Like Tree1Likes
Old 01-05-2011, 12:09 PM   #256
AudioStylz's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to AudioStylz
Well last night I saw the 1st M-06Pro on the track. I got to the track about 3 hours early and when I was getting my M-05Pro ready for some practice laps I heard another racer do the usal traction compound carpet burnout, I thought "Hey that sounds like a mini.....sort of!" So I went to check it out, it was an M-06Pro. This chassis is FAST!!! real fast. I race an M-05Pro and my friend races an M-03R, we both can do laps in the 13 to 13.4 consistantly and thats usually considered fast. Until we saw the M-06.......this driver who is considered a friend as well, He was running laps in the lower 12s!!!!! Nearly a full second faster over any of the other minis during practice.
During the race he was only able to muster a 12.8 while me and another racer were running in the low 13s all night long. DAMN! Looks like I'll have to save up the pennies and get one now.
Mike Zadler
Associated TC3 VTA & TC6 USGT
Tamiya M-05
AudioStylz is offline   Reply With Quote
Old 01-05-2011, 12:39 PM   #257
Core Creations's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Core Creations
Without sounding like a jerk, I would say you need to work on your M05. I see no reason why the M06 would be faster than a well setup fwd car. (03 or 05). Infact I would be very suprised if the equally well setup 05-06s didn't produce a several tenth difference with the 05 edging the 06.
Most of the time people setup the minis decent And they are very driveable. But there is usually a second a lap or more difference between a well setup car and a car with a great setup.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 01-05-2011, 12:58 PM   #258
Thanks for your info Core Creations. I've been going back and forth on getting the M 06 Pro. I'm gonna keep working on my M 05 Pro.
fx35rc is offline   Reply With Quote
Old 01-05-2011, 01:41 PM   #259
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Originally Posted by BumFacedGoat View Post
i dont know wht its like where you race but i know a guy at my local track got dsq for gluing his arms together instead of screwing them. they said it wasnt built as per the instructions.
Where does is say (req must use screw per instruction in the TCS rules? ....
btw if you used the hop up hinge pins with e clip ,that will hold the arm together without the screws
OVA is offline   Reply With Quote
Old 01-05-2011, 02:06 PM   #260
BumFacedGoat's Avatar
we dont have tcs here its just local rules
BumFacedGoat is offline   Reply With Quote
Old 01-05-2011, 02:43 PM   #261
That sucks, that means you have to use the same electronics that is printed on the manual.
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 01-05-2011, 02:46 PM   #262
Old 01-05-2011, 04:42 PM   #263
Trader Rating: 77 (100%+)
Smile
i had my mo6pro at erics track a few weeks ago...i got smoked by m03s and m05s...thos mini guys are fast...
artoftatt2 is offline   Reply With Quote
Old 01-05-2011, 09:46 PM   #264
AudioStylz's Avatar
Hehe, you just need to work on your car and driving skill some more. Next time your up there holler at Jeff Mo or Bill with setup. You also want to drive this thing smooth, the smoother the better.
Core Creations, I can't agree with you more about setup. I just don't know what more I can do. I'll send you a PM a little later.
Mike Zadler
Tamiya M-05
Old 01-05-2011, 11:38 PM   #265
monkeyracing's Avatar
Argh. The following is copied directly from the 2011 TCS rules.
1. All chassis platforms must be built per the instruction manual. Altering their basic structure and design is prohibited.
13. Any manufacturer’s electronic speed control, radio equipment, servo saver, antenna pipe, antenna mount, pinion and spur gears, ball bearing, tire inserts are allowed in all classes, unless exceptions are noted within class specific rules.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 01-06-2011, 07:19 PM   #266
Has anyone else had some fairly major binding issues in their M-06 gearbox? I assembled the rear portion of the car last night and had to back off every screw in the thing to get it spinning "kind of" freely. Maybe I missed something. I've built a lot of other minis, haven't seen binding this bad before.
Ideas?
Stab it and steer.
Old 01-06-2011, 08:29 PM   #267
caltek1's Avatar
Trader Rating: 33 (100%+)
Jim,
I have not had problems with mine.
Calvin.
caltek1 is offline   Reply With Quote
Old 01-06-2011, 09:42 PM   #268
I'm just going to keep it loose and run it on slow dummy motor for a while. Maybe that will loosen things up. If that doesn't work, it's dis-assembly one screw at a time until I find the culprit.
Stab it and steer.
Old 01-07-2011, 01:22 AM   #269
choon meng's Avatar
not agree with ur opinion. it's depend on the over all condition.
if running in hi-traction surface like indoor carpet, low out put motor( mabuchi silver/black can motor). a rear wheel drive have a best advantage compare with a front wheel drive. i have run my m04 with silver can motor to smoke out those mo3 with black can mabuchi.
no doubt , the m04 is very hard to drive n setting.
hope this new m06 will solve those problem. i have build my m06 now. hope it will perform well in tarmac race track.
happy rcing.
choon meng is offline   Reply With Quote
Old 01-09-2011, 08:22 AM   #270
t4m1y4niac's Avatar
anyone run on carpet track with foam tires??
i need some hint to set up on carpet trackwith foam tires.
SABRE S4 by TOP RACING....
t4m1y4niac is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 20922 Today 02:41 PM
EAMotorsports discussion thread BigDogRacing Team and Company Discussions 7633 01-07-2017 08:19 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 02:13 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 08:17 AM
