Like Tree25Likes
Old 05-15-2015, 10:41 AM   #1711
Raman's Avatar
Trader Rating: 56 (100%+)
Originally Posted by HugoW View Post
OK, thanks, then I spent my lunch break effectively:
It's 4mm stainless steel, they are 12 grams each. I didn't bother with a clamp screw, I just undersized the main hole, opened up the slot with a screwdriver, slid the weights on and removed the screwdriver again. They seem to be stuck on there pretty well. I did have to cut back the reinforcement ribs on the hubs about 3mm.
I just cannot lose coming weekend
At least the car is pretty decent.
Hugo
Nice job.. I believe the oem brass weights are 7g
Raman is offline   Reply With Quote
Old 05-15-2015, 11:45 AM   #1712
sakadachi's Avatar
Sorry I cannot comment on the M-04. This is my first M after the M-01 (which I still have, but only my son occasionally drives).
Hugo
Thanks, Hugo, no problem!
Originally Posted by Raman View Post
They are worlds apart. m04 will never have the rear end grip of the M06.. The 06 has a much lower centre of gravity and is a better balanced chassis
Thanks Raman. I should check out the M06 down the road. RWD is fun to drive for sure!
4PKS-R, DX4S, EX-5UR: Sabre4WD Mini, SabreFD Mini, M01, M02, M03, M04, M05 (2), M05ProV2, TA05 M-Four, CupRacer, BSR M-Rage, WR02, GF01 (2), CC01 (2), CW01, CR01, DF02, TT02B, TA02, RS4, MicroRS4, MR01, MR03-S (2), MR03VE, DigiQ (7), & more.. Updates of projects I am working on in my profile page.
sakadachi is offline   Reply With Quote
Old 05-15-2015, 12:08 PM   #1713
The Tamiya Specs site says they're 10 grams, and here I found 12:
TAMIYA M-06 Thread
So I'm not really sure. I'll just leave them on, and keep the car as is tomorrow, only optimise the tires. I need track time with the car at this point, not necessarily the best possible set-up.
Hugo
HugoW is offline   Reply With Quote
Old 05-16-2015, 12:10 AM   #1714
marcos graveyar's Avatar
Send a message via AIM to marcos graveyar
Nice job Hugo.
marcos graveyar is offline   Reply With Quote
Old 05-17-2015, 08:51 AM   #1715
dc661's Avatar
Trader Rating: 127 (100%+)
Quick question, which body set are you guys using for tcs racing with the m06?
-DJ Cranmer
dc661 is offline   Reply With Quote
Old 05-17-2015, 03:46 PM   #1716
MD
MD's Avatar
Trader Rating: 118 (100%+)
http://www.activepowersports.com/tam...FZOFaQodHJgA1Q
MD is offline   Reply With Quote
Old 05-17-2015, 03:52 PM   #1717
Raman's Avatar
Any body set that comes with an M06 kit, also any rear wheel drive M chassis body
Old 05-17-2015, 03:54 PM   #1718
Raman's Avatar
FYI: Horrible site to order from .. They don't stock anything, they order directly from source and then ship..they make up for cheap prices with shipping charges
Old 05-17-2015, 06:09 PM   #1719
MD
MD's Avatar
I've never ordered from there. It was one of the first sites to come up when I google the stock number.
Old 06-28-2015, 09:53 AM   #1720
hispeedguy's Avatar
Trader Rating: 35 (100%+)
I'll revive the M06 thread a bit. I am dusting off my M06 to begin getting it ready for the on road season to start here in late Sept. The diff (stock gear) got ruined at my last outing w/ my car at Marshall's in March. Should I stick w/ the stock gear diff parts for rebuild or should I consider the ball diff instead? The car was a handful when I 1st started with it last November, but using some setup tips I found on this thread and a LOT of laps, the car was getting better and better. Looking forward to getting the Mini's back on the track!
www.RCSoup.com www.cowrc.com
hispeedguy is offline   Reply With Quote
Old 06-28-2015, 10:16 AM   #1721
Raman's Avatar
Stock diff is heavy and doesn't allow much tunability. It doesn't hold silicone fluids.
Spec R and 3 Racing make gear diffs that hold silicone fluids.
I like the M05 balk diff. Had yet to service it once
Old 06-28-2015, 10:21 AM   #1722
kwkride's Avatar
Originally Posted by hispeedguy View Post
Should I stick w/ the stock gear diff parts for rebuild or should I consider the ball diff instead? . . .
It's probably a personal preference thing, but I run the M05 ball diff in mine. I've been pretty happy with it, and I've had it in there for 2 years running almost weekly.
Jim
"If God had meant for us to drive through the front wheels, he never would have allowed us to invent the ring & pinion"
kwkride is offline   Reply With Quote
Old 06-29-2015, 12:10 PM   #1723
hispeedguy's Avatar
Thanks for the info, I was thinking the ball diff was the way to go as well.
Time to place an order at TQ :-)
Old 07-11-2015, 10:31 AM   #1724
funked1's Avatar
I apologize if this was answered already. I searched for 15 minutes and couldn't find an answer.
I am trying to install the 54194 M-05 ball diff into a standard M-06 kit.
When I assemble the diff housings, the diff is able to slide back and forth axially (left to right on the car) about 1mm. I checked my M-05 Pro with the same diff, and there is barely any slop in the diff.
Did I build it wrong?
Or do I just need to find or make an appropriately sized spacer to take up the slop?
Or just live with the slop?
XRAY T4 '17 VTA / Tamiya M07 / Tamiya Euro Semi / Speedworld Raceway
funked1 is offline   Reply With Quote
Old 07-11-2015, 12:33 PM   #1725
Raman's Avatar
2mm is a bit excessive. Are you using the right bearings? They should be 10x15x4, 4mm being the width.
There are shims you can use also, they come in width of 0.1, 0.2, and 0.3mm. These are used to stop play
Tamiya Championship Series Neil Rabara Racing Forum 21198 10-19-2017 06:51 PM
EAMotorsports discussion thread BigDogRacing Team and Company Discussions 7672 10-11-2017 10:51 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
