Like Tree25Likes
Old 04-19-2015, 12:42 PM   #1681
Raman's Avatar
Trader Rating: 56 (100%+)
Originally Posted by Herc Driver View Post
Anybody have an opinion on 1 degree vs 2 degree rear hub carriers?
Also, I've noticed the front graphite shock towers (among other parts) is discontinued...any insight to this?
I missed the boat with the M06 pro...now I'm piecing one together slowly and $$$$.
I have been running the 1 for quite some time. Its good to have both.
The shock towers are still available. There are two version however.
For standard M chassis dampers / M chassis TRF
Front: http://www.tamiyausa.com/product/ite...oduct-id=54299
Rear: http://www.tamiyausa.com/product/ite...oduct-id=54300
For TC TRF dampers:
Front:
http://www.tamiyausa.com/items/radio...per-stay-54361
Rear:
http://www.tamiyausa.com/items/radio...per-stay-54362
If you are looking to buy the TC style TRF ones.. PM me.. I have them both unused.. and have no need for them.
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 04-19-2015, 01:21 PM   #1682
Herc Driver's Avatar
Thanks, I didn't realize they were different. I've been out of it for a little while and to be honest all the choices are a bit confusing...I was happy when it was just trf shocks. I guess I'm a bit out of the loop now with the other options.
Thoughts on a v2 coming out soon?
I kick myself for missing the type r.
Herc Driver is offline   Reply With Quote
Old 04-19-2015, 01:27 PM   #1683
What advantages are you noticing with the 1 degree hubs?
Old 04-19-2015, 01:30 PM   #1684
Raman's Avatar
They definitely need a version 2! You are also right, it is a bit confusing.
I run the standard graphite towers on the car front and rear. On the front I'm running the m chassis trf dampers. On the rear I am running the TC TRF damper with the Pro longer piston. The reason is because I am using the R spec lower arm mount, which lowers the mount position another mm. With the M chassis dampers, I was having a hard time getting to 4 mm rear ride height. Thats why I never bothered to use the TRF TC mounts.
Old 04-19-2015, 01:44 PM   #1685
Do you have thoughts on the aluminum motor mount and the gearbox plate that goes on the opposite side as well?
Looks like it would eliminate or reduce/dissipate some heat.
I'm deciding what hop ups I gotta buy...(lol). I got a kick out of a box stock M06 after having driven a M03M for quite a while.
Old 04-20-2015, 05:18 AM   #1686
Hi guys,
I finally managed to bust a plastic shock on the M-06, so I am looking at the Racing set:
http://www.rcmart.com/3racing-m03m13...?cPath=389_390
Does anybody know the ball diameter on this set, will it fit the balls on the rear suspension axle upgrade (standard on the Pro cars)?
Cheers,
Hugo
HugoW is offline   Reply With Quote
Old 04-21-2015, 08:53 AM   #1687
Hugo,
Says they are a direct replacement...I assume they fit the stock axels...the reviews on your link make me think that.
So switching my brain to ceramic bearings...I've used acer with great success, obviously they are pricey...have heard good things about Boca..does anyone have other recommendations for ceramic (fast) bearings.
Old 04-22-2015, 03:41 AM   #1688
Well I ran my M06 at a local inter club championship and man this thing is planted. So fast off the line compared to my M05 v2. I have got one slight problem with the car stuttering when turning. Initially I thought the wheels were rubbing on the front hubs when turning so changed to thicker hexes. This didn't cure the fault so it looks like an electrics problem, the motor stalls when turning. I'm going to change my servo for a less powerful one and use a booster and see it that cures it. Won all 3 qualifiers and both finals although I did use the M05 v2 for the last final.
Zen RSGT, Trinity, Hobbywing, LRP.
M05 S-Spec, LRP, Intellect.
M05 v2 Tekin, Orion, Savox.
B44 Mamba Max, Trakpower.
B44.2 Avid chassis, Speed Passion, Gens Ace.
BILKO1 is offline   Reply With Quote
Old 04-22-2015, 04:33 AM   #1689
kwkride's Avatar
Sounds like you had a great run. Congratulations!
Jim
"If God had meant for us to drive through the front wheels, he never would have allowed us to invent the ring & pinion"
kwkride is offline   Reply With Quote
Old 04-22-2015, 07:43 AM   #1690
Huh? Can anyone explain to me what this does, and whether it makes sense (on an M-06)?
http://www.musicamoviles.com/EtRqhiRHpPs/m-05-ff/
Thanks!
Hugo
Old 04-22-2015, 10:24 AM   #1691
Raman's Avatar
Yes I will complicate set up for 0 benefit
Old 04-22-2015, 01:15 PM   #1692
Looks like somebody had some spare parts and time to kill. The cross turnbuckles was cool looking at least.
Old 04-22-2015, 01:25 PM   #1693
Raman's Avatar
Nice work!
Old 04-23-2015, 09:33 PM   #1694
Got my shock towers, aluminum bits (thanks Raman), TRF shocks, titanium screws...waiting on bearings to arrive....then time for fun with my M06L VW super beetle!
Old 04-24-2015, 01:17 AM   #1695
Yesterday, after wrecking my shocks and body some time ago, I decided to rebuild the car. Subtle difference:
I also went for the Beetle body, should be deliverd soon. Awaiting new ESC (old one is now in my son's M-01) and a new set of 50746 shocks, as I busted one. I considered TRF ones, but this is just a fun car and the real money is spent on my Cup racer TT-01.
Hugo
Tamiya Championship Series Neil Rabara Racing Forum 21198 10-19-2017 06:51 PM
EAMotorsports discussion thread BigDogRacing Team and Company Discussions 7672 10-11-2017 10:51 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
