Like Tree7Likes
Old 02-09-2011, 09:54 PM   #451
ZiG-87's Avatar
Originally Posted by daign View Post
Warning, no matter what the LHS says, the M06 doesnt run 48p
The spur gear isn't available anywhere. I called Tamiya USA.
Maybe it will if you add a little more grease.
I believe metric 48p is also known as MOD 0.6
ZiG-87 is offline   Reply With Quote
Old 02-09-2011, 11:29 PM   #452
monkeyracing's Avatar
More helpful stuff about gears...yep 48p metric is also called mod 0.6. t
The Tamiya 20t hardened pinion is part number 53509. Another good bet is the Robinson Racing steel pinions. They don't wear out like the stock Tamiya ones always do...
1118 Metric Steel Alloy 48 Pitch Pinion 18 Teeth
1120 Metric Steel Alloy 48 Pitch Pinion 20 Teeth
Pretty much any hobby shop should be able to get either.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 02-09-2011, 11:36 PM   #453
Someone at the LHS gave me the wrong pitch Pinion gear in 17t today even though I brough him the stock 20t pinion for reference. Now my spur gear is all chewed up.
All I can find on part numbers is Gear bag 19000183
Anyone got any ideas? this guy really screwed me. Shame on me for not double checking.
Another issue is he gave you a 17t pinion. The holes are for 16, 18 and 20t pinions.
Sydewynder is offline   Reply With Quote
Old 02-10-2011, 01:59 AM   #454
digitrc's Avatar
"Metric 48dp" DOES NOT EXIST!
It's like saying that a centimetre is a "metric inch". You'd end up with a pretty small car if you built one that way. Can I say "Stonehenge"
I'm sure Robinson Racing meant well when they invented that phrase, but since 0.6module gears are closer to 42dp, it's obvious why these two are not even close to meshing.
David Allen - www.digitrc.co.uk - Xevo - Much-More Racing UK
digitrc is offline   Reply With Quote
Old 02-10-2011, 07:14 AM   #455
ZiG-87's Avatar
Yeah, that's kinda what I was getting at there chief.
Old 02-10-2011, 08:47 AM   #456
Guddam's Avatar
you can get away with 64p and metric .04 module, but no way you can get it with 48p and .06 module....
Guddam is offline   Reply With Quote
Old 02-10-2011, 12:25 PM   #457
Whether or nor it is accurate, the term 48p metric is being picked up as a common term in the hobby and the hobby industry. Companies like Kyosho (big) and Horizon Hobby (friggin big) are using it.
The bottom line is that as long as the end user finds what they want, then that's all that matters.
Stab it and steer.
Old 02-10-2011, 12:32 PM   #458
superspeed's Avatar
I'm suprised the LHS guy sold the 17T pinion, maybe he thought it was for m04...
Sorry to see your idler gear is all messed up.
The hardended 20T pinion from Tamiya is good but a bit expensive compare to standard ones from Tamiya and Robinson Racing.
superspeed is offline   Reply With Quote
Old 02-10-2011, 12:42 PM   #459
niznai's Avatar
Yes, and you can see the results above.
People are lazy. It is difficult to try and understand what words mean before using them. If our friend had done their homework he would have known all the intricacies of choosing the right pinion. That doesn't excuse the hobby shop for being incompetent and selling him the wrong part, or the manufacturers for not pointing out clearly enough what you need to understand to make the right decision, but then again, they look after their profits not your convenience.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 02-10-2011, 12:59 PM   #460
superspeed's Avatar
Ask for a discount next time on part since the guy sold the wrong pinion haha. I wonder if that LHS even carry any M06 Pros...
Old 02-10-2011, 04:01 PM   #461
Default ta-03 diff
I installed mine and realized that I was not able to adjust it while it was in the gearbox.
To remedy this problem, I removed the diff, used a cut-off wheel and made a slot in the diff screw.
This way, I can use a small flat head screw driver and tighten or loosen the diff with it in the gearbox.
Just make sure to install the out-drive cup with the pin on the same side. You will have to remove the out-drive cup in order to tighten the diff.
Hope this helps.
Originally Posted by jtsbell View Post
Can anyone tell me how tight to set the ta03 diff? I just got one to put in my 05.
mooby64 is offline   Reply With Quote
Old 02-10-2011, 07:07 PM   #462
Hope this helps.
Actually, you don't adjust a TA03 ball diff. Assemble per the instructions, but using a small amount of antiwear grease on the balls. Then loctite the diff screw and tighten it all the way till it bottoms out. You will need to rebuild every few months cause the diff will loosen some in time. An adjustable diff screw won't help cause you bottomed out the diff screw when assembling.
If you want an ultra tight diff, leave out one of the SMALL cone washers. That will nearly lock it up. One thing about really tight diffs is that they're a little hard on outdrives and if you strip a spline, you're buying a new diff. The parts are not available separately.
Granpa is offline   Reply With Quote
Old 02-10-2011, 10:05 PM   #463
daign's Avatar
troll troll your boat
daign is offline   Reply With Quote
Old 02-10-2011, 10:06 PM   #464
daign's Avatar
it was a 16t 48p I typod.. I have yet to see one in a LHS except at Ultimate Hobbies.
Old 02-10-2011, 11:56 PM   #465
stitchy's Avatar
We do!
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 21024 Yesterday 10:48 PM
EAMotorsports discussion thread BigDogRacing Team and Company Discussions 7641 05-20-2017 05:57 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
