Like Tree7Likes
Old 05-08-2013, 09:09 PM   #1186
Raman's Avatar
Trader Rating: 51 (100%+)
Corner entry speed is what I believe makes it slower than an M05. Corner exit however it's much faster.
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 05-09-2013, 03:57 PM   #1187
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
what the best Tamiya bodies shell for M06 outdoor racing ?
OVA is offline   Reply With Quote
Old 05-09-2013, 04:03 PM   #1188
wollow86's Avatar
For sure, but it does depend on the corner. I find anything that would have required the breaks on a 05 is where they can get through faster. However those are usually the corners the 06 makes it back on the exit.
So to repeat my earlier question, what diff configurations are being used at the moment? Ball, Oil or Kit and how is it setup?
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 05-09-2013, 04:54 PM   #1189
Raman's Avatar
I used to run the kit gear diff with the anti wear grease as per instructions. I recently switched to the m05 ball diff and personally prefer it. It was recommended to me by an M06 racer that was very competitive. I personally swear by the ball diff.. Then again I'm not the best driver
There are a few that are running the spec r gear diff or 3 racing gear diff. Those are both better options than the stock gear diff. As for oils, I will them chime in..
Old 05-09-2013, 09:30 PM   #1190
vivo quevas's Avatar
Trader Rating: 18 (100%+)
Tamiya doesn't make a good body for a M06. It really makes me want to sell mine! So disapointed in Tamiya's bodies for my M06!
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 05-09-2013, 09:53 PM   #1191
Raman's Avatar
You still going on about bodies for M06?
If you had your choice, what body would you put on the M06?
My opinion on M chassis cars is that the bodies should be vintage / historical race cars.. M06 should be a rear wheel drive and m05 should be a fwd. This is also Tamiya's view on these cars and thats why the first body on the new version of the fwd (m01, m03, m05, eventually m07) will be the Mini body. The new rear wheel drive (m02, m04, m06 and eventually m08) will be the Alfa GTV.
There are a few peeps that do show up to race with an m chassis Mazda 6 type and I let my opinion be known, that those bodies should not be allowed. If they want to run those bodies, they should be racing TC.
Old 05-09-2013, 10:04 PM   #1192
OVA
OVA's Avatar
I thought maybe Miata bodies would be good...
Old 05-09-2013, 10:40 PM   #1193
JustWill75's Avatar
Send a message via AIM to JustWill75
I personally like the Silvia.
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 05-09-2013, 10:45 PM   #1194
celt's Avatar
Good old No. 25 for me...
Honda S800 - dig that body so much.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 05-10-2013, 12:56 AM   #1195
marcos graveyar's Avatar
Send a message via AIM to marcos graveyar
I would love if someone would do a Mini Marcos GT body for the M05.
Then again I am a little biased.
marcos graveyar is offline   Reply With Quote
Old 05-10-2013, 04:22 AM   #1196
Aitutaki's Avatar
Originally Posted by v_squared View Post
Thanks for posting about your adventures with the m06 on asphalt tracks. What is about the m06 that makes it a little slower on asphalt tracks? If you are running on low grip tracks there are a number of things you can do to get forward bite. Like add a little weight. Shift the weight to the back. Lower the rear ride height. Rise the front ride height. Reduce front camber. stiffen the front end. Increase front drops. Add rear sway bar or use stiffer rear sway bar. I remember adding a rear sway bar to my b4 on a dry hard back track and the rear suddenly gain a lot more tractions.
As soon as I can get to an asphalt track I will let everyone know what I find. The closest track to me is Joliet in Illinois and it is about four plus hours away so I don't know when I can make it down.
Please help test if you have access to an asphalt track. It would nice if testing can done with Tamiya tires as a control condition that way we can really compare and discuss the results in a more meaningful way.
95% agree
i really did try all of this , to improve the handling with Type A tires .
weight -> m-06R weights.
shift weight back -> shorty lipo in the very rear end.
lower rear ride height and rise front height -> done
reduce front camber -> yes
stiffen front -> yes - Hard sway bar installed and hard springs (rear: soft springs)
but only the rear sway bar did not meet my expectations about a better handling *g*
and yes: i also can confirm, that i had to struggle when entering some very fast corners. when my competitors can use full throttle in this corners i had to leave the full throttle position. in my video you can see that i always lost some tenths in the corner just before the long straight. but the fastest lap time was more or less the same. so i must have been faster oftenly in the other corners....
so the big thing is , to get even more grip in the front but prevent some grip roles
Aitutaki is offline   Reply With Quote
Old 05-10-2013, 04:26 AM   #1197
Aitutaki's Avatar
I also can confirm this, i did have more troubles using the kit diff. after changing to the ball diff (TA-03 at the moment) i do have much more fun ...
to be honest i did change the setup of this car in general , but the ball diff is one part of the whole change...
and as posted before, i only had the ta-03 diff available. but will change to m-05 as soon as it will be delivered and check the bi differences for me...
Old 05-10-2013, 04:31 AM   #1198
Aitutaki's Avatar
hm, i do own the RX7 and the beetle bodies.
But i can not see many big differences as far as the speed of our series is not the fastest. (sport tuned motor speed)
The real big difference is the in fight compatibility. very often the beetle will be the loser of some fights. and if the car crashed, it oftenly ends up with the beetle laying on the side
Old 05-10-2013, 07:55 AM   #1199
[QUOTE=Raman;12136274]You still going on about bodies for M06?
QUOTE]
Raman I'm sorry I race in this century it just looks funny when I'm running a Nissan Silva against a field of Mini's. M06 don't race in a seperate class then the other M- chassis's! Tamiya should make a mini style body for the M06! That is all I'm saying Tamiya bodies choices are very limited for the M06 IMHO it is a opinion an opinion is like a hole's everybody has one and that is my opinion! Tamiya could make a body that allows me to run a longer wheel base I think my M06 would handle much better at 125mm. There should be more bodies then 3!
Also mini bodies turn themselves back over when they get flipped over most of the time. These changes might make M06 a race car that could really compete against M03/M05 those are the cars of choice at TCS aren't they?
What body should they make? Off the top of my head:
Ford Fiestiva
Dodge Caliber
Nissan Cube
That new Fiat
Honda Pilot
Old 05-10-2013, 08:03 AM   #1200
OVA
OVA's Avatar
I just pick up the Alpine bodies..should be good enough..
Tamiya Championship Series Neil Rabara Racing Forum 21024 05-21-2017 10:48 PM
EAMotorsports discussion thread BigDogRacing Team and Company Discussions 7641 05-20-2017 05:57 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
