Like Tree25Likes
Old 12-22-2016, 11:06 AM   #1951
Raman's Avatar
Trader Rating: 56 (100%+)
Originally Posted by fliedlice View Post
you are right about the power....i have a very torqey motor so lots of power....i have adjusted the expo on my radio for softer start and trying to be smoother on the throttle.....i also sauce the rears lots to have good traction......no sauce in the front for now until i can fix the spinning out issue......straight line speed is awesome!! i noticed when i am turning right it seems fine but its when i try punching to the left it spins out...so next question is what setup stuff can i try ??? i have 1deg tow out in the front and 2 deg rear toe in...
thanks....
This is a weight transition problem.
Pick the car up by front shock tower and see which tyre lifts off the ground first. It should be even. Do the same for the rear.
Next Pick the car up front centre and rear centre and see if the car tilts to one side. If it does, you need to add weight to heavier side, or reduce weight on lighter side
you're turning better right then left, then you have a may have less weight on left side than right. You may a
Raman is offline   Reply With Quote
Old 12-22-2016, 11:50 AM   #1952
Raman's Avatar
Originally Posted by eR1c View Post
That would really suck, ...go into the finals using a tire you may not have been using all year long. ...w/ the M class tires are 1/2 the battle. (well maybe 20% of the battle, ...shocks, good driving and plenty of other factors).
I'm not sure what's the motive behind the change after all this time.. GT1 / GT2 I understand, there are much better tyres out there. Having never ran the spec m chassis tyre, I can only guess it's the price?
If they make a change, I hope it's for the Shimizu inner mesh series.. They are awesome and give plenty of shore option. The lower 55D profile would also slow the cars down a tad
Old 12-22-2016, 12:46 PM   #1953
Laguna Bozo's Avatar
The problem with the TCS-spec 60D super grips is the flexible sidewall. That's why all the chatter about side wall gluing. Finally, Tamiya is running out of the last big warehouse order of super grips, and Fred is listening to all the M-chassis racers wanting a better tire. Probably helps that their experience changing F-1 tires to Pits worked out really well. The TC drivers aren't too enamored with B3's either, most using Sorex except for TCS. So, there may be lots of Tamiya racing tire changes coming soon...
Craig Richter
Laguna Bozo is online now   Reply With Quote
Old 12-22-2016, 12:59 PM   #1954
Raman's Avatar
Well I hope m chassis also switches pit Shimizu 55D inner mesh.. Less profile than the 60D Classic and a lot more shore options
PS-0430 RACING INNER MESH (24R) 2
PS-0431 RACING INNER MESH (27R) 2
PS-0417 RACING INNER MESH (30R) 2
PS-0433 RACING INNER MESH (33R) 2
PS-0434 RACING INNER MESH (36R) 2
PS-0436 RACING INNER MESH (40R) 2
PS-0435 Special Rear tyre super soft
Old 12-29-2016, 11:58 AM   #1955
eR1c's Avatar
I have a question about shocks for the M06,
I was going to use the Big bore TRF's on my M06. However when I opened them up and looked at the instructions it say that for an M06 you need 2pcs of a 34mm piston (the standard/stock ones seem to be about 24mm).
So, do I need to get the longer pistons OR can I use the longer plastic shaft piece that attaches to the end of the piston and the ball joint on the chassis outer arms (as opposed to the shorter ones) to gain the extra shock length?
thanks.
I get that this may become more apparent once I get to the shock portion of my build, right now I am only at the gearbox (waiting on a set of ball bearings to arrive) before I can move much further.
eR1c is offline   Reply With Quote
Old 01-01-2017, 03:23 PM   #1956
eR1c's Avatar
Progress thus far,
-I am familiar w/ the metal gear box plate and potential motor arcing ...however I plan to use a speed passion motor I have which has the wire ends coming directly out of the endbell (not the side like most motors)
Old 01-01-2017, 03:24 PM   #1957
eR1c's Avatar
oops forgot the photo-
Old 01-01-2017, 05:22 PM   #1958
tony gray's Avatar
For anyone who may not have seen it in the Mini Cooper thread. Another new M-Chassis.. Xpresso M1 (210 mm) RWD, due in the next couple of weeks.
tony gray is offline   Reply With Quote
Old 01-01-2017, 11:02 PM   #1959
Raman's Avatar
Looks kind like a drift chassis
Old 01-02-2017, 06:45 AM   #1960
Looks really cool. Hope for a fun article by the RC-mini guys
MatsNorway is offline   Reply With Quote
Old 01-02-2017, 12:42 PM   #1961
Raman's Avatar
I only installed the motor plate on gear side for that reason. I thought about having someone counter sink the holes so that screws would not be / or come into contact with motor tabs, but never got around to it
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Old 01-02-2017, 01:20 PM   #1962
eR1c's Avatar
as you can see from this photo the motor wires won't be anywhere near the plate. I really wanted the plate for added cooling and strength. W/ my M05 one of the biggest things in keeping it competitive is having a cool running motor.
Old 01-02-2017, 01:27 PM   #1963
Raman's Avatar
Plus it looks stunning .. Mine is all scratched up from when I used to race on asphalt.
I've been tempted to buy a replacement now that I race on carpet.. Can you say OCD lol
Old 01-03-2017, 04:14 PM   #1964
eR1c's Avatar
Yeah, I figure it will get scratched up. I don't I don't mind that so much. LOL
Old 01-03-2017, 04:28 PM   #1965
eR1c's Avatar
I am installing the VII suspension arms on my M06. can someone tell me, is this the correct orientation for M06 using Medium wheelbase?
thanks
Tamiya Championship Series Neil Rabara Racing Forum 21198 Today 06:51 PM
EAMotorsports discussion thread BigDogRacing Team and Company Discussions 7672 10-11-2017 10:51 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
