TAMIYA M-06 Thread
#1111
Keep in mind that the TA03 ball diff is about 15 years old. The M05 is identical in design to TRF416.
For the gear diff, someone should look into the possibility of using the plastic gears from TA06. They're much lighter and sufficiently durable, especially for a Silvercan motor
#1112
For the serial gear diff, maybe the planetary gears fit, but not the dish gears on the outdrives, because of the different attachment method?
But just thinking, probably I did not get your intention.
BR,
Matthias
#1114
Ah, okay.
Now itīs clear. But would Tamiya allow Ta06 inner parts in a M-gear diff,
if they would fit?
Thanks for the explanation. I hope Tamiya will sell a sealed gear diff some day also for the Minis...
if they would fit?
#1116
Spent around 6 hours at the track today tuning the M06. My daughter drove around 400 laps. She went up and down the stand 20 times to test 20 different setups.
First runs were 23 seconds. After 6 hours...
Her last run of 8 laps were 19.9, 20.2, 20.4, 20.0, 20.2, 20.3, 20.2, 20.2. Like a robot.
#1117
#1118
She seems to be really keen on driving! Sheīs a real race-girl!
What was Dadīs plan, Joel? Tires, shocks, fine adjustments? Guess you discovered some more M06 tuning knowledge with this consistent lap times....
BR,
Matthias
#1119
Suspension weights
Hiya folks,
Anyone tried the m06r suspension hub weights?
What are the effects and does it work for outdoor Tarmac?
Do please share your thoughts.
-Alexander
I have a m06 that's been used as a TAC fighter, then re-built as a rally car. Was super fun! Thinking of converting it back for on-road play.
-Alexander
#1120
If you look 2 pages ago we started some discussion on the weights.
Some of us are still testing, but most of us had the impressions they help.
Remember that you cannot get them as single parts, only in an R-kit.
Probably they will never be for sale as single parts, as the R is a limited edition kit. If you want to rebuild your existing M06 kit, the weights are an expensive tuning part.
BR,
Matthias
BR,
Matthias
#1121
Tomorrow is race day. Hard work of practice and setup done. Now just hoping for some good racing luck.
#1123
Thanks Jim.
#1124
Let the wheels of the M06 burn!
BR,
Matthias
#1125
Thanks Matthias
