Like Tree2Likes
Old 07-27-2011, 08:29 AM   #661
flat4's Avatar
Send a message via Yahoo to flat4
thanks for the advise, it will be a few more months before I start this little adventure of making the parts. I am think of building a temporary work station with some exhaust fans to keep the dust to a minim, along with a dust mask.
mo6/ae sc10/2wd slash
flat4 is offline   Reply With Quote
Old 07-30-2011, 02:35 AM   #662
Monkeys punk's Avatar
Anyone running the 3 racing shock have an idea of the right amount of spacers I can get in the rear while still being able to get a sensible ride hight. at the moment I have 1.5mm and it's to much. Maybe take them completely out ?
Top Racing Sabre mini
Tamiya m05
Sakura zero
Monkeys punk is offline   Reply With Quote
Old 08-02-2011, 12:13 AM   #663
First meeting with the m06 went well. I am still 1or2 laps off my m05 pace but there is room for plenty of improvement. After initial understeer issues where sorted I just needed to find the pace. Happy with the handling though just need to get used to Thr rear wheel drive.
Tamiya m05
Sakura zero
Old 08-08-2011, 05:53 AM   #664
CSeils's Avatar
Trader Rating: 48 (100%+)
How tight or loose should the gear diff be? I know it's not supposed to be as tight as the gear diff on the M03.
Any suggestions?
You can never go wrong with a Hooters Mini. But Mini Hooters are bad.
--- USVTA National Points Series Member #122 ---
customracingstickers@gmail.com - http://www.rctech.net/forum/painting-designs-graphics-photography/279695-usvta-trans-am-decals.html
CSeils is offline   Reply With Quote
Old 08-09-2011, 12:52 AM   #665
Are you using the oil filled gear diff mate? I tested it last night in the m06 with kit 2000wt oil and it was way too heavy so will need to be 750 or 500 max I would say. Over on the tamiya mini cooper thread there is a few posts about it at the moment if you go back a page or 2. I am going to try again with thinner oil though. As a rule though I would have thought it would need to be way thinner than what you would use up front. Hope this helps.
Tamiya m05
Sakura zero
Old 08-11-2011, 09:57 AM   #666
Hello I have a question. Can I change the wheel base on standard M06? Or is it just a M06 Pro feature?
GT-ONE is offline   Reply With Quote
Old 08-11-2011, 10:25 AM   #667
monkeyracing's Avatar
Any suggestions?
Yup. I haven't had it on a track yet, but the 425 oil I've got in there now feels about right. May go up a little if possible.
Yes. You got the extra bits in the kit to change it, or did you buy it used with no extra parts?
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 08-21-2011, 08:12 AM   #668
flyradio's Avatar
Just brought my M06.
My car always get spin when out of corner
using CVA clear blue damper (short shaft)
What springs should I use (I have set of item 42168)
My local track abit bumpy dan medium traction, and of course what number of oil should I fit.
Team TRF Malaysia
flyradio is offline   Reply With Quote
Old 08-21-2011, 08:24 AM   #669
Madulla's Avatar
What motor are you using?? Tires?? Diff?? Need more info. The stock kit setup works great. Soft springs in the rear med in the front. But tires make a difference, a locked or very packed diff would cause you to lose rear traction, too much motor.
Hobbywing North America Team Driver
hobbywingdirect.com
CARCAR VP carcar.ca
Madulla is offline   Reply With Quote
Old 08-21-2011, 08:58 AM   #670
flyradio's Avatar
Motor: Sport tuned
tires: Tamiya type B both rear n front
Diff: stock gear diff using Tamiya AW grease.
Someone mention using gear diff are perfect for rear wheel drive car. Am I put too much AW?
soft spring in rear? I thought hard spring in rear cause of motor weight. Ive thru M06 pro manual says red spring front, yellow spring rear.
What oil should I use? I want to try TRF VG #50 damper oil. It is good?
thanks Madulla for responding
Team TRF Malaysia
Old 08-21-2011, 01:45 PM   #671
edzinator's Avatar
Default loose rear M06
Originally Posted by flyradio View Post
Motor: Sport tuned
Your track is bumpy? Type B's work in the heat so this is what I would work on, use neon red spring TRF blue Oring seals, TRF 3 hole pistons with 30w for rear 4-5mm ride ht. Use blk/red (soft) or blk/yel (med) spring TRF seals TRF 3 hole piston with 50w for front with 5-6mm ride ht and front swaybar to put traction at rear wheels in corner. CVA shocks are ok, I like to put two blk Orings glued together in the shock bladders. No Orings under shock pistons, use shims.
Take your diff apart clean it and put small amount of AW on each small gear only, if your traction is low this may help you power on better out of corners.
I also found the rear inner camber link mount to be weak, get some ShoeGoo wirebrush the plastic and apply to support, this will help keep camber set. I think one degree camber gives better traction and handles traffic well for me. Where I run the car most of the equipment is spec, tires, tamiya parts only, silver can motors this make setup a most important issue 60/40 (40=driving).
The M06 will fail in traffic if your body rubs the tire when pushed by another car.
Do well Edz
edzinator is offline   Reply With Quote
Old 08-29-2011, 12:54 AM   #672
is there a tamiya belt type diff from a different model that is compatible for the M-06? e.g. ta-05, ff03, 417 etc...
edit:
or a gear diff one that can replace the original? thanks.
one-nil is offline   Reply With Quote
Old 08-29-2011, 01:02 AM   #673
Do you want to simply replace your stock gear diff with another, or do you want to upgrade? If you're looking to convert to belt drive, then you're totally out of luck.
The only gear diff that's not the stock one, is the 3 Racing oil filled gear diff. I've got one that I haven't run yet, but I suspect the stock gear diff will be better overall.
Stab it and steer.
Old 08-29-2011, 02:30 AM   #674
Thanks for your input. It's a just for fun thing. I'm building up from a conversion kit - still in the post - so I don't really have any bits for the m-06. At all. Hence I'm checking out the diff options.
Old 08-30-2011, 12:31 AM   #675
I run the 3 acing gear diff with the kit oil and it's way to thick for rear wheel drive. Even using 30wt shock oil it is too tight I think. I made the car really push as there was no rotation from the rear. Gone back to kit diff and it's perfect.
To be fair I have found a loose kit diff works well for a tight indoor track. 3 racing diff will be good for the m05 but can't get the thing free enough for the m06.
Tamiya m05
Sakura zero
Tamiya Championship Series Neil Rabara Racing Forum 20960 Today 07:10 AM
EAMotorsports discussion thread BigDogRacing Team and Company Discussions 7633 01-07-2017 07:19 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
