Like Tree25Likes
Old 01-03-2017, 04:35 PM   #1966
gigaplex's Avatar
Originally Posted by eR1c View Post
I am installing the VII suspension arms on my M06. can someone tell me, is this the correct orientation for M06 using Medium wheelbase?
thanks
According to the manual it's the correct orientation for all wheelbase settings.
gigaplex is online now   Reply With Quote
Old 01-03-2017, 07:12 PM   #1967
Raman's Avatar
Trader Rating: 56 (100%+)
thanks
Thats how I have mine installed, I run MWB as well
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 01-03-2017, 07:36 PM   #1968
eR1c's Avatar
Thanks Gigaplex and Raman,
That is what I kind of thought but the instructions for the VII suspension arms are more specific for the M05 model and are a bit more vague for the M06. ...thanks guys!
eR1c is offline   Reply With Quote
Old 01-03-2017, 07:45 PM   #1969
gigaplex's Avatar
I was actually referring to the M06 manual rather than the instructions that comes with the arms.
Old 01-04-2017, 09:40 AM   #1970
Trader Rating: 28 (100%+)
Anyone ran the HIP Datsun 510 body on the M06
littlehonda14 is offline   Reply With Quote
Old 01-04-2017, 09:43 AM   #1971
Raman's Avatar
I haven't run it but it fits just fine. The only cup racer body that will not fit well is the Lancia Stratos, because the front is so low
Old 01-04-2017, 09:55 AM   #1972
eR1c's Avatar
ah/thanks.
Sounds like someone else already answered, but I own the 510 body (as well a a few other of the "true ten" hpi bodies ...so if you need any measurements..
Old 01-11-2017, 08:27 AM   #1973
firefoxussr's Avatar
And the motor will stick out of the back. But other than that....
Parking lot heroes: M06, TA05sw, XV01, XRay T1, SC10B
Partially disassembled: HPI Cup Racer, FGX, M04, TA02, TA05 IFS
Newest acquisitions: A210SS Exige, HPI MX-5, Tamiya F40
firefoxussr is offline   Reply With Quote
Old 01-11-2017, 01:10 PM   #1974
Raman's Avatar
That's the Stratos way.. I'm still racing with the KB Stratos in USGT.. Handles pretty darn well
Old 01-21-2017, 03:03 AM   #1975
mcmattila's Avatar
I got my M06 finished last night and took it for a first spin. Although "spin" is a bit misleading, as my car won't oversteer even a bit, and I'm not even using any traction compound.. I'm running a stock motor though, so that might be my "problem". But, at least it's controllable! I'll have to dive into the controller settings later, and buy that competition motor when they come back in stock, but so far I'm really liking this.
The first run was with a borrowed BMW body, Alfa Romeo coming soon™.
mcmattila is offline   Reply With Quote
Old 01-21-2017, 01:04 PM   #1976
ruebiracer's Avatar
Welcome Mc Mattila,
good that the first run was successful!
I see you ran S-or M-grip tires rear, radial in front! that is some tire combo giving you quite much understeer, but for sure good control and no oversteer tendency. Even with a more powerful motor, this impression would not change much. Usually, I run S-Grips front and rear on my M06. Then I can reduce steering by Radio settings, but have good turn in.
Will you attend races with your new chassis?
Kind regards,
Matthias
www.TTSC-Racing.de
www.mst-estenfeld.de/der-loeffler-cup
ruebiracer is offline   Reply With Quote
Old 01-21-2017, 02:08 PM   #1977
mcmattila's Avatar
Thanks ruebiracer!
Yeah, I built the chassis as per the manual, so everything is stock (apart from some Yeah Racing hops), and the tires are as you said radials in the front and S-grips in the back. I don't currently have another pair of S-grips, only radials and slicks. But I'll keep your advice in mind when ordering new sets! I could also experiment a bit with the tires I have and see what I can come up with.
As for racing, I'm not currently looking at signing up for the league stuff as I'm very new at the hobby and don't have as much time for practice as I would like to. And I would also need that comp motor to qualify for the racing, anyway. That being said, I'm doing hot lapping and racing for fun in our club, so it's not just driving aimlessly.
Old 01-22-2017, 07:09 AM   #1978
Scottrik's Avatar
Trader Rating: 245 (100%+)
Just finishing my M06 build (first of two). A couple questions come up.
1) Do the gold springs go on the front and silver (softer) on the rear? Would seem correct...the manual "picture" did not adequately match either spring I've got. You'd think since thbuiltey're different colors they could have called out which color...
2) I built the camber link/upper arms and tie rods exactly to the specified length (gap between ball ends). Eyeballing things the rear looks like the camber ended up in the ballpark, zero to maybe slightly negative camber. The front, however, was no where nearly close in either camber or toe. I ended up turning the ball ends together on the camber link and it MIGHT be to zero camber, possibly still a little bit positive, I haven't tried to do anything with the tie rods yet because screwing the camber links in has brought the toe pretty close to zero. Similar experience? Obviously I can disassemble the camber links and cut some material off the backside to get more adjustment...provided the threads are not bottomed out in the end.
3) I was surprised (well...maybe not) that the first M-Chassis with adjustable camber doesn't come with turnbuckles. I know these end up being packaged with a sharp eye on cost, but come on Tamiya...I'd pay a couple bucks more for the ease of adjustment. What are others doing for turnbuckle links?
4) What are folks using for servos?
Thanks in advance for any input.
Scott
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 01-22-2017, 11:14 AM   #1979
Raman's Avatar
Scott
Hi Scott,
1. Gold are super soft so they go in front to minimise under steer. Silver are soft I believe and go on rear. Unfortunate on the basic kit Tamiya throws in those useless dampers and springs.
Pick up a set of aluminium dampers, they will make a world of difference. Yeah racing sells a set for $20... Make sure they are the 50mm.
http://www.rcmart.com/yeah-racing-xpress-shockgear-50mm-damper-touring-p-36295.html?cPath=389_390
If you want to stick with Tamiya, the TRF 54000 dampers can be found for a good price ($39) in Hong Kong stores
http://www.rcmart.com/tamiya-54000-50mm-mchassis-aluminum-damper-pr-25921.html
2. A good trick for setting up the camber and steering tie rod is to use these spacers in between the links (Tamiya 53539)
http://www.tqrcracing.com/shop/product_view.asp?p_id=621
The blue are in increments of 1,0
mm and the silver are in 0,5
So for a distance of 1,5mm you use the thinnest silver and blue, then tighten the rod ends until they are snug. Takes out all the guess work
3. The turn buckled came with the Pro and R spec chassis which are both discontinued.
Old 01-22-2017, 11:33 AM   #1980
Scott
In respect of your camber issues on the front did you remember to trim 2mm off each BB15 adjuster before measuring the gap between them - it's an easy step to miss and leaves the upper link 4mm too long which gives you huge positive camber.
Mini35 is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 21198 10-19-2017 06:51 PM
EAMotorsports discussion thread BigDogRacing Team and Company Discussions 7672 10-11-2017 10:51 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
