Like Tree7Likes
Old 03-04-2012, 07:36 AM   #796
Trader Rating: 76 (100%+)
Does anyone run shock limiters for a lower CG? I'm thinking of lowering my M06 and was wondering what everyone has been running?
MUDVAYNE is offline   Reply With Quote
Old 03-04-2012, 12:02 PM   #797
Raman's Avatar
Trader Rating: 51 (100%+)
Not sure what you mean by shock limiters for lower CG?
Do you mean putting spacers on shock piston inside the damper cylinder?
Thats usually done as a substitute for droop screws since these cars do not have droop screws on the suspension arms.
If you look at step 19 and 20 in manual (page 12 / 13) you will notice that you do install V11 spacer in rear and V3 spacer in front
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 03-04-2012, 04:26 PM   #798
I have done that per the instructions. I'm just wondering if anyone has added a little more? My car seems to lean alot entering the corner.
Old 03-04-2012, 04:32 PM   #799
Casey's Avatar
what springs are you running ?
Casey is offline   Reply With Quote
Old 03-04-2012, 04:44 PM   #800
Kit springs that came in the pro kit. Blue #600 in the front (mediums) and red #200 (softs) in the back.
Old 03-04-2012, 04:54 PM   #801
MikeXray's Avatar
Trader Rating: 73 (100%+)
I'm just finishing up my 06 pro, did anyone else have to shorten the upper front camber link? built to the instructions it was way too long.
I got the carbon towers and sway bars to have some tuning options, need a good low grip setup..
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-04-2012, 05:08 PM   #802
Raman's Avatar
Sway bars should address that... Im presently running without them myself, looking to give to try them out soon.
Old 03-04-2012, 09:42 PM   #803
ruebiracer's Avatar
Guess you didnīt built per instruction, and forgot to cut the plastic parts before measuring the distance...
Today 01:54 AM
I do both, running on stabis and internal spacers. Currently running medium stabi front, last time rear without, normally soft in rear. Shock length from end of the eyes to another currently 57mm. So I was able to reach the Minimum ground clearance for our carpet race 2 weeks ago. (5,2 mm).
I also have to reduce roll, as I run the beetle body...
BR,
Matthias
www.TTSC-Racing.de
www.mst-estenfeld.de/der-loeffler-cup
ruebiracer is offline   Reply With Quote
Old 03-04-2012, 10:12 PM   #804
Raman's Avatar
I run the Giulia GTA body and I noticed that on tight turns the front inner wheel was lifting.. It actually put a huge grin on my face, because the real one did that!
Old 03-05-2012, 06:39 AM   #805
MikeXray's Avatar
Yeah I figured it was something like that, but the link WAS the same length as the picture, and still would have produced a lot of positive camber, I shortened the turnbuckle and used a shorter cup..
Old 04-17-2012, 03:58 PM   #806
Raman's Avatar
Tamiya is releasing new carbon front and rear towers for the trf dampers.. (54361 & 54362) The original carbon towers don't work with the TRF dampers?
Old 04-17-2012, 06:18 PM   #807
snopro31's Avatar
Trader Rating: 36 (100%+)
i am building a m06 and m05 for tcs racing, i cant get a pro version as they are out of stock , for the mo6 what are the hop ups i need to make sure i have to be ready to race fully? does anyone have a starting point set up for pavment and or carpet?
snopro31 is offline   Reply With Quote
Old 04-17-2012, 06:25 PM   #808
flat4's Avatar
Send a message via Yahoo to flat4
upgrading the shocks is a good idea. that's all I have so far, I will be finally be able to race mins after a year its been built.
mo6/ae sc10/2wd slash
flat4 is offline   Reply With Quote
Old 04-17-2012, 07:39 PM   #809
Madulla's Avatar
You need the aluminum rear upright as it breaks very easy and the shock tower to go with it.
Hobbywing North America Team Driver
hobbywingdirect.com
CARCAR VP carcar.ca
Madulla is offline   Reply With Quote
Old 04-17-2012, 09:41 PM   #810
snopro31's Avatar
if i change the rear uprights i need to change the shock tower or your just saying as the carbon one is better?
for the shocks what tamiya set is the set people found better on the mini?
Tamiya Championship Series Neil Rabara Racing Forum 21024 05-21-2017 10:48 PM
EAMotorsports discussion thread BigDogRacing Team and Company Discussions 7641 05-20-2017 05:57 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
