Like Tree24Likes
Old 03-02-2013, 01:26 PM   #1066
Originally Posted by ruebiracer View Post
I got yesterday my M06R kit, just had to get it for the special parts!
BR,
Matthias
Hi Matthias, thanks for the kind words. My friend (the only other M06 racing in my country) also bought the M06R for the parts. The 10gram wheel weights seem to be helpful in low traction. But if track has good grip it might not be needed.
Originally Posted by Raman View Post
That's fantastic. Are you running on carpet?
Also are your running 1 or 2 degree rear upright?
Also it looks like you're running the standard TRF shocks, not the Mini/short TRF correct?
With the added rear weight / traction, I wonder of i will have to soften the front to add steering.
Hi Raman, running on indoor asphalt. TRF MINI shocks and 1.5 deg rear upright. Front uses the softest tamiya red spring.
Originally Posted by Aitutaki
Just wondering what kind of Motorcooler you are using.
Hi Aitutaki, the one on the car stand (12v) I bought in surplus. The one in the car, I don't remember lol.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 03-02-2013, 02:42 PM   #1067
Raman's Avatar
Trader Rating: 56 (100%+)
I saw someone mount the basic ESC fan to the rear stabiliser mount. Holes line up perfectly. If you want the fan directed at end bell... Guess you have to get creative
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 03-02-2013, 02:56 PM   #1068
I just use 1 screw to the rear stabilizer mount to hold the fan over the endbell.
Also on my M05 ball diff outdrive, notice there is a metal band to prevent it from splitting open. That metal is just the middle part of a ball bearing that I tore apart.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
Old 03-02-2013, 05:17 PM   #1069
Raman's Avatar
Have you found them split open? It's the same light weight material as the TRF416, never had those open.. They distort after a while
There is also a hardened version 54238
http://www.tamiyausa.com/product/ite...oduct-id=54238
Old 03-03-2013, 11:22 AM   #1070
ruebiracer's Avatar
Thanks Joel for the comment on the weights. Will for sure try them during the outdoor season on tarmac. Will see if it brings any advantage next week on carpet...
Finally swapped the R knuckles in rear in the car, and made some maintenance work. Had to replace the spur gear, was nearly stripped...
One question I have: Do you put a grub screw in on the axle, when using alu-uprights? (see pic) The R manual says no, but maybe itīs useful to remove any further play? Or leave it out? Would be curious on your advice guys.. I usually do it when using plastic uprights.
Made some pics for you, noticed I didnīt take some for a long time now.
Iīve also the fan above the middle of the can, as the Carson cup machine has an internal fan on the rotor.
BR, Matthias
TAMIYA M-06 Thread-m06pro4.jpg   TAMIYA M-06 Thread-m06pro6.jpg   TAMIYA M-06 Thread-m06pro5.jpg   TAMIYA M-06 Thread-m06pro3.jpg
www.TTSC-Racing.de
www.mst-estenfeld.de/der-loeffler-cup
ruebiracer is offline   Reply With Quote
Old 03-03-2013, 12:06 PM   #1071
Raman's Avatar
I install the grub screw even on plastic up rights. As you mentioned it helps with slop
Old 03-03-2013, 07:11 PM   #1072
Raman's Avatar
BR, Matthias
Nice gear cover.. where did you get that?
Old 03-03-2013, 07:13 PM   #1073
Raman's Avatar
Here are pictures of my newly built M06 Pro with R spec lower link. On the rear, I ended up using the standard touring rear damper.
Here is my body.. well what's left of it..
Old 03-03-2013, 10:12 PM   #1074
ruebiracer's Avatar
Hi Raman,
The gear cover I have is from Eagle Racing, they have top quality parts, as they are a nearly as old as Tamiya, but they sell them rather cheap.
I recently found a good webshop in HK, which sells most of their stuff, otherwise quite hard to get here in Europe:
http://www.broadtech.hk/eagleshop/sh...h&keyword=m-06
The gearcover I have now for 2 years, at the moment itīs not in stock.
Very nice parts are also the Shock towers, as the have the original kit holes plus some steps in between. I have them lying around for quite a while and will built them in next.
Your Alfa looks still nice, I like seeing some "racing marks"!
I guess you have a shelf body, too, so itīs no problem!
I like your color choice a lot!
BR,
Matthias
www.TTSC-Racing.de
Old 03-04-2013, 04:08 AM   #1075
Hi very nice bodyjob.
Can you tell me w;ere you find the autodelta decals?
drover is offline   Reply With Quote
Old 03-04-2013, 04:08 AM   #1076
Can you tell me were you find the autodelta decals?
Old 03-04-2013, 12:33 PM   #1077
Raman's Avatar
I downloaded the eps files from brandsoftheworld.com. Then I resized them to fit the body. Biggest challenge was finding someone to print them on clear vinyl.
Shoot me a pm with your email, and I will forward you a file with the Autodelta decals
Old 03-07-2013, 11:47 AM   #1078
kwkride's Avatar
We were back to the road course setup last night. I'm still happy with the "R". It was working pretty well and I managed to TQ again. I'm not sure how long that will last though, I think they're gunning for me now.
My M05 wasn't happy unless I was running "M"s on all four corners. Last night I ended up with "S"s all the way around for the main on the M06.
Jim
"If God had meant for us to drive through the front wheels, he never would have allowed us to invent the ring & pinion"
kwkride is offline   Reply With Quote
Old 03-07-2013, 12:00 PM   #1079
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Are you guys running the same layout as TCS?
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 03-07-2013, 12:04 PM   #1080
kwkride's Avatar
Yes we are . . . . .
I may have been able to go with "M"s on the front for the second main (We run dual mains), but I didn't want to change anything.
Jim
Tamiya Championship Series Neil Rabara Racing Forum 21185 09-05-2017 07:20 PM
EAMotorsports discussion thread BigDogRacing Team and Company Discussions 7670 08-30-2017 06:14 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
