Like Tree5Likes
Old 03-21-2011, 10:39 AM   #571
ruebiracer's Avatar
@ Evoracer:
Thanks for the compliment. Its the std. Tamiya Beetle body from the M02/M04.
Sitting now on my M06. A few posts ago I mentioned it and put the picture I have now as avatar.
BR,
Matthias
www.TTSC-Racing.de
www.mst-estenfeld.de/der-loeffler-cup
ruebiracer is offline   Reply With Quote
Old 03-21-2011, 03:32 PM   #572
Strange a 2 door car would have a Long wheelbase. The old mazda miata was medium.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 03-25-2011, 11:20 AM   #573
Have anyone heard when they will release a propper entry M06?
Im not going to buy a M06 PRO
MatsNorway is offline   Reply With Quote
Old 03-25-2011, 11:37 AM   #574
monkeyracing's Avatar
Not sure of when, but Tamiya does show a part number for an m06 with the Alfa shell.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 03-25-2011, 12:10 PM   #575
Ok good.. Appart from the fact that Tamiya should stick to propper mini bodies.. I know the alfa is small car in RL but seriously..
Its such a crash in style.. Better of with a NSU or beetle or... any suggestions? BMW 1-series?
A Opel perhaps.. they made a "hatchback" with RWD
The Early Kadetts where stunning looking and small.
Old 03-25-2011, 12:56 PM   #576
gtfour93's Avatar
Trader Rating: 22 (100%+)
Opel Ascona, Manta, Ford Escort RS Mk.1 Mexico, RS Mk.2 Brenda, Fiat Abarth 131 and Talbot Sunbeam Lotus would be nice as well.
www.activrc.com
gtfour93 is offline   Reply With Quote
Old 04-08-2011, 03:52 AM   #577
Thumbs up
Hi all,
I've been following this thread for a while now before and after getting my M06. I noticed there has been no mention of Tamiya's BMW M Roadster bodyshell, so I though I would show that it also fits the M06. I managed to pick up one of these shells up from eBay, and you will see the obvious reason I wanted it from the later pics!
We have been experimenting with touring car tyres (the M Roadster kits originally came with larger size wheels than other M chassis kits), so once we find the best tyre combination for my local club I'll put them on the original M Roadster wheels I managed to get a hold of. Please excuse the small mini wheels in the pics!
The body fits over the chassis fine but we had to use some older rear body posts from, I believe an M02, to allow the rear to sit low enough and to line up with the predrilled body and aerial holes.
Here are my pics of the shell, enjoy
Edit: Well apparently I can't post links until I get make more posts
Daaaveee is offline   Reply With Quote
Old 04-08-2011, 07:46 AM   #578
SilverShelby's Avatar
m04 rear post work on m06,thats what i'm using on miata body
also any early datsun bodys would be cool like B210,1200,or a Mazda Rx-4
and YES Its a can motor!!!!!
M03,M05L,M06M,FF03PRO,CC01 Jeep,M03L-Yello Mini
ABC Hobby Goose,Genetic
2011 Memphis winner Mini,FWD
2013 e mergent winner Mini
SilverShelby is offline   Reply With Quote
Old 04-13-2011, 08:44 AM   #579
anyone got a good m06pro setup for a outdoor dusty tarmac track?
Smartypants is offline   Reply With Quote
Old 04-13-2011, 02:15 PM   #580
<PsOp>
Guest
Posts: n/a
I'm deciding on what to get an m05 or m06, never had a tamiya mini before which chassi do you guys prefer and which one is more better to drive? Also which one has more steering in corners?
Old 04-24-2011, 08:54 AM   #581
mbahdukun's Avatar
Default M06 pro foam and tamiya rubber setup on carpet
hi guys
i am little messy confuse to get grip and control on carpet surface using tamiya radial rubber tires : S grip and M Grip
I am quite satisfied setup using foam tire. The car very fast and very controlable, consistent and easy to drive using 13 turn BRUSHLESS....i give comprehensive detail setup , Hope anyone can give me great feed back to tamiya ruber tire setup for me
here are my foam tire setup on M06carpet surface
MWB TAMIYA MIATA eunos roadster
track very small and technical....wide 2 meter only per line and lenght only 16 m, the surface medium grip M05 no problem at all using front m grip and rear m grip tires
the best i can do
front
tire : GQ tire shore 40 truer up to 59mm smaller more thumbs up
shock: touring TRF (need long shaft )
camber : 2"
ride height : 4.5
rebound : put 3 black oring rubber
red blader on shock cap
oil: 25 wt losi (i need fast rebound)
piston : 3 hole
blue spring short old m chasis
thin wheel spacer 4mm
std knuckle front hole use
0 toe
rear
tire : GQ tire shore 37 truer up to 61mm ( shore 35 if no one use tire traction on circuit ( cut 30 mm tire to 26mm using drill and hobby knife cutter)
shock: touring TRF (need long shaft for travel shaft especialy rear)
camber : 3"
ride height : 5.5
rebound : put 1 black oring rubber
piston : 2 hole
grey super hard tamiya touring spring need more hard pressure to make rear sticky
wheel spacer 6mm
alum rear tamiya upper 2 degree (m04 option)
2 degree toe
BEVEL GEAR ...A LOT AW GREASE or ta 03 ball diff (loose) ...or new tamiya ball diff
motor 13 Turn ez RUN
PINION 16 t
BAtTERY TEAM ORCA 6000 60 C
I was use tamiya rubber combine s and m grip ...but not satisfied of the result even i am using slow motor tamiya lightly tune 28 t
here are the setup.....
MWB mx 5 miata
Front
tire : s grip with hard inner (tamiya) ON OUR CARPET TRACK M GRIP MORE GRIP THAN S GRIP, SO I PUT S GRIP ON THE FRONT
shock : touring TRF long shaft
camber : 2"
ride height : 4.5
rebound : put 2 black oring rubber ( need more travel to get grip)
oil: 40 wt losi
piston : 3 hole
blue spring (black blue ) spring comes from M06 pro
0 toe
rear
tire : m grip with medium inner (tamiya)
camber : 3"
ride height : 5
rebound : put 1 black oring rubber ( need more travel to get grip)
oil: 40 wt losi
piston : 2hole
red spring (black red ) spring comes from M06 pro
thin wheel spacer 6mm
2 degree rear
3.5 rear toe
motor 28t lightly tune
batery 4000 30 c turnigy
the car cannot push to the limit and unconstant to drive......i am not satisfied
uneasy to get grip using tamiya radial tire.....if you put inner more inside the tire....you feel grip only couple laps onlY. I PUT TAMIYA SLICK A AT FRONT ....to much steering as well
ANYONE SUCCEED setup using low quality tamiya radial tire?????
PLEASE SHARE with me I SAW TIRE IS THE GOLDEN KEY....How come tamiya made very bad tire for TCS race????
thanks
++Mbahdukun (Hobby bukan profesi)
mbahdukun is offline   Reply With Quote
Old 04-24-2011, 12:00 PM   #582
Originally Posted by mbahdukun View Post
hi guys
I race my M06 successfully on carpet - but not MWB (prefer the quicker steering/change of direction of the SWB)
Here's my setup
SWB with Honda S800 bodyshell
Front
Std 60D Radial c/w kit inserts (for slicks - Sweep 33) no additive
TRF Dampers, 3 hole piston (1 black o ring under piston)
35wt oil
Blue spring
50% rebound
Ride height 5mm
Camber 1.5
1 toe out
Rear
60D S Grip c/w kit inserts (for slicks - Sweep 25) full additive
TRF Dampers, 2 hole piston
35wt oil
Yellow spring
50% rebound
Ride height 4mm
Camber 2.5
2 toe in rear hubs
PaulB is offline   Reply With Quote
Old 04-25-2011, 12:10 AM   #583
mbahdukun's Avatar
Here's my setup
Front
35wt oil
Blue spring
50% rebound
Ride height 5mm
Camber 1.5
1 toe out
Rear
35wt oil
Yellow spring
50% rebound
Ride height 4mm
Camber 2.5
2 toe in rear hubs
what kind motor are u using at....? slow motor like mabuchi 540 j is easy to get right race setup....my motor using 28t lightly tune , ESC LRP qc3 , batery 4000 30 c turnigy uneasy to get right setup
Old 04-26-2011, 12:21 PM   #584
ruebiracer's Avatar
Hi,
Im also not running MWB, but LWB.
But maybe I can give some input, as Im also sorting out problems with spec tires. I made the same experience: on some special carpets, the m-Grips stick better than the S-ones. On tarmac the S-grips cant be beaten, and forget the m-grip in the rain. (like ice)
I always use the hard foam inserts f/r and try in the meantime to use te same tire front/rear, to get more steering and to keep my stuff simple.
On the setups, I went from kit to very soft on a TEC race, now getting back to the harder side on our outdoor track. Currently running on S-Grips all around.
At the weekend I made good experience to reduce travel and droop in the rear, which stabilized the car a lot.
I run the Carson Cup machine with 3000 Nimh, Lipo just for training.
Well, for sure my setup is not 100% perfect at the moment, but maybe you can get some input from it. As I noticed this evening, italso works in the rain, which is always a good sign to me.
I was able to really push it to the limit, and on some 180 curves to throw it around by the brake, to reduce curve radius...
But youre right, with a little more power than 540, its way more difficult to setup the RWD. So I appreciate this thread and the enthusiasts here a lot, lets sort out some good setups together!
BR from Germany,
Matthias
www.TTSC-Racing.de
Old 04-28-2011, 05:59 PM   #585
mbahdukun's Avatar
Originally Posted by ruebiracer View Post
Hi,
BR from Germany,
Matthias
thanks mathias realy appreciate your great setup on tarmac....on our trophical country which humidity and temp very high using slick A tamiya on the rear and hard inner as well
I try LWB on carpet ...the car can flow ....but cannot push to the limit....SWB much better...but realy upset what tamiya tire at MO6 pro
in our club carpet circuit....M05 using F/R M grip realy easy to setup...we can use 28t tamiya motor or black can and the car can handled those motor
Tamiya Championship Series Neil Rabara Racing Forum 20996 04-28-2017 11:21 PM
EAMotorsports discussion thread BigDogRacing Team and Company Discussions 7634 04-12-2017 08:13 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
