Like Tree25Likes
Old 05-18-2011, 08:05 PM   #616
wizzles29's Avatar
Send a message via AIM to wizzles29
Originally Posted by Sydewynder View Post
If you built it per instructions, tamiya tells you to use stiffer springs in the back vs. the front. I would switch the springs around. I would make the ride height in the rear lower than the front. I would put more droop in the front. Also reduce the front camber.
Thanks for the advise, I'll try that this weekend if the changes i made (pulled the top of the shocks in, and spacing out the rear a bit based off a friends set up) dont help.
Proud "powder-puff" racer
King Hobbies/Raceway
The Track @ Harbor Hobbies
wizzles29 is offline   Reply With Quote
Old 05-19-2011, 03:14 AM   #617
MonkeyNuts's Avatar
Does anyone know if the Honda CRZ body fits the M06 at all?
Tamiya FF03 Pro ~ Tamiya M06 Pro ~ Tamiya M05L JCW Coupe
MonkeyNuts is offline   Reply With Quote
Old 05-19-2011, 10:41 AM   #618
superspeed's Avatar
wheelbase is too long, crz works on tt01 and ff03
superspeed is offline   Reply With Quote
Old 05-19-2011, 06:36 PM   #619
clittle's Avatar
The Tamiya body is way too big,
There is a CR-Z body made by a company called Spice that may fit, however you may be out of luck with the space at the rear. There's more rear space than a Mini body but I'm not sure it's enough for the M06.
Latest is a Tamiya TB04 Pro..... Love it!!!
Aussie in Japan!
clittle is offline   Reply With Quote
Old 05-25-2011, 09:02 AM   #620
MonkeyNuts's Avatar
It was the Spice one i was on about, that is what the link was too....
Old 05-25-2011, 02:27 PM   #621
IronRing Racing's Avatar
Does anyone know what the part number is for replacement tops for the 54000 M-Chassis shocks. Specifically the top plastic part that snaps onto the pivot ball. I've googled, searched here, and searched Tamiya's site, including the "Parts Finder", but haven't been able to find them.
Just build an M06 and moving my shocks over from my 5yr old, very well used M03, and realized the plastic is very worn out.
Just in case my description is bad, it's the black plastic parts in the attached picture just below the blue aluminum shock bodies. Third row from the top left hand side.
Thanks in advance.
IronRing Racing is offline   Reply With Quote
Old 05-25-2011, 03:11 PM   #622
RossoTorro's Avatar
Thanks in advance.
I can help you with that.
http://www.rcmart.com/catalog/rc-dam...8-p-18845.html
Tamiya partnumber 53918.
Get these also as they also wear out...
http://www.rcmart.com/catalog/rc-dam...74-p-8136.html
http://www.rcmart.com/catalog/rc-dam...2-p-14524.html
Partnumber : 53574 and 53572
RossoTorro is offline   Reply With Quote
Old 05-25-2011, 11:50 PM   #623
spring71's Avatar
Smile
Hello Mini Racers.
Ride High Speed Gear Set is arrived.
Click Here to check out the new arrivals.
Click Here to check out the parts for Mini
Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
[email protected]
spring71 is offline   Reply With Quote
Old 05-26-2011, 02:53 AM   #624
Could any body post some pics of the new Mazda RX-7 body? Its part number is 58493 and I have seen pics in several webs like tamiyablog. I think it's going to be released very soon because some shops have already listed it.
cybergiber is offline   Reply With Quote
Old 05-26-2011, 12:03 PM   #625
skadoosh's Avatar
Does anyone run a hardcase lipo here? Around 5000mah capacity? Can you take pics?
yesterday is history, tomorrow is a mystery, but today is a gift. That is why it is called the "present."
skadoosh is offline   Reply With Quote
Old 05-26-2011, 05:03 PM   #626
Thanks TorroRosso, or should I say RossoTorro, lol.
Old 05-28-2011, 11:58 PM   #627
monkeyracing's Avatar
Does anyone running their M-06 have an opinion on running a ball diff? I was thinking about installing one. Is it worth it? I figure the gear diff is good on carpet, but wouldn't mind an opinion.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 05-29-2011, 01:43 AM   #628
My opinion for rear wheel drive cars is to keep the diff as loose as possible for maximum rear grip.
With a ball diff you have narrow window of having it loose but not slipping and having it slip. If the diff slips a lot then it'll wear out pretty fast.
With a gear diff there is no slip and you can run it with a thin coating of light grease.
So, I prefer and do use a gear diff in my M06.
Sydewynder is offline   Reply With Quote
Old 05-29-2011, 01:53 AM   #629
Dan
Dan's Avatar
Trader Rating: 46 (100%+)
Syde, still running at Allspeed?
Dan is offline   Reply With Quote
Old 05-29-2011, 12:11 PM   #630
Yep. You coming out?
Tamiya Championship Series Neil Rabara Racing Forum 21198 Yesterday 06:51 PM
EAMotorsports discussion thread BigDogRacing Team and Company Discussions 7672 10-11-2017 10:51 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
