Like Tree24Likes
Old 03-05-2016, 10:02 AM   #1801
Raman's Avatar
Trader Rating: 56 (100%+)
Originally Posted by GuyIsDamGood View Post
Does anyone know what is the fastest Brushless Motor you can run in the M-06?(the smallest pinion is a 16-t). I'm thinking a 6.5-turn is the fastest for the gearing.......?
6.5 will be a lot to handle on any rear wheel drive platform. You would have to be very gentle on take off and slowly accelerate to full throttle.
Also you will need to change tyres, the m chassis will balloon.. Recommend Shimizu racing inner mesh series
Last, I hope you have upgraded to oil filled shocks, otherwise you will not be able to put any power down
Raman is offline   Reply With Quote
Old 03-05-2016, 10:03 AM   #1802
Raman's Avatar
Originally Posted by IAmGreatDane View Post
I take it, if standard hard case lipos fit in the compartment, stick pack lipos will fit as well?
Thanks!
Yes.. Standard rectangular hard case LiPos fit just fine
Old 03-07-2016, 03:14 AM   #1803
Send a message via AIM to GuyIsDamGood
Thanks for the info Raman. I have (item # 54000) Aluminum Damper Shocks installed, (item # 54361) Front Damper Stay and 54162) Rear Damper Stay. This M06 chassis is mostly for my three sons. I just wanted to get more speed out of the car.
GuyIsDamGood is offline   Reply With Quote
Old 03-07-2016, 12:24 PM   #1804
IAmGreatDane's Avatar
Thanks, Raman.
Although I did mean stick pack as in good old 7.2V batteries (NiCd?) and not standard rectangular hard case lipos.
Best Regards,
I Am GreatDane c'',)
IAmGreatDane is offline   Reply With Quote
Old 03-07-2016, 02:33 PM   #1805
Raman's Avatar
stick are fine as well
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Old 03-08-2016, 12:17 PM   #1806
Best Regards,
Old 03-09-2016, 04:57 AM   #1807
cpal's Avatar
Default m06R
i have the R car and have had no luck with the setup for asphalt any setups i can try?
Chris Palermo - roar 1-91330
GP Racing - Brownies Hobbies -
If You Tempt A Squirrel With A Nut, Be Prepared To Be Bitten.
R.I.P CHESTER P.
cpal is offline   Reply With Quote
Old 03-17-2016, 05:50 PM   #1808
Default Set up
So what is your car doing? No luck can mean too pushy, to loose, traction roll, etc. I just ran a setup last week that with Tamiya spec tires (TCS) worked really well. Better on asphalt than my M03 or M05.
If you are not into TCS, then I found certain tire combos will make a car that should handle like garbage, actually be fun to drive. IM if you want a little help. I want to see some more M06 drivers have success. The 06 has a clear advantage in acceleration.
EB R
EB Racer is offline   Reply With Quote
Old 03-24-2016, 09:32 AM   #1809
foampervert's Avatar
Send a message via MSN to foampervert
Default M06 fiends!
Greetings fellow Rear Driven FANatics!
I've just created a fully editable Setup PDF for the M06
Should you want it, please drop me a PM with your email address.
The file is slightly larger then 1MB and cannot be posted here.
This will allow us to share our setups more effectively.
Cheerio!
-Alexander
p.s. The pic is a screenshot of the PDF files with stuff ticked and things written. It's fully editable, you can rename and store your own setups.
When sharing setups, just take a screenshot of your setup sheet (like I did) cos the setups sheet is, once again, 1MB and cannot be posted here.
During heats, i use durex for both front and rear, with Hard inserts.
Sorex, i meant Sorex.
foampervert is offline   Reply With Quote
Old 03-25-2016, 02:26 AM   #1810
Default my setup for TAC Rd1 (Singapore)
Dear Rear Driven FANatics,
Included is my setup for our local indoor carpet race (TAC Rd1) on a super high grip surface.
I find that the car traction rolls if I am off power, but is stable (with understeer) on throttle. This allows me to let off throttle early and power through a sweeper that M05 drivers have to brake and turn at.
the infield was a s-turn, a fast chicane and a 90 turn to a slight chicane to the straight and the m06 was flawless there.
All up weight is 1232grams.
I initially juiced the whole rear tyre and the 2 inner ribs of the front tyres, but I found myself still traction rolling. So I stopped juicing entirely... helped a lot but if I didn't get on throttle fast enuff or I chickened out and let off throttle, the car would traction roll in the sweeper.
any suggestions? lower ride height? minimum is 3mm... maybe I should slam the car down?
-Alexander
Old 03-25-2016, 07:23 AM   #1811
ruebiracer's Avatar
-Alexander
Dear Alex,
good to hear some race action from the M06 side!
Unfortunately, I cannot zoom your screenshot clearly enough to identify your setup! Can you post a pdf maybe? Or just pm me yours and of course Iīd like to test your editable setup sheet and compare to Ramanīs!
Without real knowledge of your setup, have you thought about gluing the front tire sides/tread with cyano to avoid traction rolling? Of course, it also depends on the tires you use. But if that are S-Grips, it will for sure help.
Br,
Matthias
www.TTSC-Racing.de
www.mst-estenfeld.de/der-loeffler-cup
ruebiracer is offline   Reply With Quote
Old 03-25-2016, 07:49 AM   #1812
Raman's Avatar
Agree with Mathias, we need to see your set up.
Old 03-25-2016, 09:49 AM   #1813
Originally Posted by ruebiracer View Post
Dear Alex,
Br,
Matthias
We aren't allowed to glue the sidewalls or tire surface... Technically, no other "anti-traction roll" techniques like thick silicon oil either (that's not preventing people from using it of coz)
I'd rather just tune it out or drive differently. I do like how fast they car is through turns... I just need it to be a tad less tippy.
I can send you the editable PDF and my setup via email. The PDF file is over 1mb and cannot be posted here. Just pm me your email address.
Alexander
Old 03-25-2016, 11:07 AM   #1814
Raman's Avatar
Alexander
I know your previously mentioned that you had tried my set up recommendation and it made the car twitchy.
My experience on carpet still remains the same, I do not have any traction roll issues. The limiting factor is always me.
Looking at your set up, I still feel you are too soft. So I recommend something in the middle. The light blue Spring is probably too stiff for 40wt and may be causing the rear to be bouncy.
to reduce traction roll, try the following, but not all at once.
1. Heavier shock oil eg 50wt
2. Yellow Spring up front
3. Running a weight down the centre of chassis under battery
Old 03-29-2016, 07:36 PM   #1815
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
EB R
hey EB - would you be willing to share your setup?? I'm getting one to try out this summer (for a TCS race), wanna try something different for a change instead of my m05
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 21150 08-18-2017 08:58 PM
EAMotorsports discussion thread BigDogRacing Team and Company Discussions 7669 08-08-2017 05:39 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
