Old 05-10-2013, 09:06 AM   #1201
volracer's Avatar
Send a message via ICQ to volracer
If you had your choice, what body would you put on the M06?
MGB
Elva courier
bug eyed sprite
volracer is offline   Reply With Quote
Old 05-10-2013, 09:12 AM   #1202
kwkride's Avatar
If I had my choice it would be anything by an American car company.
I feel that way about all of the TCS classes though.
Beyond that, I would just like to see a few more choices that fit the M06 properly.
Right now, every M06 at our track is running the S15 Silvia
Jim
"If God had meant for us to drive through the front wheels, he never would have allowed us to invent the ring & pinion"
kwkride is offline   Reply With Quote
Old 05-10-2013, 12:51 PM   #1203
Trader Rating: 31 (100%+)
Originally Posted by Aitutaki View Post
95% agree
i really did try all of this , to improve the handling with Type A tires .
weight -> m-06R weights.
shift weight back -> shorty lipo in the very rear end.
lower rear ride height and rise front height -> done
reduce front camber -> yes
stiffen front -> yes - Hard sway bar installed and hard springs (rear: soft springs)
but only the rear sway bar did not meet my expectations about a better handling *g*
and yes: i also can confirm, that i had to struggle when entering some very fast corners. when my competitors can use full throttle in this corners i had to leave the full throttle position. in my video you can see that i always lost some tenths in the corner just before the long straight. but the fastest lap time was more or less the same. so i must have been faster oftenly in the other corners....
so the big thing is , to get even more grip in the front but prevent some grip roles
Were you running type A all around or just in the front? Have you tried s-grip in the rear and type A in the front on asphalt?
So what you are looking for now is a little more front grip so you don't drift wide on high speed corner entry?
Sometime that can be done with a quick weight transfer to the front tires. Then quick on the gas again. Kind of like stock racing the old days.
v_squared is offline   Reply With Quote
Old 05-10-2013, 12:56 PM   #1204
More rwd mini bodies would be nice. In fact more mini bodies over all would be nice. I would like to see a Lotus Europa for m06.
Old 05-10-2013, 03:01 PM   #1205
SilverShelby's Avatar
a Shelby Charger or Omni GLH would be great....
and YES Its a can motor!!!!!
M03,M05L,M06M,FF03PRO,CC01 Jeep,M03L-Yello Mini
ABC Hobby Goose,Genetic
2011 Memphis winner Mini,FWD
2013 e mergent winner Mini
SilverShelby is offline   Reply With Quote
Old 05-11-2013, 10:08 AM   #1206
Hi guys and girls after some setup ideas for my m06 using it on carpet. Just seeing if anything has changed as i have not used it for 18 months
Many thanks Rob
minivtec is offline   Reply With Quote
Old 05-11-2013, 11:22 AM   #1207
Raman's Avatar
Trader Rating: 47 (100%+)
1:1 scale equivalent to M chassis would be equivalent to a 4 cylinder race class, 1.2 to 2.0 litre. The 4 cylinder american pony cars would not look scale on an M chassis, plus thats what you have VTA class for.
From the 60s / 70s the only american cars I can think of would be a Ford Capri (technically Brit) Chevy Corvair.
ABC Hobby has a lot of bodies that will work on the SWB of the M06. HPI also has the Porsche RSR, Datsun 510, 240Z, and Toyota Levin.
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 05-11-2013, 02:42 PM   #1208
OVA
OVA's Avatar
Trader Rating: 72 (100%+)
don't forget the ford Pinto,mustang 2. Chev vega, monza,Pontica fiero,
OVA is offline   Reply With Quote
Old 05-11-2013, 03:31 PM   #1209
Raman's Avatar
Ford wants you to forget the Pinto
Old 05-15-2013, 12:46 PM   #1210
Hi could any body that owns a set of the R hub weights please tell me how much they weigh as i want to make some.
And i would also love to see more shells for the m06 as there is a very poor selection about at the moment
Old 05-15-2013, 02:22 PM   #1211
Dan
Dan's Avatar
Trader Rating: 40 (100%+)
Maybe you can put in a swelled up lipo so when you crash, it will be like the real Pinto. Lol
Dan is offline   Reply With Quote
Old 05-15-2013, 03:53 PM   #1212
Raman's Avatar
I think they are 7 g each. Do a search on thread, it was posted a few pages back.
Old 05-15-2013, 03:54 PM   #1213
Raman's Avatar
Lol
How about strapping the LiPo to the back of the body for the desired effect
Old 05-15-2013, 08:19 PM   #1214
Core Creations's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Core Creations
Eunos Mx5 and 225mm wheelbase...hands down.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 05-16-2013, 12:03 AM   #1215
Dan
Dan's Avatar
I also ran the HPI MX5 body on my M06 once. You'll need lower body mounts for the rear part, otherwise, the rear end will be mounted a lot higher. It was a pretty good handling body.
Tamiya Championship Series Neil Rabara Racing Forum 20852 01-21-2017 08:29 PM
EAMotorsports discussion thread BigDogRacing Team and Company Discussions 7633 01-07-2017 08:19 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 02:13 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 08:17 AM
SEO by vBSEO 3.5.0
