Like Tree25Likes
Old 04-04-2016, 01:50 PM   #1816
ruebiracer's Avatar
Originally Posted by foampervert View Post
We aren't allowed to glue the sidewalls or tire surface... Technically, no other "anti-traction roll" techniques like thick silicon oil either (that's not preventing people from using it of coz)
I'd rather just tune it out or drive differently. I do like how fast they car is through turns... I just need it to be a tad less tippy.
I can send you the editable PDF and my setup via email. The PDF file is over 1mb and cannot be posted here. Just pm me your email address.
Alexander
Hi Alex,
sorry for not answering earlier, as promised!
From looking at your setup, there are 2 things not clear to me: light blue spring: Is this the milky blue one from TC set? Personally, I only use the black M06 set only or the comparable hardness Ta03 ones in fluorescent colours.
Did not make good experiences with M05 harder springs.
Your tire insert rear is custom made?
And your upper arm spacer is 2mm in front. This could be maybe too much for my taste. I run since 2 years 0,7mm and like it. (Did not change back to stock) And you run 6mm hex front and 4mm in rear? Could be interesting to test it the opposite way round (Porsche style). I usually run same thickness f/r on my M06. From looking closer on your traction roll, can you spot if the roll occurs more from the rear axle? Id guess so. I agree with Raman, to try a softer spring rear and / or a harder up front.
Camber could also be an option to increase it to -1,5 - -2 in rear. Furthermore, do you have the stabilizer set? This could aslso help you!
And with all TC at the moment, even the Tamiya ones, I would rethink to use TC dampers with the higher Carbon towers on the M06, and go for shorter (mini) dampers instead with M06 lengths. And for the rear damper piston,
I only use M06R 1,3mm holes since some time.
In the end I can only guess what will maybe help you, sorry.
I never drove an Brushless in my M06, so my experience is limited on Cupmachine power output!
More torque is always more difficult to tame down!
But as your problem occurs off power, you are on the right way, Id say!
If you test some of the tings, please let us know here!
I lack the time on M06 testing at the moment, but its always so much fun to get this beast going. (when it works)
Kind regards,
Matthias
www.TTSC-Racing.de
www.mst-estenfeld.de/der-loeffler-cup
ruebiracer is offline   Reply With Quote
Old 04-05-2016, 01:56 AM   #1817
foampervert's Avatar
Send a message via MSN to foampervert
Default quirky little bastard...
Originally Posted by ruebiracer View Post
Hi Alex,
Kind regards,
Matthias
Thanks for your thoughts Matthias,
We don't have enough time to test, before the race. So we need to make assumptions and develop car setups based on theories.
I appreciate your inputs and we will try them at our next carpet race. Our organizer has decided that the next race will be on an outdoor painted race surface... I just hope it doesn't rain...
-Alexander
During heats, i use durex for both front and rear, with Hard inserts.
Sorex, i meant Sorex.
foampervert is offline   Reply With Quote
Old 04-08-2016, 02:24 PM   #1818
C5R01's Avatar
Send a message via Yahoo to C5R01
Need some help. Could someone post a pic of their M06 with the TCS Reedy 21.5 Brushless motor mounted in it. Looks a little tight back there and i need ideas. Thanks in advance.
Current Cars:
Tamiya Garage:TB03; TA05V2-IFS; 414X #60;F104 V2;TA03r-s:TA03F:TA03R: FF01: FF03: M01: M03: M06: 1/14 Mercedes Semi truck- w/Reefer trailer ( fully functional): Tamiya Juggernaut 4X4X4, Tamiya RC Freightliner Cascadia Evo.; Honda City Turbo WR-02C; TRF102 F1
OTHERS:Kyosho 1/8th scale nitro Corvette C6R: Yokomo GT4 nitro, Slash 2WD,TA SCm5
C5R01 is offline   Reply With Quote
Old 05-13-2016, 10:02 AM   #1819
billjacobs's Avatar
Trader Rating: 54 (100%+)
Default tamiya m06 with reedy 21.5 motor
get a Yeah Racing YA-0463BU shim set to shim the motor 1mm. that way the tabs clear the gear plate. you can get it on ebay for about $11 shipped.
Current racing stable: xb4, sct410.3, b6, t5, t3 '12, x1, MGT7 :: Sponsored by my day job.
billjacobs is offline   Reply With Quote
Old 05-14-2016, 08:03 AM   #1820
Default check it!
Dear RWD friends,
I've just rebuilt my M06 as a MWB... but have yet to try it out. suspension settings are similar to my SWB. Will update when the next TAC comes around.
enjoy! and keep trucking, from the rear!
Alexander
TAMIYA M-06 Thread-img_9812.jpg   TAMIYA M-06 Thread-img_9811.jpg   TAMIYA M-06 Thread-img_9787.jpg   TAMIYA M-06 Thread-img_9786.jpg   TAMIYA M-06 Thread-img_9785.jpg
Old 05-14-2016, 08:06 AM   #1821
Default moe pics
wing is from the Datsun 280zx shell
Waste not, want not...
TAMIYA M-06 Thread-img_9784.jpg   TAMIYA M-06 Thread-img_9782.jpg   TAMIYA M-06 Thread-img_9779.jpg   TAMIYA M-06 Thread-img_9778.jpg   TAMIYA M-06 Thread-img_9777.jpg
Old 05-18-2016, 08:52 PM   #1822
Default m-06 gearing
Hi every body I got a new m-06 with a lightly tune 28t tamiya motor but it lacks of speed for my taste .I got a castle sidewinder 5700kv in my ff04 evo and I really like the feel of it and the simplicity of ajustement of it .I would like to put one kit on my m-06 but I can't decide if I put the 4600kv or the 5700kv and what gearing I will need to keep it don't overheat .I got too the fast gear set from 3 racing to give me more possibility of ratio.Thanks have a nice day.
op4dc4 is offline   Reply With Quote
Old 06-06-2016, 07:14 PM   #1823
funked1's Avatar
nm
XRAY T4 '17 VTA / Tamiya M07 / Tamiya Euro Semi / Speedworld Raceway
funked1 is offline   Reply With Quote
Old 06-14-2016, 11:35 AM   #1824
Recently i started to drive more frequently with my M-06 with a nissan S15 body.
The very first time i drove the car it was dialed and felt great on a very high traction carpet track.
In the meantime M-chassis started to hit the track at my local club but so far i'm the only one with a rear wheel drive M-chassis.
I even let a clubmember drive my M-06 at the Belgian tamiya race at our club, the young fellow was second fastest with the rest of the M-05 drivers following at 0.4 seconds of the fastest laptime from him.
Only one guy (well known for his great driving skills and his knolledge to setup a M-05) was able to drive even faster with his M-05.
The fastest laptime was about 13.7seconds (M-05), second fastest latime was 14.1seconds (M-06) and third fastest laptime was 14.5seconds.
They all run with a brushed carsson cup motor (Rpm is arround 19-20.000), at this moment i'm running a lightly tuned motor (16.500rpm) in my M-06 chassis and so far my fastest laptime is 14.56seconds.
My car is basically a standard out of the box car, with the exception of M-chassis TRF dampers (54000), M-05 ball diff and 1.5 rear toe-in uprights from my M-05PRO.
Been running M-grip tires at the rear and standard type radial tires at the front, fastest time was arround 14.9seconds.
Changed the front tires to M-grip with the sidewalls being glued and this improved my car to turn in much better and laptime by almost 0.4seconds, all this with a ride height of 5mm (front&rear) and NO traction rolls.
Will keep testing with other setups, therefor i ordered a stabilizer set along with some carbon damperstays for M-chassis TRF dampers.
Hope to improve even more my laptime, will keep you guys informed
So far i really like how the M-06 drives
addicted2blue is offline   Reply With Quote
Old 06-26-2016, 07:29 AM   #1825
Looking for M06R, let me know if you have one for sale. Please pm me and Thank you!
seasons29 is offline   Reply With Quote
Old 06-26-2016, 09:15 PM   #1826
Raman's Avatar
Trader Rating: 56 (100%+)
Nice job, stick to it and show those FWD who is boss
Raman is offline   Reply With Quote
Old 06-27-2016, 10:24 AM   #1827
I will
Old 06-28-2016, 11:04 AM   #1828
Send a message via AIM to GuyIsDamGood
I run the TRF black springs (blue rear and yellow front). On the Carbon Damper Stays I use the fourth(4) holes. Camber rear 1, front 0.5. Ride height 5mm. For the tires I use 60D reinforced slick tires. With that setup I get absolutely no oversteer. It's like the perfect setup without sway bars installed.
Thank You
GuyIsDamGood is offline   Reply With Quote
Old 06-29-2016, 02:01 PM   #1829
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Thank You
is this for carpet or asphalt?
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 06-29-2016, 02:30 PM   #1830
Raman's Avatar
Thank You
I'm running similar set up on carpet. front is 0. Identical springs. For tyres I'm running Shimizu 30 with sweep hard insert in rear and Shimizu 40 in front. Car is very planted and no oversteer. As of yesterday I even started to run the car without the R spec axle weights. It gave me a bit more steering.
I'm battling with different turn in. Left turn in is superb and tight. right goes wide. I'm thinking its a weight balance issue.
Tamiya Championship Series Neil Rabara Racing Forum 21198 Yesterday 06:51 PM
EAMotorsports discussion thread BigDogRacing Team and Company Discussions 7672 10-11-2017 10:51 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
