Like Tree25Likes
Old 04-24-2017, 09:39 AM   #2071
Send a message via AIM to GuyIsDamGood
Originally Posted by Raman View Post
Well I finally competed in my first TCS race!
For concours my Alfa almost won. The judge later told me that he loved my car and it was a tough decision. In hindsight, I should have brought my shelf queen body.. my race body was already battle worn.
For the races, cars were separated into two races. I was in the second race and the one and only M06 hehehe. Watching the first race, I quickly realised who the top drivers were. There were two guys running under 19 second laps… they were both outstanding drivers
First heat I had a bad start. When I pulled the trigger car darted to right wall. I thought it was a radio glitch, then I thought my left rear wheel had come off.. those grey TCS wheels are hard to see for these old eyes. Once I realised the car was in one piece I drove it like I stole it and finished in 3rd place.
Second heat, I was 3rd in starting grid. Car tried to dart right again but I caught it this time and ended up second real quickly. The guy ahead of me was really quick had a few laps under 19 seconds (very experienced driver) but I was quicker overall. So I ended up first and getting TQ!!!!
In A-Main I started out in 4th position and overtook the guy in 3rd. The two top guys from other heat proved to be tough to catch. They both had more top end speed. They were also able to get consistent lap times in mid 18s and I was low 19s and high 18s. The race from there though was just us.. weaving and bobbing through the field.
So I finished 3rd place.. my first ever podium finish. As a prize I received the new MX5 Mazda Miata body..
Congrats to you! Glad you're having fun.
GuyIsDamGood is offline   Reply With Quote
Old 04-24-2017, 09:45 AM   #2072
I think I've fixed the steering problem.....?
It's the servo.
-I adjusted the servo horn a few degrees(°) on the servo. Then it ran 95% straight.
Old 04-24-2017, 11:44 AM   #2073
firefoxussr's Avatar
Originally Posted by GuyIsDamGood View Post
Anyone having problems with this chassis running in a straight line?
-Or is it the Servo?
I do. my car pulls to the left noticeably under power. this may be an exaggerated thing cuz i'm running oversized/wide/non-standard wheels.
Parking lot heroes: M06, TA05sw, XV01, XRay T1, SC10B
Partially disassembled: HPI Cup Racer, FGX, M04, TA02, TA05 IFS
Newest acquisitions: A210SS Exige, HPI MX-5, Tamiya F40
firefoxussr is offline   Reply With Quote
Old 04-24-2017, 01:09 PM   #2074
Raman's Avatar
Trader Rating: 56 (100%+)
The kit chassis set up gives the car a left side weight bias. Weight of esc and receiver vs steering servo. This will make the car veer to left.
You can address placing weight on the side of the steering servo.
Some also move the esc to battery compartment / channel.. works if you run a short pack
Raman is offline   Reply With Quote
Old 04-25-2017, 12:15 AM   #2075
Raman's Avatar
Photographer from event sent me an awesome photo of the car in action
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Old 04-25-2017, 09:37 AM   #2076
Hey firefoxussr.
Check the Tie-Rods. They could be uneven. Or it could be the servo (the M-06 is a chassis to bump around...Ha Ha!).
Old 05-01-2017, 06:29 AM   #2077
Interesting, currently I have the battery in the forward-most position and the ESC is mounted above the motor. The receiver is mounted in its factory position, perhaps migrate that to the right side too.
Hey firefoxussr.
I see it sidewinder-ing at low speeds, so I'm thinking some sort of alignment problem.
Thanks for the answers, here's a pretty picture of running it yesterday:
Old 05-02-2017, 03:50 AM   #2078
foampervert's Avatar
Send a message via MSN to foampervert
Default reasons for a car that turns on acceleration
Hiya!
RWD cars are more affected and the following are possibilities that you need to slowly weed out. My car does occasionally do what you describe but then I'll take the car down to the pits and discover something or other.
-Uneven Droop
-Uneven length roll bar standoffs
-too tight roll bar holders
-bent roll bar
-tires with uneven wear/uneven grip (I rotate my tires left to right after every run)
-unevenly built shocks (shock lengths, oils, pistons, rebound should be same left and right)
-chassis tweak (due to hard impacts, might be warped)
-arms or joints are not moving freely... I had a shock ball joint forced into the suspension arm and caused the arm to be less free, it caused the car to become very inconsistent)
-ball bearings are worn (causing more drag on one side then the other)
-if you use tamiya high torque servo saver, it is somethings caused by a servo saver that is worn out. (consequently, I always use kimbrough type servo savers)
I find that my usual cause for inconsistent handling, as you have described, is due to worn bearings, suspension not moving freely and poorly adjusted shocks.
hope this helps you.
firefoxussr likes this.
During heats, i use durex for both front and rear, with Hard inserts.
Sorex, i meant Sorex.
foampervert is offline   Reply With Quote
Old 05-02-2017, 08:16 AM   #2079
Hey firefoxussr; good job on the 911 Body.
Hey foampervert; I agree. It could be one or all of the problems you mentioned that will cause a chassis to not run straight.
I knew it was a servo problem because it will pull to the left or right on and off power.
-it ran straight last year (Spring, Summer and Fall).
New Servo time.
Old 06-09-2017, 01:35 AM   #2080
mcmattila's Avatar
Hey m06 gurus! I just bought an r-spec gear differential from our club, and was wondering which oil to fill it with (it's going in the m06). I can get some associated oils locally, in cst scale. There's 1k,2k,3k,5k,7k,10k,20k,30k,60k,80k and 100k fluids available. Would any of those work? I'm running on carpet.
mcmattila is offline   Reply With Quote
Old 06-09-2017, 01:54 AM   #2081
gigaplex's Avatar
You probably want to start somewhere in the 2k to 10k range.
gigaplex is offline   Reply With Quote
Old 06-09-2017, 10:16 AM   #2082
You mean Spec-R diff (because some one'll pop up otherwise to say R-spec M06s just have non-fluid diffs lol). I ran mine with 2k on gray carpet. Anything thicker made it too drifty. I got mine dialled with springs and tyres more than the diff though I feel.
Mini35 is offline   Reply With Quote
Old 06-10-2017, 01:48 AM   #2083
mcmattila's Avatar
Thanks for the input gigaplex and Mini35!
And yes, I did mean Spec-R!
Old 06-17-2017, 06:05 AM   #2084
Bored with M05, had my daughter race the M06 today. Surprisingly gave a good run, lot's of banging
Video of the banging here. This time it is the M06 making the M05 spin out hehe. Sorry for the crap quality. https://youtu.be/9ivRK8vZJuc
kwkride likes this.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is online now   Reply With Quote
Old 07-06-2017, 07:24 AM   #2085
JatoTheRipper's Avatar
Does anybody know the part number for the polycarbonate / Lexan body for the Lowride Pumpkin?
Leaf Spring Mafia - Member #1
https://www.shapeways.com/shops/leafspringmafia
https://www.facebook.com/LeafSpringMafia
https://www.instagram.com/LeafSpringMafia
JatoTheRipper is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 21195 10-14-2017 12:02 PM
EAMotorsports discussion thread BigDogRacing Team and Company Discussions 7672 10-11-2017 10:51 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
