Old 11-22-2012, 03:40 PM   #901
abi787's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to abi787
Questions?? gear diff
Hi .a lot of useful information.has any body try the 3racing gear diff.
abi787 is offline   Reply With Quote
Old 11-22-2012, 04:17 PM   #902
c-lyon's Avatar
Works great with the stock oil in M06. In M05 300000 or 500000 oil.
c-lyon is online now   Reply With Quote
Old 11-22-2012, 04:36 PM   #903
abi787's Avatar
Thanks.what shock oil and springs you recommend.I'm running on carpet.
Old 11-22-2012, 06:02 PM   #904
DOE BOY's Avatar
Trader Rating: 24 (100%+)
You don't need no stinky shock oil!
DOE BOY is offline   Reply With Quote
Old 11-22-2012, 06:27 PM   #905
abi787's Avatar
Thanks DOE BOY.I'll try dad
Old 11-23-2012, 01:53 PM   #906
Raman's Avatar
Trader Rating: 48 (100%+)
You need 30 to 35 weight Max. I'm running 35 in front and 30 in rear with yellow springs in front and red in rear
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 11-23-2012, 02:57 PM   #907
abi787's Avatar
Thank You Raman.I was thinking 40 / 35.but i'll take your advice.
Old 11-23-2012, 03:11 PM   #908
Raman's Avatar
I was running 40 in front. It was pushing a lot. Little by little I'm going softer in front to add steering.
Old 11-24-2012, 11:09 PM   #909
vivo quevas's Avatar
Trader Rating: 17 (100%+)
I need a suggestions on what to do to my M06. The car was working great the track I race on is large asphalt with good traction but it is a little bumpy and very fast. The car was getting on 2 wheels in the 90*turn at the end of a 100' straight. Front wheel mini's were traction rolling in the same corner when they tried to carry the same speed into the same corner. I would like the car to slide the rear end just a little more. More on power steering on the corner exit the car gets into the corner well but push's on exit. Med fronts soft rears
Tamiya/Exotek EXO6 USGT, Tamiya TB03 GT3, Exotek FR1V2
Roche Rapid 1/12, XRay Speed Merchant WGT
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
"Take an early lead and extend it".(Fast Eddie Janis)
vivo quevas is offline   Reply With Quote
Old 11-25-2012, 02:27 PM   #910
abi787's Avatar
Questions?? DROOP
how do I set DROOP.on M06 with no droop screws.
Old 11-25-2012, 02:40 PM   #911
Raman's Avatar
By putting spacers (orings) inside the dampers.
Old 11-25-2012, 03:01 PM   #912
abi787's Avatar
Can you tell me how many orings or spacers are needed in front and rear?
Old 11-26-2012, 04:11 PM   #913
Need help bad. I'm at wits end. My M06 is very "darty". It will suddenly veer to one side or the other at any time. Sometimes left, sometimes right. Zero toe. Can't keep the thing in a straight line. Cranking the steering Expo to max helps somewhat but that slows the steering down way too much.
I've looked at everything. Servo saver swapped out. All steering and suspension parts look good. Receiver swapped out. Took the gearbox apart and that looks okay.
Obviously this could be a steering problem up front or a traction problem in the rear. It "feels" like the latter, but I can't pin it down. Servo swap is next.
I'm hoping someone has had a similar problem and you will say "your fetzer valve is broken, replace that and you'll be good to go..."
.crispy is offline   Reply With Quote
Old 11-26-2012, 04:15 PM   #914
How much do you want to bring the wheels up? The shocks aren't at too much of an angle, so you'll roughly bring the wheels up by about 80% of the thickness of the "spacer".
Old 11-26-2012, 05:02 PM   #915
Raman's Avatar
I know you said suspensions is good.. But did you check to see if the arms move freely and do not bind. Also is your servo centring?
Tamiya Championship Series Neil Rabara Racing Forum 20908 Yesterday 05:58 AM
EAMotorsports discussion thread BigDogRacing Team and Company Discussions 7633 01-07-2017 08:19 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 02:13 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 08:17 AM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
scirocco14
