Like Tree24Likes
Old 12-17-2016, 08:39 PM   #1936
Raman's Avatar
Trader Rating: 56 (100%+)
Just rebuilt front shocks.. One set with 55 and the other with 50.. Both with red springs. Hoping I can get to track wed to test out
Raman is offline   Reply With Quote
Old 12-19-2016, 11:42 AM   #1937
eR1c's Avatar
My experience is the opposite. Won't track straight, give it more toe-out.
. -LOL, that is what I love/hate about the Tamiya M Chassis cars ...there are many ways to get your car to run well. ..we all find slightly different paths. Thanks, i'll be sure to keep Toe at stock for the initial build then.
ah, cool, let us know what you find.
I am still waiting for my M06 to arrive. Its been 1 week, hoping it will be there when I get home from work.
eR1c is offline   Reply With Quote
Old 12-20-2016, 10:29 AM   #1938
eR1c's Avatar
Look what arrived last night!
Old 12-20-2016, 01:37 PM   #1939
Raman's Avatar
Nice
Old 12-20-2016, 03:16 PM   #1940
Let the frustration begin
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 12-20-2016, 05:34 PM   #1941
eR1c's Avatar
What?!
Ha, I am ready.
Old 12-21-2016, 01:04 PM   #1942
eR1c's Avatar
Raman,
how did those premounted tires work for you? Have you had a chance to use them? (You got the slicks, right)?
Also,
I have a question for everyone.
I am going to start my build tomorrow AM, ...the first part of the build is the gear box.
I have two questions:
1) Should I run the stock gearing OR the TA03 Ball Diff (I have both)
2) To begin, how loose or tight should I run the gearing? Because this is RWD and the front wheels spin freely I don't really have any point of reference ...maybe an F1 is the closest thing. Per the F1 I run, I like my diff' a bit on the looser side (I find it prevents the rear from spinning out easily).
Thanks!
I am excited to get going on this one.
Old 12-21-2016, 02:10 PM   #1943
Raman's Avatar
No I heard that there maybe a new spec tyre for TCS.. So I'm not going to buy them until the TCS race gets closer.
Regarding the diff, which is lighter on weight, the TA03 or stock.. They could be close since the TA03 has the pot metal casing.
My diff: If I turn the right wheel, the left turns in the same direction and vice versa. So I run mine tight!
I have always ran mine this way, so I could be missing something by not trying it looser.. But judging by the cars ability to go full throttle in sweepers.. I think I'm doing something right.
Old 12-21-2016, 02:28 PM   #1944
eR1c's Avatar
really! ....any word on what it may be ??
Thanks for the info on the diff', i'll start w/ tighter to begin then.
Old 12-21-2016, 06:15 PM   #1945
Raman's Avatar
No.. this is what fred wrote: we are still looking at a NEW tire for the Series for certain classes. However, this has taken longer than expected, so we will continue to use the same tires for the regional races. Implementation of a new spec tire may not happen until the 2017 Finals
When I first read this, I assumed it maybe for the GT classes.. but a guy at my track said.. its m chassis too.
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Old 12-21-2016, 09:45 PM   #1946
Default spinning out
hey guys,
i am just wondering what are the causes for the car to spin out either to the left or right when you punch it ??? thanks.
fliedlice is offline   Reply With Quote
Old 12-21-2016, 11:02 PM   #1947
gigaplex's Avatar
Originally Posted by fliedlice View Post
hey guys,
It's a rear wheel drive car. That'll generally happen when you've got too much power or not enough rear grip. You'll either need to change your throttle control behaviour or change the setup.
gigaplex is offline   Reply With Quote
Old 12-21-2016, 11:20 PM   #1948
you are right about the power....i have a very torqey motor so lots of power....i have adjusted the expo on my radio for softer start and trying to be smoother on the throttle.....i also sauce the rears lots to have good traction......no sauce in the front for now until i can fix the spinning out issue......straight line speed is awesome!! i noticed when i am turning right it seems fine but its when i try punching to the left it spins out...so next question is what setup stuff can i try ??? i have 1deg tow out in the front and 2 deg rear toe in...
thanks....
Old 12-22-2016, 10:49 AM   #1949
eR1c's Avatar
That would really suck, ...go into the finals using a tire you may not have been using all year long. ...w/ the M class tires are 1/2 the battle. (well maybe 20% of the battle, ...shocks, good driving and plenty of other factors).
Old 12-22-2016, 10:51 AM   #1950
eR1c's Avatar
What motor are you using? I mean yeah if you have a 13t in there and are punching it the car will probably spin out. I haven't driven my M06, but can say that w/ F1's which are rear wheel drive if you punch it even w/ a stock 21t it will spin out.
Unless you move to a lower powered motor I would finesse the car a bit more ...don't just "point and shoot".
Tamiya Championship Series Neil Rabara Racing Forum 21158 Yesterday 01:41 PM
EAMotorsports discussion thread BigDogRacing Team and Company Discussions 7669 08-08-2017 05:39 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
