old 08-04-2013, 07:08 AM   #1296
Raman's Avatar
If you plan on installing ESC and receiver on left hand, then I'd install a standard height servo. I'm presently running a Futaba low profile and I ended up adding weight right side to balance out the chassis.
I don't know savox servos by numbers, basically any high resolution digital servo will suffice.
Old 08-20-2013, 01:51 AM   #1297
Hasi's Avatar
Hey Guys,
I'm thinking of getting a Porsche Turbo RSR Type 934 body for my M-06.
I was wondering if the Tamtech-body would fit? I haven't found anything about the dimensions of that chassis....
http://www.tamiyausa.com/items/radio...urbo-rsr-57101
There's also a Type 934 on a special TA-05 chassis with a WB of 230mm, but I think its width doesn't match...
http://www.tamiyausa.com/items/radio...type-934-49400
I know there's a HPI Porsche body, but that's not the one I'm searching for
Anybody any ideas?
Old 08-20-2013, 06:42 AM   #1298
Raman's Avatar
I think the Tamtech is too small. Check the HPI cup racer thread, I think one person was able to fit it to the cupracer.
The TA05, wheelbase of 230 is close to M06, M is 225 and L is 239. Problem is the body is wide, 190 mm width, the M06 is too narrow.
Old 08-20-2013, 07:43 AM   #1299
Hasi's Avatar
Thought so.... damn it
Well, let's hope Tamiya does some new bodies for the M-Cars then and that the Porsche Turbo RSR type 934 is one of them...
Old 08-21-2013, 09:47 AM   #1300
Raman's Avatar
Here is the Cup Racer thread
http://www.rctech.net/forum/electric...racer-183.html
I think he ended up using the whale tale on the RSR body
Old 08-22-2013, 01:03 AM   #1301
Hasi's Avatar
Thanks, looks nice.
But in my opinion using the whale tale doens't make a Type 934...
This may be a bit close-minded, but yeah...
I guess I'll just have to wait an hope.
Old 08-22-2013, 01:55 PM   #1302
Schs2013's Avatar
Looking for a few tips on building tfr shocks mainly for the seal section any tips that have worked well?
Schs2013 is offline   Reply With Quote
Old 08-25-2013, 11:02 PM   #1303
OVA
OVA's Avatar
Trader Rating: 72 (100%+)
Who got carpet set up for m06
OVA is offline   Reply With Quote
Old 08-26-2013, 05:16 AM   #1304
Hi guys,
I've only run medium wheelbase. Any comments on the Long and Short?
Will be testing the short soon.
Thanks.
Joel
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 08-26-2013, 07:55 AM   #1305
Hasi's Avatar
My setup on my M-06 Pro, high grip carpet track:
Toe-in Front: kit standard
Toe-in Rear: kit standard
Camber Front: kit standard
Camber Rear: kit standard
Damper position Rear: inner position, kit damper stay
Dampers: TRF M-Chassis Works Edition
Front: Yellow springs
Rear: Red springs
Oil: 300 wt(? I always get confused about wt/cst)
Pistons: 2 hole
Rear dampers got the long ball cups.
Tires: Tamiya 54d slicks all around
Body: HPI BMW 2002 Turbo
Works fine for me so far.
Tamiya Championship Series Neil Rabara Racing Forum 20851 01-17-2017 10:21 PM
EAMotorsports discussion thread BigDogRacing Team and Company Discussions 7633 01-07-2017 08:19 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 02:13 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 08:17 AM
SEO by vBSEO 3.5.0
