Old 02-11-2011, 08:27 AM   #466
Can someone share tips on how to make the gear diff work on the M06? I'm running hobbywing 13T Esc combo.thanks in advance!
seasons29 is offline   Reply With Quote
Old 02-11-2011, 08:51 AM   #467
@Seasons" , you should discribe your diff problem to us . How can we know what you're after ? I run the same combo with a 20t pinon whitout any issues. ... Peter
Rockopa is offline   Reply With Quote
Old 02-11-2011, 09:01 AM   #468
Trader Rating: 18 (100%+)
Default What is the approximate top speed with EZrun 13t
Does anybody know the approximate top speed I should get the EZrun 13t combo. Mine on 20t pinion seems only slightly faster in both acceleration and top speed than the stock mabuchi can that came with my M05 kit (put in the M06).
Is something wrong with my Ezrun?
Thanks for any reply.
lyrragnus is offline   Reply With Quote
Old 02-11-2011, 10:46 AM   #469
Hi, just wanna try out the gear diff app for the M06 and not familiar with how to build the gear diff probably. I've been running the new M05 ball diff with silver can in the 06 and not just want to try the gear diff and see the difference.
Thanks!
Old 02-11-2011, 12:33 PM   #470
monkeyracing's Avatar
Gear diff in the RWD cars is easy. Keep it loose. Build it as the instructions state. If you must, use a little anti wear grease. Just don't lock it up like you would in a FWD car. If you do, it will spin out at almost every corner.
Jim
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 02-11-2011, 03:00 PM   #471
Turn up the timing (~26.5degrees) and punch (level 9). Get the programing LCD box it's easy to do to with it. The 13t hobbywing should be alot faster than a silvercan.
Second thought for a rear wheel drive car you might not want to turn the punch all the way up. It might make the car spin out.
Sydewynder is offline   Reply With Quote
Old 02-11-2011, 03:32 PM   #472
daign's Avatar
Originally Posted by stitchy View Post
if you call san gabriel local to downtown la
daign is offline   Reply With Quote
Old 02-11-2011, 11:29 PM   #473
edzinator's Avatar
Greetings mini racers, I tinker a little in Adobe and adjusted a photo to a useable setup sheet to share.
edzinator is offline   Reply With Quote
Old 02-12-2011, 12:36 AM   #474
stitchy's Avatar
If you're walking or skateboarding, maybe not...but on a good day it's only like a 15 minute drive...which in LA *is* local.
Then again, on a bad day....hmm....I see your point
But I will tell you this, we deal with Tamiyas all day and would never have sold you a 48p pinion to go in your mini
(that was an attempt at humor, not being a smartarse)
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 02-12-2011, 12:43 AM   #475
daign's Avatar
duly noted, I normally order from ampdraw but maybe I'll trek on out there in my 1:1 RC car and check out your goods.
Old 02-14-2011, 08:34 AM   #476
Default Yellow Challenge Bredene Belgium.
Yesterday for the first time in Bredene M06Pro Yellow wire during the Challenge. A satisfied test day for myself and fellow Eli. Both in the A Final.
MRTMD is offline   Reply With Quote
Old 02-14-2011, 06:48 PM   #477
corrversion's Avatar
I was just wondering if you have to use the universal swing shafts with the ball diff in an M-06?
thx
Kyosho Ultima RB5
Kyosho Ultima RT5
CRC Gen XL
CRC Gen X10 LE
Tamiya M-05
corrversion is offline   Reply With Quote
Old 02-14-2011, 06:52 PM   #478
trerc's Avatar
Trader Rating: 89 (100%+)
thx
Ball diff is a worthy upgrade. You wouldn't want the universal swingshafts tho, but the ones that are more like a cvd axle, if you were gonna upgrade from the stock dog bone set up, which there's really no need as they work fine.
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 02-14-2011, 06:57 PM   #479
Thanks for the reply, cvd's is what I was thinking of.
Kyosho Ultima RB5
Kyosho Ultima RT5
CRC Gen XL
CRC Gen X10 LE
Tamiya M-05
Old 02-14-2011, 07:01 PM   #480
trerc's Avatar
Cool, Just wanted to make sure you didnt wanna put these on your M06
http://www.tamiya-model.com/shop/tam...ft-p-4392.html
Tamiya Championship Series Neil Rabara Racing Forum 20908 Today 05:58 AM
EAMotorsports discussion thread BigDogRacing Team and Company Discussions 7633 01-07-2017 08:19 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 02:13 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 08:17 AM
