Like Tree23Likes
Old 04-24-2015, 09:57 AM   #1696
Raman's Avatar
Trader Rating: 56 (100%+)
I recently watched Jilles Groskamp's build tips on YouTube. If you guys get a chance, watch the part on building shocks. I have been bundling them that way and have had great consistent results. On a car such as M06 with limited tuning, it helps a lot.
Raman is offline   Reply With Quote
Old 04-24-2015, 04:48 PM   #1697
ShadowAu's Avatar
Originally Posted by HugoW View Post
Huh? Can anyone explain to me what this does, and whether it makes sense (on an M-06)?
http://www.musicamoviles.com/EtRqhiRHpPs/m-05-ff/
Thanks!
Hugo
Looks to me like a very complicated and heavy way of achieving the same basic thing a sway bar does
ShadowAu is offline   Reply With Quote
Old 05-02-2015, 04:06 AM   #1698
The race body for the long chassis is done:
Hugo
HugoW is offline   Reply With Quote
Old 05-07-2015, 06:55 PM   #1699
Herc Driver's Avatar
Nice job Hugo.
2 questions for the bunch.
1. On the M06 pro it comes with e clip hinge pins (steel I assume) and the long screw type hinge pins...if you use the hinge pins do you just not use the same me that the shock mounts on? The hinge pin with ball on end?
2. Does everyone's rear camber length deeply angle backwards (as seen from above)? Seems you could space out the ball studs and make it more straight.
Herc Driver is offline   Reply With Quote
Old 05-08-2015, 09:23 AM   #1700
Raman's Avatar
Originally Posted by Herc Driver View Post
Nice job Hugo.
Hinge pin with ball end gives you more ability to lay down the shock. So it's a good mount to use.
The camber links are angled. I have often pondered using spacers to straighten them out.. However since the car is so planted, I've never bothered to mess with it
Old 05-08-2015, 09:36 AM   #1701
Ok thanks...building the trf shocks and painting up my herbie body next.
Still looking to get aluminum motor mount and 1 degree hubs next
I have kit clear shocks (nip) that I won't be using pm me if you are interested.
Old 05-14-2015, 07:42 AM   #1702
Hi guys,
Today while testing my car I think I messed up my M-05 ball dif. If I drive slowly its works, but when I push the throttle It starts slipping. I will take it apart tonight, but I need a back-up plan. I have the original gear dif still, should I keep it light with regular grease, heavy with AW grease or semi locked with 500k Tamiya silicone dif oil? I will race an outdoor tarmac track this weekend. Conditions unknown, a new top surface was put down last Tuesday.
Thanks,
Hugo
Old 05-14-2015, 07:52 AM   #1703
sakadachi's Avatar
Hugo- That body you did looks awesome! I use thread lock on the ball diff screw when I assemble it.
As for bevel diff solution, I hear people use 2 washers per side instead of one (or more) to shim it up to tighten the diff + the AW grease you mentioned.
My question.. I have a M04L for the longest time. It's "ok". I'm sure you get asked a lot, but how much better is the M06?
4PKS-R, DX4S, EX-5UR: Sabre4WD Mini, SabreFD Mini, M01, M02, M03, M04, M05 (2), M05ProV2, TA05 M-Four, CupRacer, BSR M-Rage, WR02, GF01 (2), CC01 (2), CW01, CR01, DF02, TT02B, TA02, RS4, MicroRS4, MR01, MR03-S (2), MR03VE, DigiQ (7), & more.. Updates of projects I am working on in my profile page.
sakadachi is offline   Reply With Quote
Old 05-14-2015, 01:16 PM   #1704
Thanks for the compiment, and for the dif info. I meanwhile found I forgot the outer bearing in the middle gear of the gearbox, so the pinion was slipping on the worn gear. How stupid is that? Anyway, the dif is in good shape and the issue is fixed. Saturday my first real training session with the car, Sunday the first race.
Sorry I cannot comment on the M-04. This is my first M after the M-01 (which I still have, but only my son occasionally drives).
Hugo
Old 05-14-2015, 01:39 PM   #1705
Raman's Avatar
They are worlds apart. m04 will never have the rear end grip of the M06.. The 06 has a much lower centre of gravity and is a better balanced chassis
Old 05-14-2015, 10:29 PM   #1706
Another question. I hear the rear upright weights of the R version really are a great help, but they are not available anymore. Are they really such a big help?
Now I am allowed one or two non-standard parts in our Cup. If I read this:
http://www.tamiya.com/english/produc...m06r/index.htm
I see the weights are 10 grams each. Would adding 10 grams of lead strip with a ty wrap have similar benefits as the original clamp on ones? It would be easily made...
Cheers,
Hugo
Old 05-15-2015, 02:41 AM   #1707
marcos graveyar's Avatar
Send a message via AIM to marcos graveyar
There was a guy in Australia who made a batch of the wheel weights last year, made 20 sets or so, don't know if they are still available though.
marcos graveyar is offline   Reply With Quote
Old 05-15-2015, 05:10 AM   #1708
kwkride's Avatar
Yes, that's what my buddy did on his, after seeing the weights on my "R". It works fine.
Jim
"If God had meant for us to drive through the front wheels, he never would have allowed us to invent the ring & pinion"
kwkride is offline   Reply With Quote
Old 05-15-2015, 05:39 AM   #1709
OK, thanks, then I spent my lunch break effectively:
It's 4mm stainless steel, they are 12 grams each. I didn't bother with a clamp screw, I just undersized the main hole, opened up the slot with a screwdriver, slid the weights on and removed the screwdriver again. They seem to be stuck on there pretty well. I did have to cut back the reinforcement ribs on the hubs about 3mm.
I just cannot lose coming weekend
At least the car is pretty decent.
Hugo
Old 05-15-2015, 05:50 AM   #1710
kwkride's Avatar
Great job on those!
Jim
Tamiya Championship Series Neil Rabara Racing Forum 21143 Today 02:07 AM
EAMotorsports discussion thread BigDogRacing Team and Company Discussions 7669 08-08-2017 05:39 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
