Like Tree9Likes
Old 11-26-2012, 05:15 PM   #916
Originally Posted by Raman View Post
I know you said suspensions is good.. But did you check to see if the arms move freely and do not bind. Also is your servo centring?
Arms are moving freely. I'm going to rebuild the shocks just in case. But I have full range of motion front and back.
Servo seems A-OK. Going to swap it out just because.
.crispy is offline   Reply With Quote
Old 11-26-2012, 05:19 PM   #917
Raman's Avatar
Trader Rating: 51 (100%+)
How are your tyres? Check to see if they are even. If the fronts have developed an inner ring, it can cause your car to bob and weave
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 11-26-2012, 06:28 PM   #918
Crispy, check your diff & make sure it is tight, too me it sounds like a loose rear diff
check the bearings make sure they are all smooth
and lastly make sure you have the right servo adapter for the servo you are using
Shortbusallstar is offline   Reply With Quote
Old 11-27-2012, 07:27 AM   #919
Depends on surface you're running on but sounds to me you have a combo of loose diff and mostly incorrect tires in rear
In most cases running a grippier set in rear is what you want
Overgeared Racing
GH Racing
TommyAfrica is offline   Reply With Quote
Old 11-27-2012, 07:34 AM   #920
Fairly new set of S-Grips on the rear, seem balanced. Swapped the servo, no difference. Rebuilt the shocks.
Here's the odd thing, I returned the front to 1 to 2 degrees of toe OUT and it seemed to help stabilize the car in a straight line. I thought that toe out would make it wander more?
BTW, how do I tighten the diff on this car?
Old 11-27-2012, 01:01 PM   #921
Send a message via AIM to A-Ko
Have a M06. Noticed there were aluminum rear uprights for 0, 1 & 2 deg rear uprights pt# 54178, 54327 & 54267. Does anybody know if or what the part numbers are for plastic ones are?
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 11-27-2012, 06:07 PM   #922
Does anyone knoe wehn the M06R will be released in the US?
This is the red anodized version of the mo6 with the hop ups
also for high traction carpet do i want a ball or gear diff with a stock silver can 27t?
Old 11-27-2012, 07:16 PM   #923
Raman's Avatar
January I think
Old 11-29-2012, 12:17 PM   #924
Tighten rear diff you depends on if you have gear diff or ball diff
Gear diff use thicker viscosity than what is already used
Ball diff take off rt rear suspension and pull out dog bone inside you see a 1.5mm hex screw ,tighten to desired effect
Overgeared Racing
GH Racing
Old 12-03-2012, 12:45 PM   #925
vivo quevas's Avatar
Trader Rating: 18 (100%+)
I have a question has anyone reversed the rear hub carriers to take the rear tow in out out of the rear of the car. Less rear tow in would take the on power push my car has. Or should i go with S grip tire on all four corners.
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 12-09-2012, 11:39 AM   #926
abi787's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to abi787
Questions??
Can someone tell me the difference if any, between the MABUCHI and JOHNSON 540 motors.
abi787 is offline   Reply With Quote
Old 12-13-2012, 11:35 AM   #927
irockflipflops's Avatar
Trader Rating: 33 (100%+)
a lot of people seem to believe the johnson silver cans are a stronger motor than the mabuchi's...apparently they are harder to come by too...
What’s behind you doesn’t matter. – Enzo Ferrari
“Very occasionally, if you pay really close attention, life doesn't suck.” ― Joss Whedon
irockflipflops is offline   Reply With Quote
Old 12-13-2012, 05:55 PM   #928
Raman's Avatar
I think Johnsons have more rpm and Mabuchi have more torque.
53689 is the 540-J Johnson motor
7435035 is the 540-SH Mabuchi motor
Old 12-13-2012, 08:42 PM   #929
Raman's Avatar
TamiyaUSA is showing the M06 Pro kit as discontinued. I guess the M06-R is going to replace it.
Slight over sight on Tamiya's behalf.. no one outside of Japan will want to show up to a track with a chrome and red chassis. Its pretty hideous looking.
Old 12-14-2012, 04:16 AM   #930
That is hilarious.
We have this one Japanese fellow that shows up at our local track. He works at the local Subaru factory. He has an M03/M05 that he runs in our Mini class.
It is an all chrome chassis...
What's really neat is the he has a Subaru 360 body for it.
Tamiya Championship Series Neil Rabara Racing Forum 21036 Today 06:18 PM
EAMotorsports discussion thread BigDogRacing Team and Company Discussions 7642 06-05-2017 02:43 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
